HackBerry PI was born as just a break-out for Soft-Propeller, but well it can do bit more than just being simple breakout.
Features
- Form factor as RPi B+
- does fit into RPi enclosure
- same mounting holes
- same 40 PIn header
- same place microUSB connector
- can work with RPi HAT's
- DIP40 socket: Accept Parallax Propeller DIP40 or Soft-Propeller
- PMod located at about the HDMI connector (accessible from the enclosure)
- 26 Pin header RPi Model A layout
- Arduino compatible headers (location not board outline)
- DIPSY DIP8 Socket
Antti Lukats
Andrew Mitz
MaBe42
Cliffweb03
