The Cardboard Computer - IO is my name
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This is an educational platform for me.
My goal is to build a four bit computer using recycled, re-purposed and just plain junk as the main construction material. Why? Well, the cardboard is free as my workplace puts it in the dumpster and I do not have the funds to buy better material. A very green build indeed. The first electronic parts to start this were given to me by a friend who passed away and what better tribute than to build a computer. Except for the ALU all gates are either NAND or Nor using DTL. The transistors used are NPN 2N2222 type or PNP 2N3906. Thanks to Yann Guidon and Jezz - Morning Star for additional parts. Very large construction is employed as to aid in my learning about logic circuits and also to make it easier to make changes as I find out what does not work. Each gate measures about 0.75 X 1.75 inches on cardboard cutouts. RISC will used and the clock speed will be very slow at about 3Hz to start. The main bus is 8-bits ( 4 for data and 4 for address ).
Having a little fun with IO
IO has printed its first word after some issues were cleared up.
Added a clock speed control to IO
Replaced the 555 IC with a astable circuit.
2's complement works well for counting down.
October 19, 2017 - Power usage for IO at about 1.5 watts / 5 volts
October 12, 2017 - IO's theme song. Pink Floyd - Wearing the Inside Out
September 24, 2017 - IO has a new 7 segment display.
August 27, 2017 - Update, All the current sections of IO are working together.
HACKADAY Wheels, Wings and Walkers 2017 contest entry.
Cardboard computer video update 1
Cardboard computer video update 2
Cardboard computer video update 3
IO - The Cardboard Computer update 4
  • 130 × 2n2222 npn transistor
  • 95 × 2n3906 pnp transistor
  • 230 × 1n914 Switching diode
  • 462 × Resistors Assorted common values
  • 1012 × Paper fastener Paper fastener found in any big box store
View all 7 components
  • Light Logic is coming
    Dr. Cockroach10/18/2018 at 08:31 0 comments
    I have decided that the upcoming IO2 project will use #Light Logic gates entirely. This means a CPU/MCU with out transistors, relays or vacuum tubes for ALL of the logic circuits.
  • A fairwell to IO but looking forward to IO2
    Dr. Cockroach08/28/2018 at 19:52 8 comments
    Here it is August 28, 2018 and I have decided that IO has reached its limit. I have learned a lot from this project but IO has has grown to the extent that I no longer have enough room to work on any other projects and I might be moving away from the coast in the next year.
    I will be saving IOs boards either for future use in IO2 or will use the parts on other projects. I wish to thank everyone here on Hackaday for their support and look forward to the same support in future projects.
    There are no set plans for IO2 except that it will be much more modular in design.
  • Still on hold but not for long
    Dr. Cockroach07/19/2018 at 23:45 0 comments
    Here it is July 19, 2018 and IO is still on hold as I continue to work with other projects for this years HaD contest. I have decided that I wired myself into several corners on IO and once work resumes, I will revise some of the sections and make other improvements as I come across problem areas.
    Thanks for all those who are followers and there will be more of IO and later, IO2
  • IO is on hold - May 30,2018
    Dr. Cockroach05/30/2018 at 10:24 0 comments
    Dont panic everyone, I am giving IO a vacation while I work on #ColorChord  for the 2018 contest. I had to borrow a couple of parts from IO but it is still in fine health :-)
  • K.I.T.T. meets Carr..dboard
    Dr. Cockroach05/06/2018 at 22:42 12 comments
    Well it's time for a little fun for a change and @davedarko  this for you :-D
    Thank you @danjovic  for the new title :-D
    Was wondering what to do next with IOs construction and @Morning.Star  gave me an idea that tickled my funny bone :-)
    So watch the video and enjoy...
  • First printed word for IO - April 11, 2018
    Dr. Cockroach04/11/2018 at 19:30 13 comments
    Finally have been able to get IO to print out its first word. The home made opto-couplers had a little light leakage issue near the leds but sealed that end off with black silicone and now all of the circuit is working as desired :-)
  • Opto-Couplers for IO
    Dr. Cockroach04/09/2018 at 23:25 3 comments
    I have decided that even though the relay will work as isolation for the printer signals, I see that it would take a lot of time to perfect and build the number that I need. Sooooo, I am rolling my own opto-couplers. @Morning.Star provided the seed to go this way and it is so simple. The CdS cells are from old style night lights found in area thrift stores and the Leds I already have so take a look at the construction images and smile a little. BTW I have seen this method else where on the internet and it works quite well. With no light the cell has a resistance of 15k ohms and full led light it goes down to 400 ohms. IO and the printer work well with it.
    The night lights are being sold cheap as they have old style incandescent bulbs and folks these days want the Led type. Better for me in finding cheap parts to hack with :-)
    The SCR? and 1meg resistor might find a use later on.
