Contra-rotating propellers are nothing new - they've been around for decades. Most require a gear box between engine and propellers using two shafts (typically one inside the other) rotating in opposite directions.
This take uses a single feed shaft. Rotation is divided between clockwise and counter-clockwise in the hub between the two propeller planes. The gear system is a modified planetary transmission -- very simple. It uses spherical geometry rather than traditions cylindrical-type gears.
I have coupled it to an O.S. Engines LA-40 glow engine (0.40 C.I.) to show it can be used by RC aircraft.
I know how to make it variable pitch, but won't do that until I have finished prototyping the fixed-pitch version. I'm hoping to control pitch using a single SG-90 servo.
I am tying to make as much of it as possible out of printed parts. I will shortly put the models of all the parts up for download at www.ranachy.org
I'd really like to make (or help someone make) a quad-rotor that utilized contra-rotation using electric motors or glow-engines.
I modeled it in SolidWorks -- including the awesome animation linked on this page.
Ranarchy
Christine Nievaard
ITman496
Jason Dorie
Sean Hodgins
This looks very intriguing. I'm looking forward to seeing the models up on the website
