I designed this USB hub to be generally user friendly. That means no soldering or hacking, just a clean plug-n-play solution. The idea is that with everyone jumping on the Pi Zero band-wagon(myself included), there is going to be a large range of users; some of which are not going to be as familiar with certain things like soldering and wiring. I wanted a solution that would work for everyone.
Now availble on Tindie! https://www.tindie.com/products/idlehandsdev/piangle-plug-n-play-raspberry-pi-zero-usb-hub/
Sean Hodgins
julien
Teemu Hakala
Hey Mr. KiCad user, would be cool if you could add a PDF for your schematics as well :) I was able to open it with my KiCad, but had to click through some errors. Thanks for sharing all the stuff though :)
