IR Light Dimmer v2
IR Remote Light Dimmer v2 - installed instead of wall switch!
PROJECT PUBLISHED HERE: <a href="https://hackaday.io/project/19221-ir-light-dimmer-v2-1kb-challenge-edition" target="_blank">https://hackaday.io/project/19221-ir-light-dimmer-v2-1kb-challenge-edition</a> Plan is to make a second version of my most popular project: IR Light Dimmer, that can be found here: <a href="http://www.elektronika.ba/617/ir-light-dimmer-v1/" target="_blank">http://www.elektronika.ba/617/ir-light-dimmer-v1/</a> This version should be much easier to install, without need of a neutral line. This means that it can be installed simply by replacing a wall switch!
PROJECT PUBLISHED HERE: https://hackaday.io/project/19221-ir-light-dimmer-v2-1kb-challenge-edition
Found capacitive power supply and triac triggering ideas here:
http://www.st.com/content/ccc/resource/technical/document/application_note/a8/00/35/e2/62/e5/4c/14/CD00266635.pdf/files/CD00266635.pdf/jcr:content/translations/en.CD00266635.pdf
  • 1 × PIC12F629 or PIC12F675
  • 1 × TSOP IR receiver
  • 10 × Misc components
View all 3 project logs
