[H6X POD] Overview
follow along on Instagram: https://www.instagram.com/zen.diy/
GitHub Code: https://github.com/lennypane89/H6X
Features
- 2x High-Brightness LED Spotlight + Floodlight
- 2x Screens TFT + OLED
- Trackball + status LEDs
- Air Quality Index (C02, tVOC, NO2, ...)
- UV Index & LUX Index
- Thermal Camera
- Heart-Rate Sensor and Blood Oxygen
- Weather Temp, Humidity, Pressure
- GPS Location Compass, Steps, Altitude, RTC
- SD Card Reader
- 2-Port USB Charger 60W - fast charging
- Week - Month long Battery-life
- Thermal Duct Cooling
DETAILS | Function | Detail Module |
SENSORS | Air Quality Thermal Camera Heart Rate (and SP02) UV-Index Light Meter Weather Location Motion | CO2, VOC, NOx SCD41, SGP41 8x8px - Interpolated 120x112px AMG8833 MAX30102 330nm/365nm peaks VEML6075 LUX VEML7700 Temp, Altitude, Humidity, Pressure BMP390 GPS, Altitude, Compass PA1010D Orientation, Compass, Steps MPU9255 |
LIGHT | LED ~2500lm Torch LED ~1500lm Dispersed | 5000K, +Button, 7/4 Modes BLF A6 4000K, dimmable, high CRI, no Strobing |
POWER | 20.000mAh 60W Charging Out 30W Charging In | 2S6P MJ1 18650 USB-C, USB-A - QC4+, PD3.0 USB-C, USB-micro-b |
IO | TFT IPS 1.54" OLED 0.91" Trackball | Main 240x240px ST7789 Secondary Always-On 128x32px SSD1306 4-Color status LED, Button |
LOGGING & DATA | SD Card Reader HTML App | Logging, UI elements, up to 32GB Data Monitoring, Settings, local Network |
SYSTEM | ESP32 Thermal Duct System Sleep & Power Save Mode Electronic Path Protection Redundant components Sustainable Robust Design | 2 Core, 240MHz, 16mb, ULP WROOM-32U with two 20x20mm Fans Extends battery life to weeks/months Self checks, Auto-Shutdown & Warnings Power, Screen, Compass, AirQ Sources & Materials Alu, Carbon, Boat Leather, Plexiglass |
Use-cases
- Outdoor and Adventure (traveling, off-the-grid/offline living, two-in-one high power Lamps, Air Quality Fumes and Gases low Oxygen alerts inside Boats/Cars/Tents/Caves, Compass and Location for trekking & tracking, UV Index / Sunscreen indicator)
- IOT Station Logging and Monitoring for Weather and Air Quality Indoor/Outdoor (Air Quality Citizen Networks i.e. Canair.io)
- Urban Air Monitoring Body Temperature and Air testing in Offices and Schools (general Air Quality and Virus prevention)
- Emergency Intelligent hazard sensing & Alerts, GPS location, SOS lamp signal, health monitoring
- Rural Areas with limited or no access to basic monitoring equipment, medical support
- Makers & Developers platform for sensor/module testing, modding
- Smart Home Light HomeKit, ESPhome, smoke/gas warning, temperature, humidity etc
Cool project!
Since it is an apocalypse companion, I would also suggest a geiger counter feature for potential nuclear winters.
