Modified Neon Light Bulb Tester
$10 neon tube tester with modified 4x 9v dc battery power supply, modified antenna, + circuit bent bug zapper, with 2x 3.7 liion batteries.
Suppose to emit an "EMP" what ever it may be, it was a 555 timer circuit connected to a coil pack nothing two fancy or powerful the 555 covered the pulsed part and the electromagnetic energy was emitted threw the antenna boosted buy the coil pack.
Coye Knoll wrote 10/12/2017 at 17:43 point
i feel ya man step up or down?
Coye Knoll wrote 10/12/2017 at 18:40 point
because once the primary magnetic field induces into the secondary coil windings Kaboom
Ghost wrote 05/09/2016 at 23:44 point
do you thing its legal device
lantramnamcodon wrote 07/03/2016 at 11:35 point
are you kidding me?is the gun is legal in America?the important is what do you use it for and also depend will you be catching or not.
Coye Knoll wrote 10/12/2017 at 18:34 point
Take a piece of wire, bend it in such a way and stick directly into a wall outlet, for this is how simplistic something can be to cause such "Radio" interference of an undesired type. is that piece of wire a "legal" device? Who is a man, to state and put forth and limit the ability of another man.
Coye Knoll wrote 10/12/2017 at 18:37 point
call for back up
Coye Knoll wrote 09/20/2015 at 20:53 point
I keep getting zapped,
ZMOM1031 wrote 09/19/2015 at 08:28 point
This project is cool
Why not step?
