Vento is a SunLeaf derivative board that replaces the ESP-09 modules with a ESP32 chip. The idea behind Vento is that its a BLE and ARM development platform that can run off lipo batteries and be solar charged.
Its essentially a more open ended SunLeaf as far as applications go, where as SunLeaf is aiming to be a node in a remote sensor network.
Vento will allow individuals to make bluetooth or wifi enabled devices of their own using the same technology as SunLeaf.
AVR
Guido - IW5ALZ
pcadic
Davide Raggini
morgan
What kind of solar panel do you recommend for this design? Looking forward to seeing more!
