Adobe Portable Document Format - 9.85 MB - 05/03/2016 at 00:34
Adobe Portable Document Format - 24.92 MB - 05/02/2016 at 23:10
# http://www.ibiblio.org/apollo/hrst/archive/1689.pdf # pg. 4-5 memory = range(00, 010000) bank = range(00, 010) super_bank_bit = 0 # Memory adressing # http://www.ibiblio.org/apollo/NARA-SW/E-2052.pdf # Section 1.1.2 paragraph 2 #Flip-Flop Registers A = 00 L = 01 # also channel 01 Q = 02 # also channel 02 EB = 03 # erasable bank register FB = 04 # fixed bank register Z = 05 BB = 06 # both bank registers __ = 07 # zeroes # 2040 words of eraseable ARUPT = 010 # xRUPT = storage for x LRUPT = 011 # during interrupt QRUPT = 012 # ZRUPT + BRUPT stored spare1 = 013 # automatically. spare2 = 014 ZRUPT = 015 BBRUPT = 016 BRUPT = 017 # (RIP) CYR = 020 # cycle right 1 bit SR = 021 # shift right 1 bit CYL = 022 # cycle left 1 bit EDOP = 023 # edit (polish) OpCode counters = range(024, 060) unswitched_eraseable = range(060, 01400) switched_E_3 = range(01400, 02000) switched_E_4 = range(02000, 02400) switched_E_5 = range(02400, 03000) switched_E_6 = range(03000, 03400) switched_E_8 = range(03400, 04000) fixed_fixed_02 = range(04000, 06000) fixed_fixed_03 = range(06000, 010000) # Fixed memory is a “read only” memory. The programmer may not alter the contents # of any location in fixed memory, and in fact the hardware will not permit it. # http://www.ibiblio.org/apollo/NARA-SW/E-2052.pdf Section 1.1.4 common_fixed_00 = range(010000, 012000) common_fixed_01 = range(012000, 014000) common_fixed_04 = range(020000, 022000) common_fixed_05 = range(022000, 024000) common_fixed_06 = range(024000, 026000) common_fixed_07 = range(026000, 030000) common_fixed_10 = range(030000, 032000) common_fixed_11 = range(032000, 034000) common_fixed_12 = range(034000, 036000) common_fixed_13 = range(036000, 040000) common_fixed_14 = range(040000, 042000) common_fixed_15 = range(042000, 044000) common_fixed_16 = range(044000, 046000) common_fixed_17 = range(046000, 050000) common_fixed_20 = range(050000, 052000) common_fixed_21 = range(052000, 054000) common_fixed_22 = range(054000, 056000) common_fixed_23 = range(056000, 060000) common_fixed_24 = range(060000, 062000) common_fixed_25 = range(062000, 064000) common_fixed_26 = range(064000, 066000) common_fixed_27 = range(066000, 070000) super_bank_0_30 = range(070000, 072000) super_bank_0_31 = range(072000, 074000) super_bank_0_32 = range(074000, 076000) super_bank_0_33 = range(076000, 0100000) super_bank_0_34 = range(0100000, 0102000) super_bank_0_35 = range(0102000, 0104000) super_bank_0_36 = range(0104000, 0106000) super_bank_0_37 = range(0106000, 0110000) super_bank_1_30 = range(0110000, 0112000) super_bank_1_31 = range(0112000, 0114000) super_bank_1_32 = range(0114000, 0116000) super_bank_1_34 = range(0116000, 0120000)
View all 3 project logs
3.625KiB RAM? - Double check these
19Kib ROM
2KiB per Cog
31.25Kib RAM
31.25Kib ROM
wglasford
Bruce Land
Tim
Yann Guidon / YGDES
Yes, delete it Cancel
You are about to report the project "YUL", please tell us the reason.
19Kib ROM
2KiB per Cog
31.25Kib RAM
31.25Kib ROM
