The heart of this project is the Cardboard Logic Pad or CLP. With this construction method, any logic gate can be produced and pads can be combined for more complex logic circuits. This method started out by using thumb tacks pressed into wood panels. That method was not well suited to easy circuit modification and logic gates could not be inserted or removed easily. Using cardboard as a base material has proven to be easier to work with and is lighter in weight.
Dr. Cockroach
deftcoyote
Harvey Sugar
Frank Duggan
Beautiful design, illustration, photos. I like the brass brads, 3D circuit assembly, and common transistors. Nice tangible aesthetics. Your DTL cardboard logic pads make me wonder if a computer (diode-logic) could be succesfully built from a crystal rock collection acting as point-contact diodes.
