close-circle
3D Printable Robot Arm
A printable robot arm, a little bigger than the usual hobby servo once.
My printable robot arm is inspired by the well known industry robots, but printable.
The goal is to develop a open source robot arm to use in private or small businesses and make robot development available for every one.
The arm should lift about 2 kg enough to perform every day tasks. Currently robot arms are expensive or small and weak, or clumpy.
Industrial robots are expensive and dangerous and for that not suitable for using at home or schools.
A Open Source printable robot can build,used and developed by every one.
Robots are still expensive and hard to operate, but this must not longer be the case.
A cheap 3d printed robot arm could be used by disabled persons to manage their daily needs better and more independent. Operate at dangerous but not so developed places.
Remote controlled you could even us the robot to open your door if you forgot your keys.
The future Arm will include a moving base.
That's where I'm currently heading:
The four robots I build since this project started.
Version 4 now nearly done and in testing.
Take a look at my newest video of my robot arm project, it's also the video for the HackadayPrize semifinals.
Version 4 is now nearly complete:
I also started uploading the files on github:
https://github.com/4ndreas/BetaBots-Robot-Arm-Project
And a components list for version 4:
http://1drv.ms/1NIofNR
  • 1 × Version 4 BOM see the link to the excel file: http://1drv.ms/1NIofNR
  • 1 × 24V - 200 Watts (or more) Power supply
  • 1 × Arduino due + Ramps+FD shield I use this until I have time to design my own shield
  • 5 × suitable stepper motor driver I used TB6560 Stepper Motor Driver Boards
  • Mantis IK in Robot Overlord
    Dan Royer05/10/2016 at 16:35 1 comment
    https://www.instagram.com/p/BFNmSFqofN_/?taken-by=imakerobots
    The link above is a video of the working inverse kinematics. Now I don't have the arm on my desk, so I can't write the firmware that ties the arm to RO. However! RO is ready to connect and talk with Mantis.
    My interest is drifting towards easier ways to move the arm in VR. The more I use RO the more I want to fly like an FPS game and push/pull the virtual model rather than click buttons on the side.
  • Robot Overlord support for Mantis
    Dan Royer05/04/2016 at 19:23 3 comments
    Hello Everybody! Dan Royer here. You may know me from helping such projects as the PancakeBot and the Cypress Umbrella. Glad to be working with @Andreas Hoelldorfer. He's got the hardware and I've got the software, so it will make a good team. Above you see the latest version of Robot Overlord (RO) simulating the Mantis arm. RO is a robot simulation package I've written in Java. Think of it as my One Ring.
    First stage was to port the Inventor models into the system and animate them. The line you see running through the model is the software's mental model of the forward kinematics (FK). The FK informs the rendering engine where to draw the parts of the model AND it lets the software check for illegal/impossible arm moves. FK means "if my joints are at these angles, tell me where is the finger tip."
    Second stage will be to get the inverse kinematics (IK) working. IK is the other direction - "I know where the finger is, tell me where the joint angles need to be." It will be a naive solution full of singularities because I'm only marginally clever (MC). Sigularities are cases where there may be many valid solutions, and picking an answer is hard for a computer.
    Third stage will be firmware to make this arm talk with RO like all MC robots.
    More generally, MC is working on adding Vive VR support and record/playback to RO. That will mean telepresence work, gamification, and more.
    Dan out!
  • I started with a new version called Mantis
    Andreas Hoelldorfer04/13/2016 at 08:11 0 comments
    After version 4 (green) works quite well. I decided to stick with the basic design and improve this version instead of trying another approach.
    I started with the Gripper and will work from top to bottom down the robot arm
    http://chaozlabs.blogspot.com/2016/04/mantis-robot-arm-part-1-gripper.html
    I will post a video about the part and a small article on my blog where all the links and part lists will be.
  • Still here
    Andreas Hoelldorfer02/29/2016 at 17:32 2 comments
    I just posted a update about my 3d printed, 6-axis robot arm project:
  • All in motion
    Andreas Hoelldorfer10/19/2015 at 07:24 5 comments
    All six axis of my robot arm are moving now:
    I build a case for the electronics, nothing special but it will serve the puropse.
  • 3-Axis running and detailed description of the arm.
    Andreas Hoelldorfer10/04/2015 at 09:55 1 comment
  • Working on Version 4 - Progress
    Andreas Hoelldorfer09/24/2015 at 12:47 3 comments
    I use now Nema23 steppers a high power stepper driver and a Arduino Due board with a Ramps-FD shield. I plan to build my own shield but this have to wait a little bit. I defiantly will stick to the Arduino Due. For now the Ramps-FD shield works fine and its quite cheap (25€).
    Currently I'm waiting for the large bearings to arrive, they are not so easy to find. In the meantime I started wiring all up, the cable tubes inside seams to work this time so less ugly cables.
