The box would include LED lightning and ventilation.
It would regulate the temperature, humidity and it may filter out any smells.
The aim is to make it as autonomous as it can get!
The main controller would be an ESP8266 in the form of the nodeMCU platform.
Domen
I decided to also buy salad seeds, so I would grow salad and beans in parallel under different lights. But I will start working on that over the weekend or maybe even later. School stuff to do ... To bad right?
The nutrient solution is the same as always, 50% strength of the root stimulator and 50% strength of the plant food. I lowered the pH with Sodium bisulfate, which is from the pH minus chemical for use with pool maintenance.
Although I would recommend you get slightly thicker wire, because I can still tear this wire apart fairly easily with my hands and that's why I have to use more wires in parallel.
Em
sadhana
morgan
justin
Oh its a great creation I never watched this type of idea before I will suggest you to carry on working on this amazing idea. I am also working on topgrinderguide project that has some interesting topics you can see here
