PSU #099, an EX354RD
03/05/2024 at 16:23 • 0 commentsThis is a switch-mode PSU, so the mains is rectified to around 400 volts DC inside.
Extra care is required to avoid touching this dangerous part of the PCB.
Instruction manual:
EX354RD+EX354RT_Instruction_Manual-Iss6.pdf
Fault:
Not marked on unit.
Suspected cause:
Examination:
Action:
Result:
Status:
Unknown.
Photos:
Plenty of room allows passive cooling:
Front panel:
Power inlet area:
PSU #095, a CPX400SP
03/05/2024 at 16:21 • 0 commentsThis is a switch-mode PSU, so the mains is rectified to around 400 volts DC inside.
This can be remote controlled by GPIB, RS232, USB or Ethernet.
The user manual is here: CPX400S+SA+SP_Instruction_Manual-Iss9.pdf
I have requested the service manual.
Fault:
Output trips at over 20 watts.
Error on display.
Suspected cause:
Examination:
Action:
Result:
Status:
Examination:
Remove three screws at the back:
Pop the plastic rivets at the sides:
They would not pop out so I ran a knife between the metal side and bottom.
You can see the display and controller boards (left), the power board (nearest), network board (furthest right) and GPIB board (middle right):
A better view from this side:
Be very careful, don't poke around willy nilly!
It is densely packed. The case forms a tube that the fan blows air through.
Networking boards:
Front panel display and control boards:
I can't see what that microcontroller is.
I suspect the 4-way cable is a serial comms link to the networking board. Maybe I2C?
PSU #084, an EX1810R
03/05/2024 at 16:19 • 0 commentsThis is a switch-mode PSU, so the mains is rectified to around 400 volts DC inside.
Fault:
Sparking at back of unit.
Suspected cause:
Faulty power connector or EMC capacitors.
Examination:
The power inlet was loose in the PCB, because of repeated cable insertions and no attachment to the case. Thus the strain goes direct to the PCB joints.
Action:
Resoldered power connector joints.
Result:
No sparking.
Status:
Fixed. Awaiting re-assembly and PAT test.
PSU #077, a PL154
03/01/2024 at 10:51 • 0 commentsFault label: "Faulty current limit".
Suggested action: Check current sensing circuitry.
PSU #075, a PL154
03/01/2024 at 10:49 • 0 commentsFault label: "Current readout and limit vastly wrong".
Suggested action: Check voltage entering digital meter chips.
PSU #073, a PL154
03/01/2024 at 10:47 • 0 commentsFault label: "Missing sense plate, wrong voltage".
PSU #010, a PL320QMD
03/01/2024 at 10:46 • 0 commentsFault label: "Numbers keep changing".
2024-03-01
Switched on, set dials to maximum. Leftt around 28.8V and drifiting, right around 32.88
Dials set to minimum.
Left side very slowly descends to 14.3 volts, terminals are at -0.424 volts.
Right side slowly descends to 1 volts, terminals measures 0.017 volts and quickly rise to 32 volts when dial turned.
Voltage displays take a very long time to change when dials adjusted.
A look inside shows no disconnected cables. It is essentially two power supplies in the same case, with some push-buttons to connect them in parallel, serial, or not at all.
Therefore it seems odd that both sides should be failing at the same time.
PSU #001, a PL320
03/01/2024 at 10:44 • 0 commentsFault label: "Sparky".
2024-03-01
Opened case. Mains cable enters through grommet and is wired to the front-panel mains switch. There is no IEC filtered inlet.
No sparking seen, even if wires poked with an insulated plastic rod (a Biro).
Dials set to maximum, voltage reads 29.75, current limit reads 2.1.5.8.
Diagrams
02/26/2024 at 02:56 • 0 comments
