![](http://m0.tibbo.net/m/pictures/tps-tutorials/wiegand-demo/wiegand-demo-scheme.png)
On-board Software
- SQLite database engine to store cardholder's info and events;
- Node.js V6.x.x (pre-installed during production)
GitHub Repository
Repository page: https://github.com/tibbotech/wiegand-demo
Clone URL: https://github.com/tibbotech/wiegand-demo.git
Updated At: Mon Oct 10 2016
Node.js Application
- The app utilizes the sqlite3 module as a permanent event and cardholder data store. The module is a serverless, self-contained SQL database engine which does not need any other software to be installed on the device.*
- Express and socket.io support web interface functionality.
* The module is written in C++. A precompiled version will be installed from Tibbo's GitHub during the app installation. If you want to install the module from NPM, you should also install build-essential on the device.
Web Client
- The web client UI is based on the Angular Material library according to Google's Material Style guide.
- Angluar toolset binds the UI and the client-side application logic.
- Socket.io library facilitates real-time bi-directional communications between the on-board and interface application.
The web interface includes three tabs:
1. Add a user tab
To enroll a user:
- Click READ CARD;
- Read a card; the ID code from this card will be displayed in the User ID field;
- Fill in the First Name and Last Name fields manually;
- Click ADD USER to make a new record in the database.
![](http://m0.tibbo.net/m/pictures/tps-tutorials/wiegand-demo/wiegand-interface-01.png)
2. User List tab
This tab displays all the records you've created. It also allows you to delete user records.
3. Events tab
This tab displays access control events on-the-fly.
The TPB2L variant is too much different. It's based on Tibbo C/Tibbo BASIC and we decided to sell it as a complete AggreGate + TPS2L solution: http://tibbo.com/solutions/access-control.html
