This is a GT2 Pulley 16teeth 1mm pitch and fits 5mm motor shaft.
Onshape.com online cad was used to design this part.
Standard Tesselated Geometry - 303.21 kB - 12/15/2016 at 11:51
Download attached STL file and print it out.
View all instructions
Mark Liu
Peter Buckley
Luc JOB
Rory
Yes, delete it Cancel
You are about to report the project "GT2 Pulley 16t 1mm pitch 5mm shaft", please tell us the reason.
