PiG (Pi4GPU)
Raspberry Pi CM4 carrier board for testing GPU cards
Dedicated carrier board for Raspberry Pi CM4 module (and compatible models) for testing high-performance GPU cards, enclosed in the standard PCIe form factor card.
Technical specification:
ports: HDMI, 1GbE RJ45, 2x USB 2.0 host (Type A);
power supply inputs: 12VDC DC barrel jack or 6-pin Molex (8A max.);
microSD slot for CM4 Lite module;
full 40-pin GPIO pin header;
4-pin fan socket (controlled by EMC2301) - 5/12V version supported;
USB-C for flashing CM4 module;
system and user LEDs;
PCIe x4 edge connector (PCIe x1 lane only implemented);
I2C diagnostics module for analog measurements (system power rails, 3.3V/5V/12V, voltage/current);
Project published as Open Source Hardware (OSHW) under CERN OHL v1.2 (Open Hardware License).
https://github.com/mfolejewski/PiG_Pi4GPU
https://github.com/geerlingguy/pi4gpu
Jeff Geerling video review:
https://www.youtube.com/watch?v=l9dItRUjQ0k
x-zip-compressed - 18.39 MB - 04/13/2023 at 16:54
Download
x-zip-compressed - 15.08 MB - 04/13/2023 at 16:53
Download
Technology overkill wrote 04/14/2023 at 18:20 point
The only question left to answer is, can it run Doom?
