IKEA Antonious Basket Frame corner repair
3D print a replacement corner bracket for an Ikea Antonius Wire Frame Basket system.
The corner brackets in the basket model I have are cast from iron and very weak (think cheese metal). You can't buy the brackets as far as I know so the choice was to discard the frame and baskets or print a replacement. It's a very basic print, printed on its side for strength. I emulate the original as closely as possible including the raised retainer but decided to skip the raised lip (which would be a nice aesthetic improvement). I printed it in PLA since this is all I have, it's strong enough and has been in use for over a month without issues.
ikea-corner.stl
STL file for corner bracket
stl-binary - 14.41 kB - 01/31/2018 at 22:57
Download
ikea-corner.scad
OpenSCAD source for corner bracket
scad - 673.00 bytes - 01/31/2018 at 22:57
Download
Alexandre Norman wrote 04/25/2023 at 20:00 point
Beware the furniture was called Antonius and not Antonious.
(for search engine visibility)
