Simple 3D-Printed solder stencil frames
Just a quick OpenSCAD design to help hold solder stencils
With these frames and a 1.6mm board, the board is flush with the edge of the frame for applying a stencil and adding solder paste. For 1-sided boards it's easy enough to use scrap boards make a frame while applying paste. If you're reflowing both sides of a board, a frame is really helpful
Frame1.stl
Standard Tesselated Geometry - 7.84 kB - 03/11/2017 at 17:24
Download
Frame1.scad
scad - 440.00 bytes - 03/11/2017 at 17:24
Download
