"Etch A Sketch" style frame and function for the badge from Hackaday Supercon 2023
phosphor_gradient_14.pyUpdate this file on your badge for the simplest way to change the phosphor persistence to 100%. A side effect is the loss of the menu highlighting feature, so you will have to navigate in the blind. A more complete firmware update is pending with a little more free time...x-python-script - 677.00 bytes - 11/13/2023 at 14:51 |
Potentiometer knob v5.stl3D printable knob. PETG or PLA 0.2mm layers.Standard Tesselated Geometry - 266.10 kB - 11/08/2023 at 05:14 |
Pot P160 datasheet.pdfThis project uses two of the potentiometers. 10K is a reasonable value, others will work. Cut down about 1/3 to 1/2 of the stem so the knobs fit closer to the frame.Adobe Portable Document Format - 600.40 kB - 11/08/2023 at 04:56 |
HackASketchBodyFinal_0.4n_0.2mm_PLA_MK3_2h0m.gcodeSliced version of the body for printing in PLA on a Prusa MK3 with 2 colors and support. Near the end of the print you will get prompted to change the filament for the gold lettering layer.gcode - 2.68 MB - 11/08/2023 at 04:42 |
HackASketchKnob_0.4n_0.2mm_PLA_MK3_13m.gcodeSliced version of the knob for printing in PLA on a Prusa MK3. You will need 2 of these.gcode - 1.49 MB - 11/08/2023 at 04:42 |
Thank you...
...Hackaday and Supply Frame teams for making Superconference 2023 and the badge happen!
...SoftEgg for the early CAD model of the badge to work from!
...Simen, Elliot, Tom, Daniel for providing help with code mods!
...attendees who cheered us on! What a great community.
Did you know the original Etch A Sketch launched in 1960??? 63 years ago...
Learn more: https://en.wikipedia.org/wiki/Etch_A_Sketch
Connect the 3V line to the top of both pots.
Connect the ground line to the bottom of both pots.
Connect the left pot's center pin to X oscilloscope input.
Connect the right pot's center pin to Y oscilloscope input.
Definitely one of my favorite badge hacks from Supercon 2023. Especially in that is really embraced the analog nature of the badge -- no microcontroller needed here.
So many points for simplicity and the idea :D Nice one!
