SMT to DIP Breakout Boards
Eagle files used to convert SMT chips to DIP format for use in breadboard prototyping.
I wanted some open source hardware breakout boards that I could use for my projects. So far I've made the following boards. If you have ideas for others, drop me a comment.
  • QFN28 - 3mm
  • QFN32 - TQFP32
  • QFN44 - TQFP44
  • SOIC8 - TSSOP8
  • SOIC12 - TSSOP12
  • SOIC14 - TSSOP14
  • SOIC16 - TSSOP16
  • SOIC20 - TSSOP20
  • SOIC28 - TSSOP28
  • SOT23-3 - SOT23-6
  • SOT89
  • SOT223
  • DPAK
  • 1206 and 1206W (good for SMT PTC fuses)
I want to give Adafruit a nod for the inspiration. If you just need a quick fix for a couple of boards and don't want to deal with the lead time for fabrication, their shop is a good place to go.
  • Added some new boards
    Kevin Neubauer09/26/2015 at 00:47 0 comments
    TO252 / DPAK
    1206 and 1206W
    Check out the GitHub repo.
  • Next Revision
    Kevin Neubauer07/07/2015 at 02:19 0 comments
    Based on the units I received from DirtyPCBs, I narrowed several boards by 0.1" and made several silk screen modifications. I also dropped the version stamp from the file names and the board. I figured for boards this simple, the versioning was more of a PITA than it was worth.
  • First DirtyPCB Fab Received
    Kevin Neubauer06/15/2015 at 20:20 0 comments
    Received back my first fab of some of the boards from DirtyPCB. Looks like I have several silk screen issues to work.
    Sorry for the lighting glare. My workbench is in a basement and in order to get a legible photo I have to put a light right beside the PCB.
  • Silk Issue & SOT23
    Kevin Neubauer06/09/2015 at 02:49 0 comments
    Fixed a silkscreen issue with QFN32-TQFP32 and added SOT23-3 - SOT23-6 board.
  • Panel Design Help?
    Kevin Neubauer05/28/2015 at 02:31 3 comments
    If you have some experience with Eagle and would be willing to spend some time putting together 5cm x 5cm and 10cm x 10cm panel BRD files for DirtyPCB fabrication, I would much appreciate the help. Drop me a comment here.
  • Renamed QFN-28 Boards
    Kevin Neubauer05/28/2015 at 02:21 0 comments
    My current QFN-28 boards are designed with 3mm QFN-28 chips. If you have a QFN-28 that is a different size, it will not work with these boards. I have renamed the files to include this info.
View all 6 project logs
Kevin Neubauer wrote 06/16/2015 at 19:32 point
Interesting idea. Do you have a how-to or a website that shows this process?
motion wrote 06/15/2015 at 23:02 point
could be very useful when, for instance, upgrading diskrom in a old commodore drive aswell
