Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Events Hackerspaces Profiles Hackaday.com Tindie Marketplace Remoticon
Sign up Log in
Merciless Pi Alarm Clock
This alarm clock has no pity and can't be fooled - it won't shut up till you get up.
hberg32hberg32
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
6.9k views
4 comments
553 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 14
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
6.9k
4
553
10
Team (1)
  • hberg32hberg32
Join this project's team
hardware
ongoing project
raspberry pi alarm clock
Related lists
Alarm Clocks
Projects to wake you up
Raspberry Pi Projects
Projects based on everyone's favorite low cost Linux Machine - The Raspberry Pi
This project was created on 03/25/2015 and last updated 6 years ago.
Description
Here are the things that set this apart from your typical alarm clock:
1. A bed shaker under the mattress (from an alarm clock for the deaf/hard of hearing) adds vibration to the alarm. Put your bed on vibrate.
2. A pressure sensor from a patient fall alarm is used to sense whether you are in or out of bed. The alarm won't stop till you vacate the bed.
3. The snooze button only gives you 3 snoozes (programmable). Push the button all you like after that, it doesn't care.
4. The clock continues to monitor the pressure sensor for the next hour and sounds the alarm if you get back in bed. No backsliding.
5. Uses a Raspberry Pi with WiFi and an RTC module with a battery backup so the time will always be correct even if there is a power failure or daylight savings time switch during the night.
Files
pialarm_-_ponoko_2.svg
Laser cut file for the enclosure. I had ponoko.com do the cut using veneered MDF with a thickness of 5.7mm. Veneered MDF looks great after staining and a coat of polyurethane.
svg+xml - 597.68 kB - 03/30/2017 at 00:10
Download
pialarm_-_lens.svg
This is for the diffuser to fit into the window over the LCD. I used gray tinted acrylic 3mm thick.
svg+xml - 664.30 kB - 03/30/2017 at 00:10
Download
PiAlarm.fzz
Circuit diagram
fzz - 108.24 kB - 03/30/2017 at 00:09
Download
Components
  • 1 × Patient alarm pressure sensor pad I got mine from eBay but there are many others. They look like this: http://www.medline.com/jump/product/x/Z05-PF11969
  • 1 × Sonic Alert Super Shaker http://www.amazon.com/Sonic-Alert-Super-Shaker-Vibrator/dp/B003E6HORE/ref=sr_1_17?s=hpc&ie=UTF8&qid=1427274082&sr=1-17
  • 1 × Raspberry Pi B+ The B+ has FAR less noise and pop than the B. The Pi 2 is presumably the same
  • 1 × DS1307 Real Time Clock with battery backup Keeps the time when the power is off
  • 1 × 1.2" Adafruit 7 segment LED clock display No glasses, no problem
View all 14 components
Project Logs
Collapse logs
  • Finish filling out this project description and profile
    hberg32 • 03/25/2015 at 10:01 • 0 comments
    Just getting started, here.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Ethan Crow wrote 03/13/2017 at 16:30 • point
Can you make instructions?  Also can you post the design you used for the enclosure
hberg32 wrote 03/30/2017 at 00:08 • point
Hi - just saw your message.  What kind of information are you looking for?  I've added a Fritzing file of the circuit schematic and will post the source code as well (it's not fancy).  I've lost my original inkscape design files for the enclosure but I've posted the files I sent off to ponoko.com for laser cutting.  The only real trick to the enclosure design was the use of the "Tabbed Box Maker" plugin for inkscape.  That lets you enter the dimensions of a box and it will draw the sides for you.  After that I just added cut lines for the various holes.  The "lens" file is for cutting a piece of acrylic to use as a diffuser in the LCD display window.  Laser cut pieces are tight enough that the diffuser doesn't even need a mounting, you just press it in and friction will hold it securely.
Andrew Lee wrote 09/21/2016 at 23:25 • point
Can you please explain how you managed to connect the Sonic Bed Vibrator to the Pi peripherals?
Paul Leskinen wrote 03/30/2015 at 11:56 • point
Love this idea. Having a daughter who's a sophomore in high school whom I often find in bed 5 minutes before it's time to leave, the "no backsliding" feature is fantastic.
It is a smart clock that can show time and tell time in voice and also change color according to time.
Project Owner Contributor
pi smart talking clock
Ashwini kumar sinhaAshwini kumar sinha
Not a bomb.
GPS controlled FischerTechnik Clock
Jac GoudsmitJac Goudsmit
A clock for our Personal Economic Offerings to the Nation
PEON Clock
Daniel DomínguezDaniel Domínguez
A front cover for a classic word alarm clock with touch interface.
Word Alarm Clock with a Touch
CFCF
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Merciless Pi Alarm Clock", please tell us the reason.
Send message
Remove Member
