Step 1: Go to System -> Administration -> Software & Updates
Step 2: Check the checkboxes to repositories to allow “restricted,” “universe,” and “multiverse.”
Step 3: Setup your sources.list
1
sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
Step 4: Setup your keys
1
wget http://packages.ros.org/ros.key -O - | sudo apt-key add -
Step 5: To be sure that your Ubuntu Mate package index is up to date, type the following command
1
sudo apt-get update
Step 6: Install ros-kinetic-desktop-full
1
sudo apt-get install ros-kinetic-desktop-full
Step 7: Initialize rosdep
1
sudo rosdep init
1
rosdep update
Step 8: Setting up the ROS environment variables
1
echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc
1
source ~/.bashrc
Step 9: Create and initialize the catkin workspace
1
mkdir -p ~/catkin_workspace/src
1
cd catkin_workspace/src
1
catkin_init_workspace
1
cd ~/catkin_workspace/
1
catkin_make
Step 10: Add the catkin_workspace to your ROS environment
1
source ~/catkin_workspace/devel/setup.bash
1
echosource ~/catkin_workspace/devel/setup.bash>> ~/.bashrc
Step 11: Check the ROS environment variables
1
export | grep ROS
Check the ROS installation
  1. Open a new terminal and type: roscore
  2. Open a new terminal and type: rosrun turtlesim turtlesim_node