    Good swing in resistance.
    Here is a very short video of two couplers connected between IO and the printer. No timing or signal level issues :-)
  • A cardboard relay for IO - March 21, 2018
    Dr. Cockroach03/21/2018 at 10:58 2 comments
    Here is the second version of the Uglytech relay. I will try this for signal isolation to the typewriter/printer. Still needs work but getting better at this...
    This video shows that the relay does work with both IO and the printer Note the screw and nut added to adjust gap.
  • A possible output device for IO
    Dr. Cockroach03/02/2018 at 17:11 7 comments
    Found this Smith Corona Typewriter for $8 and it works fine. No, the Hello World is not from IO... I might be able to patch IO into the keyboard electronics so please pray for me on this one :-)
    The keys press a small rubber? coated finger across the meshed contacts so I think that the contact is acting like a capacitor. Going to begin mapping out the matrix...
    So far so good. The contacts are simple make and break. Makes the use with IO a little easier :-
    So here it is March 4, 2018 and I have cobbled up a plug in adapter to where the keyboard ribbon cable connects to the main board. Take a look at the progression and either shake your head or chuckle a little but the connection is rock solid.
    At least this way I can restore the typewriter back to the way it used to be later :-)
    Here is how the connector has mapped out.
    All wired up and ready for input from IO :-)
    Just at the point where IO is able to send a signal to the typewriter with each sequencer cycle. This is just the beginning.
  • ROM card read logic board - March 2, 2018
    Dr. Cockroach03/02/2018 at 13:03 12 comments
    Update May 5, 2018 -  IO's failed audition as K.I.T.T from Knight Rider :-) But not bad for just four leds.
    Just having some fun with the instruction cards
    The ROM instruction board all finished and tested. Now need to wire up more cards.
    Update May 1, 2018 - All of the logic is wired and the board tests OK after finding one shorted wire.
    Update April 30, 2018 - Here is the progress today. The first image shows the power wiring.
    This next image shows how the first two 4 input nand gates are wired to the address buss.
    This shows the unit being tested. the simulated address switches are set for address 0001 and a rom instruction card with the value of 0111 is inserted into the second slot. The output leds indicate 0111. So far, so good :-)
    Update April 29, 2018 - I have set up the logic gates and ready to do some serious wiring. The four gates on the lower left is the address input from the PC. The 16 Nands at the top decodes the address and selects the required instruction to be read. The four gates on the right side is the instruction output to be sent to the CU.
    Update April 17, 2018 - After the usual delays I am getting back to wiring up the logic gates  and get back on track with the Brain Warp instructions.
    Starting to layout the construction and wiring for the logic board that will read the program ROM cards. Just like all other wiring on IO, this will be a large board...
    The ROM back plane will mount above the logic circuits...
View all 69 project logs
  • 1
    Step 1
    My basic nand gate
    I guess that this could be called a single 2 input nand gate IC . Just very large scale.
    Start with cardboard and brass fasteners
  • 2
    Step 2
    Layout the parts needed.
  • 3
    Step 3
    Solder the parts to the cardboard base
View all 5 instructions
Yann Guidon / YGDES wrote 12/21/2016 at 03:15 point
Please, upload some schematics :-)
What do you use to mount the parts ? I've never seen this method before :-)
Dr. Cockroach wrote 12/21/2016 at 09:21 point
Good morning Yann, As soon as I figure out Hackaday I will get some sketches of the circuits I am using. The metal paper fasteners on cardboard is used for a few reasons. 1 I'm poor, no extra money to buy better material. 2 it spreads out the parts so I can better learn what is going on visually and 3 it looks kinda cool and almost a art form in itself. The gates are attached to the main cardboard frame using hot melt glue.
Yann Guidon / YGDES wrote 12/21/2016 at 13:43 point
You could write a log that explains your unusual but smart method :-)
For example, a step-by-step How-To with several pictures ?
Who knows who it might inspire in turn ?
Regards :-)
Yann Guidon / YGDES wrote 12/21/2016 at 13:44 point
Oooooops too late :-D
Dr. Cockroach wrote 12/21/2016 at 13:53 point
Yup, started posting some instructions. Now it's time to get dressed and go to work. I'm a chef at a assisted living facility and there are some days I feel like I need to live there :-)
coletonn wrote 12/21/2016 at 14:14 point
Yeah that would be nice. See how the thing ticks.
zaphod wrote 12/20/2016 at 15:20 point
this is pretty impressive
coletonn wrote 12/20/2016 at 18:36 point
Ikr. This gives me a headache.
Dr. Cockroach wrote 12/21/2016 at 01:10 point
Thanks, so is yours. you have inspired me to keep working at this.
