DIY Inkjet Head
This is my attempt to build a simple inkjet head that everyone can build at home.
This is a toolhead for printing many sorts of fluids like binder, ink and almost all fluids with low viscosity. In this configuration you can print ink on paper with your Ender 3, but the printhead should also be suitable for other applications like binder jetting or labeling.
Here is a test of the Toolhead.
This is my attempt to build an open source inkjet printhead by myself. I started this project because I wanted to build a binder jetting 3D printer but could not find any open source inkjet printhead for this. So I started trying to build one.
The toolhead is a DIY Piezo Printhead inspired by https://reprap.org/forum/read.php?153,52959,page=1 and https://reprap.org/wiki/Reprappable-inkjet.
It's controlled via a L298N H-Bridge and PWM from the 3D printer. The printhead runs on 36V DC and the puls is created by an Arduino Uno.
The first test was engraving / printing the rose made with Estlcam. The second test was Bob Marley as dot matrix with Pixels to Gcode on 80g/m² paper which seems to be too thin. Today I tryed with 120g/m² paper and it works way better. Pictures and more tests with dot matrix will follow.
Standard Tesselated Geometry - 121.18 kB - 09/03/2019 at 01:13
Download
Standard Tesselated Geometry - 79.18 kB - 09/03/2019 at 01:13
Download
Standard Tesselated Geometry - 50.67 kB - 09/03/2019 at 01:13
Download
Standard Tesselated Geometry - 45.98 kB - 09/03/2019 at 01:13
Download
Standard Tesselated Geometry - 50.38 kB - 09/03/2019 at 01:13
Download
View all 7 files
  • 1 × Acrylic Block 40x40x20mm
  • 1 × 27mm Piezo Disc
  • 22 × M5x8 Screws
  • 10 × 2020 Corner Bracket
  • 4 × M3x30 Screws
View all 34 components
  • Testing the controller
    Dominik Meffert9 hours ago 0 comments
    For the 9 nozzle printhead I want to use the Ramps 1.4 + Arduino Mega 2560 as controller too but the M106 command supports only 3 "fans" at the moment.
    So I used the I2C connection to connect an Arduino UNO which drives the LEDs and later the L298N H-bridges. The same UNO can create the H-bridge direction change too.
  • Toolhead with 9 Nozzles and Python Script
    Dominik Mefferta day ago 0 comments
    I think it should be better to start with multiple printheads in a row instead of a matrix. So I printed 9 separate printheads which are individually assembled and then bolted together. The 3D printed parts are only for fit checks.
    With the new toolhead the printing process should be faster because with 9 nozzles in a row every printhead must only print the space between two nozzles.
    I have written a Python Script for post processing the gcode from Matthew Rayfields Pixels to Gcode.
    The gray stripes show the printhead area.
    The red dots show the xy coordinates on the paper.
    The blue dots show the gcode coordinates which are executed by the printer.
    The graphic is created by the matplotlib - library.
    The next step will be testing the electronics for 9 printheads.
  • Further Plans
    Dominik Meffert09/09/2019 at 00:04 0 comments
    The next thing I want to try is a new toolhead with 8 nozzles and 8 piezo discs.
    With that I want to test printing with 8 nozzles at once at different locations of the picture and maybe CMYK printing.
    I think, it will take a while until I can test printing with multiple printheads, because I will need a different printer assemby and a software for creating the gcode.
  • Testing
    Dominik Meffert09/08/2019 at 22:26 0 comments
    The first test was printing a vector graphic with Estlcam.
    In this test I started the piezo, printed the line and turned off the piezo.
    In the next tests I tried printing dot matrices with Pixels to Gcode by Matthew Rayfield on 80g/m² paper.
    It seems that 80g/m² paper is too thin for the drop size, so I switched to 120g/m² paper.
    I think, I will stay on the dot matrix methode, but try to improve the printing speed.
  • Ender 3 Mod
    Dominik Meffert09/08/2019 at 17:55 0 comments
    After I got the printhead to work, I bought a Ender 3 Pro because it's not expensive and can be easily modified to test controlling the printhead by gcode and working with it. So I removed all parts which were not needed, like the Z axis, the hotend and the extruder motor. To get a free pin for pwm control on the Ender 3 the Pin 27 Board is needed. With the 3D printed parts the printhead and printhead electronics are mounted. Also the Z axis is locked in place with 3D printed parts. The printhead electronics are powered by a 36V DC power supply. 36V goes to the L298N and LM2596 which converts it down to 5V which powers the Arduino and the logic side of the L298N (The jumper must be removed if the voltage exceed 12V). Digital pin6 and pin7 of the Arduino are connected to the logic input of output B on the L298N. The GND pin of the Pin27 Board is connected to the GND Wago 221 and Pin27 is connected to enable B on the L298N. The piezo disc is connected to output B of the L298N. The Arduino continous switches the "direction" of the piezo "forwards" and "backwards". In the Arduino sketch the time between the direction changes can be set. It seems like one pulse must be longer than the other e.g. pulse1 = 50ms  pulse2 = 2ms. I flashed the latest Marlin firmware on the Ender 3 and added the pin27 as fan 1 like here http://marlinfw.org/docs/configuration/laser_spindle.html. Then the piezo can be started with M106 P1 S255 and stopped with M106 P1 S0.
  • How it started
    Dominik Meffert09/08/2019 at 12:36 0 comments
    I started this project because I wanted to build a binder jetting 3D printer like https://hackaday.io/project/86954-oasis-3dp, but with a selfbuild printhead. So I started building my printhead based on https://reprap.org/forum/read.php?153,52959,page=1 and https://reprap.org/wiki/Reprappable-inkjet.
    First I build the Reprapple-Inkjet design, but with an acrylic block for the "fluid chamber" instead of a 3D printed part.
    Later I changed from the transformer to a H-bridge and added the upper connection for flushing the air out.
    After that I tryied to build a pressure control system based on load cells to keep the pressure stable when the fluid level in the tank gets lower, but I figured out that it was not precise enought to work.
    In the future I will test pressure sensors to see if these work for controlling the pressure. Until then the systen with the stand works reliable for hours bevore the fluid level is too low.
View all 6 project logs
PropellerGraph wrote 09/12/2019 at 03:48 point
I like how this has gone full-circle--using a 3D printer to make a 2D printer! The dot-matrix prints almost look like pointillist paintings!
Dan Maloney wrote 09/06/2019 at 17:50 point
Reminds me a little of the inkjet heads used to print on packaging as it goes down a conveyor. Even sounds a little like it.
Krzysztof wrote 09/03/2019 at 17:40 point
Nice! Have you considered using mobile phone speakers?
Dominik Meffert wrote 09/03/2019 at 20:34 point
Thank you.
Not yet, maybe in the future for a smaller toolhead.
