All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
Does anyone else routinely reply to comments by: {type reply in text entry box below the comment; post reply; select-copy reply text; delete comment; click tiny gray-on-black "reply" link; paste copied reply; reply} ?
https://hackaday.io/profile won't let me save the profile if there is no Twitter link. Yes, that's correct, there is none, I never had any, and will never have it, either.
It would be nice to be able to remove it, or leave it empty. Hopefully, just a GitHub profile would be sufficient.
I'll check that for you, maybe something is stuck. Thanks for also reminding me we need to update it to X... :(
Is there a way for me to clear out "ghost followers" on some of my projects, or if that's not possible, reset the follower count to 0? (and then the ones that actually want to follow the project can re-follow)
I get a notification when a user follows, and usually the follow:like ratio is roughly 1:1. However, some of my projects have hundreds of followers that I've never been notified about, despite only have single-digit likes (that I'm always notified about), which makes it seem like these "followers" are either a bug or bots. I looked into some of these followers and they follow projects that have high follow counts, with some where the amount of views == the amount of follows.
How about providing a way to "like" or generally acknowledge a log entry for a followed project? Sometimes I want to simply ding a bell that I've read a new log for a ongoing project and appreciate that my fellow hacker persists at something that's taking more than two weeks. I know I can leave a comment, but a succession of "I appreciate that you're persisting at something that's taking more than two weeks" comments would have progressively decreasing snr vs just a counter to bump.
I can't delete my account because oauth with github is broken. Also I can't change my password because I don't know it because I used Github Oauth
Here's a weird bug: On my page https://hackaday.io/page/11900-costing-assembly-service-for-my-pcb , the links associated with the comments point to a different project e.g. https://hackaday.io/page/11900-koat0-portable-terminal/discussion-190917 However clicking on the link doesn't go to that project but back to the same page, but at the top, not the comment.
Yep looks like a bug on pages comment links, thanks.
It got more bizarre, now it ostensibly points to a different page but still takes one back to the same page. It seems that the website only uses the page ID to reach the destination page and the text after that is ignored. Unfortunately the discussion ID is also dropped so it cannot land on the actual comment.
Hey Hackaday, possibly a niche problem, but I'd love to be able to replace broken image tags in place. Dragging a file over a broken img tag highlights the same as a working image, but dropping the file does nothing. I'd expect it to replace the src of the target element with the uploaded file, but this doesn't happen.
This is because I write my articles externally in markdown, then copy the rendered HTML into the online editor. It works great for text formatting, but with images I currently have to go through every one, copying the alt text, deleting the element, dragging the file into the now vacant spot, and reapplying the alt text. It would be a lot quicker to drag files onto the img tags without recreating them.
Maybe other people aren't writing 7000 word articles with 40 images in them though 😅
The Z80-MBC3 is a DESIGN, an upgraded version with similar characteristics as the other single board computers, including the predecessor : the Z80-MBC2 which has been on Hackaday for more than four years. So there is no argument to exclude an upgraded and modified DESIGN from another user.
As the Z80-MBC2 which also an advertorial for the kits that Just4Fun sells and posted links here on Hackday. He describes it here, on Facebook, on Github, and various other places like : https://shop.mcjohn.it
The italian shop is not mine, nor one from Just4Fun himself. But the Z80-MBC2 ( the older version ) is a commercial product, as any other "kit" is a bundle of components offered for sale with which the buyer can finish it to a usable device. This publication is INFORMATION about the updated and revised design of the older design. Therefore it has INFORMATIVE value to people who are interested in building devices with kits.
Lutetium thinks that there is a principle difference between the Z80-MBC2 and the Z80-MBC3 . There isn't. The latter is simply an updated and enhanced version of the older (MBC2) one.
Which link are you complaining about and is the one that you are rejecting ? I don't see any links in the latest version of my Z80-MBC3 project here. So what do you mean with "link dumpung". Hackaday invites to add a whole range of links, but I did not use these.
I just checked the 'hackerspaces map' (/hackerspaces) here for spaces near Seattle and it seems like half the spaces listed are only user accounts and one points to a broken link. Is there a maintainer for the hackerspaces map?
