I Built a Magnetic Phone Stand
I use my phone to take videos of myself. But I kept dropping my phone. I built a stand to mount my phone anywhere.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
https://youtu.be/_g9Bg83jz3Q The full build is here! I was inspired by Van Neistat's (Casey Neistat's brother) phone stand. Van uses his stand in his car. However, I required a wider use case. So I added a magnet to the bottom "foot" to mount to any beam, fence, chair, shelf, door, etc. The "foot" attaches to a go-pro inspired tilt mechanism. With the tilt mechanism attaching to a screw-phone mount. Though it's important to note I cannibalized the screw-phone mount from a tripod I was using before. Everything else was 3D printed and found at the hardware store. (magnet, 1/4" hex bolts, wing nut).