    Everything looks very pomising now I'm very happy with the new design and looking forward to the all in action.
    The only thing left is the rotating base. I try to get the construciton done this weekend.
    I also uploaded step files on github so you can take a look on the arm.
    https://github.com/4ndreas/BetaBots-Robot-Arm-Project/tree/master/Green/step
    Also all other inventor files are online.
    For those who have no CAD I uploaded the robot A360Viewer an online cad viewer:
    http://a360.co/1gQUnjT
    I tried Onshape but it had a problem viewing all the parts???
    I regularly upload pictures in this here:
    https://goo.gl/photos/ZQA8tRJFSAAc8pZQ9
  • Working on version 4
    Andreas Hoelldorfer09/19/2015 at 11:36 6 comments
    Here is my new Video of the robot arm project:
    I also started uploading the cad files on github:
    Still a mess I try to clean it up in the next weeks.
    Andreas Hoelldorfer09/11/2015 at 20:46 9 comments
    I'm working on a new version based on the experience I made with the previous versions.
    The plan is to use stepper motors and timing belt gears.
    The plan is to use a Nema23 stepper for the rotary base,
    Joint one and two will be Nema24 ( this: http://www.omc-stepperonline.com/dual-shaft-cnc-stepper-motor-nema-24-100mm-4nm566-ozin-24hs393008d-p-388.html )
    Joint 3 and 4 Regular Nema17 stepper and for the 5 joint a HerkuleX DRS-0101 .
    But nothing is final now.
    Power supply will be 24V-36V I guess.
  • Still working :)
    Andreas Hoelldorfer08/24/2015 at 14:21 2 comments
    I'm still working on this project ;) but not I've not so much time.
    Im currently working on a new version again with steppers (Nema24) and belt drives.
    I also tried to make my own harmoic drive:
    It didn't worked as I hoped and I spend a lot of time working on it until now but I will close this aproach.
View all 18 project logs
  • 1
    Step 1
    Print all parts and assemble them ;)
View all instructions
Les Hall wrote 02/25/2017 at 20:13 point
Watching your robot move in the video was very inspiring!  I'm working on one too but mine is just vaporware at this time.  Seeing yours work so well got me motivated!
Les
TTN wrote 01/18/2017 at 11:53 point
New and very clever harmonic drive implementation that you may be interested. The video on the page: https://hackaday.com/2017/01/17/3d-printed-strain-wave-gear-needs-your-help/
Lasal wrote 10/25/2016 at 04:21 point
Hi Andreas,
the stl files are not available in git hub for version 4. the folder seems empty
matt.moram wrote 10/24/2016 at 13:54 point
Hi Andreas,
Ive started to build your Version 4 robotic arm, please could you tell me where i can purchase the Non LED and LED encoders.
Also do you have an english version of the BOM
Kind Regards
trevorjtclarke wrote 09/13/2016 at 00:17 point
For anyone here, looks like this project is a derivative of: https://github.com/BCN3D/BCN3D-Moveo, Obviously things are tweaked, but as I was trying to build one myself, a lot of things were left to guess. So heres a link to the main project, which includes docs.
 cheers.
Adam Vadala-Roth wrote 09/13/2016 at 16:22 point
This project was started in 2015, the Moveo was only launched two months ago if I'm not mistaken.
trevorjtclarke wrote 09/13/2016 at 17:24 point
Looks like i was mistaken. BCN took Andreas first design for their use. Its very annoying trying to find the source of truth on this one, since no one is giving appropriate attribution or explanation of history. Thanks for the heads up.
Jarrett wrote 09/13/2016 at 17:35 point
Yeah, this is weird:
https://github.com/BCN3D/BCN3D-Moveo/issues/1
Kind of a dick move
Adam Vadala-Roth wrote 09/13/2016 at 20:09 point
Perhaps we should all post on that github issue until its resolved?
trevorjtclarke wrote 09/13/2016 at 23:54 point
I have added a pull request to acknowledge. Hopefully they rectify soon. Very bummed at the publicity without proper acknowledgments.
Vasily D wrote 08/23/2016 at 18:27 point
Hi Andreas.
You have done great job and I guess a huge amount of try and redo things :)
I am trying to do some similar design, my goal is to hide all motors (step motors for now) inside, make them invisible. I do try to use some planetary gears and keep the motor inside the knee.
And .... meantime I found a great video of KUKA industrial hand.... where, what a surprise, all motors are NOT inside the arm but at the basement... incredible!!!!