We don't actively curate the hackerspaces, but they can be removed if reported, do you remember the broken link you found?
Hello Richard thanks for the response.
I emailed back but no response there.
The visits are not me atleast 80% of them.
I do not visit my files online. I edit them local and post them.
85 views ? Also without visiting i can see how many views if im logged on. from all my projects.
These are not me veiwing my files.
Alan
I'm not saying you're wrong, there could be other reasons for the view count.
For example, here is one of my private projects, https://hackaday.io/project/190779 visiting says 'Page not found', but the server still sees the project path was visited.
But it's not other users/accounts viewing your content. They can't see it.
Hello
I have a question about security of private projects. Why do I have 85 views? also the views continually gain in amount slowly.
Hey I see how that looks confusing. It's including your own and any authorized contributors visits across any of the private projects pages. I'll check to see if it can be adjusted to not do that, but we haven't filtered these historically.
I would be nice if some javascript or serverside image scaling was added, most of my pictures taken with my mobile phone (Pixel6pro) is larger then 5MB making it a real hassle to add images to my project, instead of just adding them from my pone I need to get them over to my computer and rescale them. This make me less eager to add pictures at all and I add less pictures, and that is a pity, I assume this would be true for most new phones.
I hope there would be some simple rescale/repack JPG library that you could easily embed in the upload image workflow. If so it would be really helpful. Thanks for the site.
Just install the imageshrink app which is free on your phone. It's also useful for scaling photos to send by other means.
I just wanted to mention a few possible bugs and suggestions/complaints/man-yells-at-cloud.
Possible bugs:
- Under some scenarios, copy and pasting images in to the project log editor will cause the image to appear twice, however once you save the image will appear only once. If you remove the apparent duplicate, no image will appear at all.
- Sometimes when pasting in text, it will paste to the beginning of the editor field, regardless of where my cursor is. Saving as a draft and reopening works around this issue.
- I haven't been able to get the ability to position an image to one side and have text wraparound work at all. It works in the editor preview but once I save that formatting doesn't work and is lost.
Suggestion:
- It seems to only be possible for comments to nest up to three deep. Someone commented on my project > I replied > they replied > no more replies are possible. I could reply to my own initial reply but then I think the order would get mixed up and I'm not sure they would get the notification.
- This isn't a terrific format for feedback since I can't search the other 4500 comments to see if I'm repeating any, or get any reassurance that my issues are real and not just something I'm doing wrong. Also, searching on a search engine doesn't really work because it will always show results of projects on hackaday.io, not anything meta *about* hackaday.io directly.
Is it possible to have a white background? I really struggle with the black
Indeed. For those of us with rather less than perfect vision, the low-contrast grey-on black text is very difficult to read. And in general, for older people with presybopia, screens emitting more light cause the pupil to close slightly, making it easier to focus.
I know that young people with great eyesight love their low-contrast, dark screens; but if you're going to have just one option, it should be one that works for us older folks as well.
(This difficulty in reading the site, BTW, is probably the primary reason I don't follow stuff here much, and why I don't post any of my projects here.)
The default styling for handling vimeo embeds does not work at all. Video in front of text and bad sizing levels of bad. In order to make https://hackaday.io/project/190248/log/219832-prototype-chassis-hilt-fitting work at all, I had to hack together embed code and edit via HTML; the WYSIWYG editor just was not enough to get the job done.
Thanks, I'll look around and see why Vimeo is behaving differently from YouTube.
....Wow, this is an interesting avenue for feedback. Searching requires google with `site:`, and even then, it's a challenge. Some ability to search for discussion threads that contain all keywords would be an improvement.
Great resource! I love the contest- a real stimulation for innovation.
Have you considered a science based one? I am planning on building an openflexure microscope with some pretty sophisticated upgrades. That is just one example. There is a growing movement to open source research/methods/instrumentation.. I can't imagine what people could come up with.
Hi @dot_solutions - There is an 'Edit project' button on the top right of the project page. I've sent you a PM.
Patrick LeBoutillier
This dangerous project should be removed. He will set Halloween costumes on fire. https://hackaday.io/project/192959-programming-propane-espnow-and-walkway-upgrades
