Triangle Stand
Keep your triangle standing! I built a new stand for a triangle in band that is comfortable to use, and 3D printable.
I am a band nerd, and I wanted to create something that every band could use. After school, I went down to the band room and asked my band director, Mr. Nguyen, if he ever had any problems in band (due to lack of equipment). He told me that the biggest problem for him was the stand for the triangle. It would constantly spin around, making it hard to strike, and silence. The current configuration (<a target="_blank" rel="noopener noreferrer" href="https://www.amazon.com/Sabian-61122-Triangle-clip/dp/B000EENI4W/ref=sr_1_7?s=musical-instruments&amp;ie=UTF8&amp;qid=1518491326&amp;sr=1-7&amp;keywords=triangle+stand+instrument">https://www.amazon.com/Sabian-61122-Triangle-clip/dp/B000EENI4W/ref=sr_1_7?s=musical-instruments&amp;ie=UTF8&amp;qid=1518491326&amp;sr=1-7&amp;keywords=triangle+stand+instrument</a>) was a string tying the triangle to a clip, that you would attach to a stand. I decided to 3D design a new stand for the triangle. I wanted something that supported the triangle in two pla
I started by doing some research online. I found a bunch of stands similar to to our current configuration, but ended up stumbling across something similar to what I wanted to design. I found a cheap one for $15 (https://www.amazon.com/ammoon-Triangle-Percussion-Teaching-Instrument/dp/B0734YX94K/ref=sr_1_1_sspa?s=musical-instruments&ie=UTF8&qid=1518491501&sr=1-1-spons&keywords=triangle+stand+instrument&psc=1), and a nice one for $100 (https://www.amazon.com/goldon-triangle-wooden-stand-japan/dp/B00CE42OS6/ref=sr_1_18?ie=UTF8&qid=1518491204&sr=8-18&keywords=triangle+stand+instrument). Both options seemed a bit pricey. I took the measurements of the triangle, and began designing. (NOTE: the captions describing each image are located beneath the image.)
To start, I built a triangle, matching the dimensions of the real thing. I then added a frame around the triangle (as an outline for the stand).
 I then proceeded to shorten the height of the stand, and cut out the top (so that the triangle can be struck and silenced with ease). I made sure to keep two overhands that will be used as hooks to hold the triangle with fishing line in two places.
I then cut out the holes that the fishing line will be tied into.
I then began adding a slanted edge, used to add extra rigidity and style.
As of now, I have the frame built, but not a way for it to stand up.
I decided to do something like the feet of a box fan.
I sketched the feet out, basing them of the feet of the box fan.
Now that I had the feet, I wanted more surface area underneath, and more structural support horizontally.
I added a base to fix this. Now it is ready to print.
I put it into Cura, and it was twice as big as it should have been. (this happened because I started with center lines in Solid Works, so I was putting in the measurement of the whole line, where I should have bean putting in the measurement for half of the line.)
I used Cura to scale the stand down by half.
Now it was ready to print. Since it was my first attempt, I only used 6% infill. I also printed it upright.
finp
 But the stress from the strikes on the triangle where to much. I also realized that printing it upright created a ton of week spots.
The print, however, failed. The print started to cool half way through, and made a huge mess of ABS plastic. I used the failed print to check that the stand would be strong enough. It was definitely strong enough for it's purpose. I had four failed prints like this, so I decided to redesign the whole thing, so that it came in separate pieces. Making it like this would also make it so that you could print it on much smaller printers.
To start, I began remaking the base, this time I made it the correct size.
I tried to make it as close to the original as possible, so that I was not starting completely from scratch.
I sketched out and extruded the slots for the arms to slide into.
I did the same on the other side.
I added the slanted sides.
I did this to both sides, and added some designs, for decoration.
I opened the original stand back up in Solid Works, and cut out the base, so that I only had the two arms left. I then cut out one of the other arms so that I had one arm left.
I scaled the measurements of the old arm down by half.
After that, I sketched and extruded the outline of the arm (reduced by 50%).
I added the tie in point, and got rid of the larger arm.
I set it up in Cura (two triangle stand arms, and one base), and printed. I used ABS plastic, and set my infill to 50%.
triangle stand arm.SLDPRT
This is the solid part for the arms of the triangle stand.
sldprt - 182.75 kB - 02/19/2018 at 18:35
Download
triangle stand arm.STL
This is the STL for the arms of the triangle stand.
Standard Tesselated Geometry - 9.07 kB - 02/19/2018 at 18:35
Download
triangle base.SLDPRT
This is the solid part for the base of the triangle stand.
sldprt - 143.63 kB - 02/19/2018 at 01:34
Download
triangle base.STL
This is the STL for the base of the triangle stand.
Standard Tesselated Geometry - 16.68 kB - 02/19/2018 at 01:34
Download
  • 1
    Print Settings
    I would recommend using ABS plastic for its strength.
    Layer height (mm): 0.25
    Shell thickness (mm): 1.0
    Fill density: 50%
  • 2
    Building Stand
    Lightly sand the base of the arms for the stand about 1 centimeter up, creating a rough surface. Put a layer of epoxy on the sanded area of the arms, and slide into the slots on the stand. Let the glue dry for 24 hrs before installing the triangle.
  • 3
    Installing triangle
    Use fishing line to tie the corners of the triangle to the holes at the top of the arms.
View all 3 instructions
