Hackaday.io Hackaday.io
Sign up Log in
Multibot3d
A delta-style circular 3D printer with an infinitely extendable number of extruders.
jenjhall1jenjhall1
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
11 comments
2 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 11
View Gallery
983
11
2
5
Team (2)
  • jenjhall1jenjhall1
  • krzysztofKrzysztof
Join this project's team
hardware
ongoing project
3d printers Independent extruders 3d extruders Non-cartesian Full Color Multiple materials delta smoothie SMOOTHIEWARE CMYK glass Porcelain Bone china Sintered
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 02/12/2018 and last updated 8 years ago.
Description
This is the very beginning of the development of the Multibot3d. This five extruder model could print in cyan, magenta, yellow, black and white. Multimaterials could be used. It could be made with a larger circle and accommodate six, seven, eight, to infinite numbers of extruders. So far, thoughts of integrating a Smoothie v2 board to drive five extruders are being developed. Collaborators are being sought.
Files
1375750610340351383.mp4
Shows the maximum reach. The most stable reach would be closest to the edge.
MPEG-4 Video - 8.16 MB - 02/17/2018 at 11:06
Download
Project Logs
Collapse
  • Feedback encouraged
    jenjhall1 • 02/12/2018 at 16:10 • 0 comments
    Just getting started. Would love input.
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
jenjhall1 wrote 02/17/2018 at 10:19 • point
Thanks @krzysztof especially for the DaVinci link. I’m really not thinking about applying ink to to anything at this point though. I have considered using a translucent glass powder in CMYK. This could be printed in a bed of refractory support material and then fired in a kiln. Porcelain and bone china could also be done like this. Do you think that the 90 degree turned Y shape that you describe would have enough reach inward for smaller or more complex shapes?
Krzysztof wrote 02/17/2018 at 15:05 • point
I suggested it because it could easily reach into center, you don't need more. It's just a matter of rail height.  Try drawing it on paper in different positions. Unfortunately with this setup max print height will be approximately half of printer height at biggest distances from center (and almost full height at center). Also I used small letter 'y' on purpose.
jenjhall1 wrote 02/16/2018 at 22:42 • point
@krzysztof that does sound like a more manageable approach. I was letting my thoughts run wild and was thinking that I might see if I could print the inside of an object white and then use four extruders for a cmyk dot printing as if I were using a color cartridge. Anybody here know how to do that?
Krzysztof wrote 02/17/2018 at 07:31 • point
For color you would need mixing extruder (http://www.reprap.org/wiki/Diamond_Hotend). It's very hard to do this with different extruders. You could of course have printer cartridge instead of one extruder but this has been already done and effects are not that good. Using single extruders for this will have even worse effect, because you will have too small resolution, 0.2 at best but this will be very hard to control accurately (severe stringing with such short extrusions).
jenjhall1 wrote 02/17/2018 at 08:01 • point
hmmm. I understand. But I don’t like thinking that something can’t be done. The powder based systems are getting pretty good color. Perhaps looking into a material that needs to be sintered afterward would be the way to go. But that particular idea can be tabled until the arms are operational.
jenjhall1 wrote 02/17/2018 at 08:50 • point
Another issue with using 3 color as a building material is the inability to add black and white. On paper you have a white background so there is no issue with its lack. There is a separate black cartridge which the software substitutes when the cmy reaches a certain threshold. Otherwise the print looks muddy. So I don’t see where the diamond hotend could be utilized for full color on its own.
Krzysztof wrote 02/17/2018 at 09:27 • point
It's not like it can't be done, but was already done and effects of printing ink over plastic were ratther poor. Maybe you can do something with this, better method is yet to be invented, I'm just giving you ways things were done poorly. As for printing ink over plastic: https://www.xyzprinting.com/en-US/product/da-vinci-color I've seen early versions, latest seem rather good.
Krzysztof wrote 02/16/2018 at 21:13 • point
If you want to have rotating build plate, I suggest only Z/R movement for each extruder (Z - vertically, R - radially). This will use only 2 steppers for each arm. This could be done with two sliders on two parallel rails (so that they don't rotate), upper slider would have longer arm and lower slider would support upper arm with shorter arm connected in middle of upper one (think letter 'y', but rotated 90deg CCW). Build plate could be rotated from outside.
jenjhall1 wrote 02/16/2018 at 13:32 • point
I would like to develop this concept into a functioning 3d printer. Would anyone out there be interested in collaborating? The picture shows the armature reaching all the way across just to demonstrate that it could. I am more interested in developing a build plate that rotates to the active tool so that they will always be operating in their most stable range.
deʃhipu wrote 02/15/2018 at 11:24 • point
Interesting design, though the working area is in the worst part of the delta's reach in this case, where you have the largest errors — I hope this can be compensated with the large vertical travel of the arms.
I wonder if a similar design could be useful for a pick-and-place machine.
jenjhall1 wrote 02/15/2018 at 16:27 • point
Yes. In the model I was trying to demonstrate that the arm could reach across if necessary. However I’m also considering having a rotating build plate that can turn with the tool change to keep the active extruder in its most stable range. I’m pretty new so all thoughts and contributions are welcome. I need to read more about pick-and-place technology.
This device converts your fdm printer to a full color powder printer.
Project Owner Contributor
ColorPod full color 3d printing
aadAad
The 2018 Hackaday Prize
How a silly mistake led to a 3D printed part.
A stand for my multimeter again
matthias-kesenheimerMatthias Kesenheimer
A footprint and 3d model for KiCad that can be used to get a grasp of the scale of your board.
The KiCad Banana Footprint - For Scale!
arturo182arturo182
Replacement Kerf Boards for a Makita chop saw
Makita Kerf Board
carter-clacksonCarter Clackson
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Multibot3d", please tell us the reason.
Send message
Remove Member
