Project based on ATTINY13A MCU and uses almost all of its flash ROM. EEPROM & RAM not used.
Firmware can be assembled with Atmel AVRASM2 or gavrasm (tested with version 3.5).
Standalone charger for PlayStation 3 controllers
PS3 Charger.7zSchematic, FW & Source code7-Zip - 19.00 kB - 01/02/2017 at 19:53 |
Any 12MHz quartz oscillator, suitable to clock ATTINY13. Something like http://sjk-crystal.com/4-2-3225-smd-oscillator/169879/ for example.
I only built it on debug board and used clock source from that board.
Hello, does it realy work ?
Someone did build a pcb ?
regards
Yes, it works. I just build it on a breadboard and my Sixaxis controller started charging.
Great work, Vga. Thank you so much!
Anybody have built this? what is the type of oscilator. thanks