YuehChuan wrote 08/03/2016 at 14:03 point
Hello I wonder what is the encoder for Nema stepper? Thanks!
andrew.amos wrote 07/30/2016 at 18:12 point
Hi Has anyone exported the STL files as I don't have Inventor
andrew.amos wrote 08/21/2016 at 15:46 point
Thanks Yueh its a great design started to print a few problems with warping great Job Andreas looking forward to your new design
marekesz wrote 07/29/2016 at 09:29 point
Hi Andreas, Your design is quite impressive. You seam to have the problems with the software thaw. There are some programming platforms for the robots available, but they are too simple (like just few sliders and the timeline to store poses in relation to time nodes), or too complicated (like ROS RobotC or even Arduino solutions). In our  company (link below) we produce tobots for education (hardware) and we've created the software platform to run them. This platform (RobLAB) is inpired by the real - industrial robot software, but it's  dedicated for the education purposes, so it's not related to just one construction (kinematics) - in fact you can define any crazy kinematics you want and controll it the proper way. There's even reverse kinematics for most tipical constructions (Puma, Scara, Delta, Portal) to enable eazy programming and controlling. There are two REAL programming languages implemened - Melfa Basic (of Melfa/Mitsubishi robots) and ISO (G-code) - so if you learn how to program your own robot, you will be able to program the real thing (real industrial robot). There's even the 3D simulation available in the definable environment with the phisics. RobLAB was dedicated to our robot with our proprietarry controller, but we are working on moving to the Arduino platform to give the independent constructors oportunity to actually use their wonderfull constructions the right way. Please, let me know if You're interested in getting the demo version for testing. http://mechatronik.pl/programy-2/oprogramowanie-roblab-detail#filmy-i-foto
andrew.amos wrote 08/21/2016 at 15:47 point
Hello is this software free ?
marekesz wrote 08/24/2016 at 21:22 point
Hi, sorry for the delay (the holidays...).
No, unfortunately it' not free. I've just proposed our newcomming version that we are working on to Andreas to test it as a beta tester.
We are looking for betatesters. To qualify as a candidate, one have to be a good mechanical constructor (one that makes an effort to  construct something more advanced than a hotglued stick robot or have taken the 3D files from the net). So, their projects must be original and interesting. If You are a person like that, You'll have the chance to have the beta version of our program if You are not, soon the full version will be available to purchase or the demo version (with some restrictions like not being able to control the HW objects and some other restrictions) will be available to download.
valerio monticelli wrote 07/26/2016 at 08:51 point
beautiful I decided to build it and I assembled but do not understand that firmware and software used someone I can 'help ?
trevorjtclarke wrote 07/15/2016 at 20:47 point
Hello Andreas! Very excited to see what progress you've made lately!! Any updates?
Eric LeClair wrote 06/22/2016 at 20:44 point
Now this is what I call a real robotic arm! Great job :)
YuehChuan wrote 06/20/2016 at 20:26 point
Hey I'm curious which kind of encoder for Nema motor? thanks!
YuehChuan wrote 06/20/2016 at 20:16 point
Hey Andreas , I found a project for your mobile base. https://linorobot.org   basicly you can facility the ROS community to make Mantis more powerful !
Francesco wrote 06/18/2016 at 18:19 point
Thank you for this amazing project. Anyway do you make available the firmware to get this thing moving?
kk wrote 05/27/2016 at 11:45 point
First of all, deeply thx for sharing the amazing idea. I've been following the project for a long time. Now I'm concentrating on the controlling system. Have you ever considering about the ROS? ROS seems like a popular platform even though the ROS for Industry is still under development.
YuehChuan wrote 06/18/2016 at 01:29 point
Hi there! Thanks Andreas for this project ! u are so amazing  one man can do this job, i also think the suggestion for using ROS is good. Now my team and I going to make this robot also and build  a Rasberry Pi3 base controller with ROS interface for this bot.  I'll tell u if any progress!
tfolbrecht wrote 05/09/2016 at 09:48 point
The quick mount moving part is called a face cam. Awesome work dude!
Peter Walsh wrote 05/12/2016 at 19:16 point
tfolbrecht: I sent you a private message, it should be in your Hackaday.io page. Check the UL corner of your main page for the word-bubble icon.
ahmedrokba wrote 05/25/2016 at 11:27 point
Vielen Dank für deine tollle Arbeit und damit dieses Projekt.
one mobile
one mobile
Sri wrote 04/29/2016 at 06:54 point
Hello Andreas, great job!!!. I would like to print Green robot arm. I'm new to 3d printing, I planning to purchase a 3d printer. Can all parts of green arm be printed on average 3D printer? Can  you please let me know the dimensions of the largest part so I can buy appropriate printer so I can print all parts on the printer.
87102076 wrote 04/23/2016 at 01:29 point
Hallo Andreas,  it is a great job you have done. Thanks for sharing.  How much did you pay for printing ?  Thanks
Thirkell wrote 04/20/2016 at 17:16 point
Great work. I have been following your project closely since the first Blue version. Will you be uploading the Invertor ipt files for the Mantis Gripper?
Keep up the great work.
