Lost your mouse battery lid? Here's how I took care of mine...
This technique of putting an item on the scanner can be a much faster way to design an object than to break out the calipers.
Thanks for walking through your technique, this is a really great trick! I've seen the scanner trick used in reverse-engineering PCBs before (remove all the components and then can the bare board) but hadn't considered it for modeling replacemnt parts. Neat!
Cool I use exactly the same trick. Usually scan a ruler with the object and use that to get my dimensions right.
