Dual valve pre-amp guitar pedal
true bypass guitar pedal effect
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The pedal is based on Matsumin valve caster project. I modified it to house 2 tubes for an extra crunch. Each of the tubes sits on independently operated circuit with potentiometer controlled gain. Tone is controlled by the third, common potentiometer.
