Xorya Touch
Xorya Touch PCB is even cheaper implementation of Xorya game console on single PIC32 chip
This is the same Xorya ( <a target="_blank" rel="noopener noreferrer" href="https://hackaday.io/project/5507-xorya-extremely-low-cost-game-console-on-pic32">https://hackaday.io/project/5507-xorya-extremely-low-cost-game-console-on-pic32</a> ), but instead of analog joystick and buttons we have touch interface etched directly on PCB for 4 touch pads on the left and 4 touch pads on the right that significantly reduces cost of the product!
So Xorya Touch is still Xorya but with touch interface that should significantly decrease cost of the final product (no more buttons or analog joysticks), so schematics are the same:
Additionally it has 4 square pads, connected to RB8, RB9, RB10, RB11 and later I'll connect another 4 pads to get 8 buttons total: 4 arrows and 4 controls A,B,X,Y...
  • Video demonstration of touch interface
    SHAOS03/07/2017 at 04:54 0 comments
  • Reading touch sensors
    SHAOS03/06/2017 at 07:52 0 comments
    In order to read touch sensors (they will be implemented as part of PCB) we need to connect internal pull-ups to those pins then to read we should set pins out, clear pins and set pins in then read a few times (until parasitic capacitor is fully charged through internal pull-up) and analyze (touched pads charge longer):
    int tch[4],cc[5],c,i;
    ConfigCNBPullups(CNB8_PULLUP_ENABLE|CNB9_PULLUP_ENABLE|CNB10_PULLUP_ENABLE|CNB11_PULLUP_ENABLE);
    // somewhere in the game loop:
     tch[0]=tch[1]=tch[2]=tch[3]=5;
     mPORTBSetPinsDigitalOut(BIT_8|BIT_9|BIT_10|BIT_11);
     mPORTBClearBits(BIT_8|BIT_9|BIT_10|BIT_11);
     mPORTBSetPinsDigitalIn(BIT_8|BIT_9|BIT_10|BIT_11);
     cc[0] = mPORTBRead();
     cc[1] = mPORTBRead();
     cc[2] = mPORTBRead();
     cc[3] = mPORTBRead();
     cc[4] = mPORTBRead();
     for(i=0;i<5;i++)
      c = cc[i];
      if((c&BIT_8) && tch[0]==5) tch[0]=i;
      if((c&BIT_9) && tch[1]==5) tch[1]=i;
      if((c&BIT_10) && tch[2]==5) tch[2]=i;
      if((c&BIT_11) && tch[3]==5) tch[3]=i;
    tch[4] are states for 4 touch sensors - if respective number is greater than 1 then sensor is "touched". Experiment showed that if nothing is touched array will have all 1s, but if one or more sensors touched - respective value will go up (usually 3 if one sensor was touched or 2 if more than one sensor were touched). Interesting fact that it's relatively easy to detect intermediate finger position when it touches 2 neighboring sensors so with 4 pads we got 8 positions (or even 9 if we count center position as well).
  • First run
    SHAOS03/06/2017 at 06:02 0 comments
    Xorya-touch in action (connected to TV and PICKit3):
    for now it shows static image 320x200 with 2 half-frames (it's drawn as 160x400 with interlace):
  • Xorya-touch
    SHAOS03/06/2017 at 05:59 0 comments
    This is the next prototype of #XORYA - extremely low cost game console on PIC32 with capacitance touch interface where 4 pads connected to RB8, RB9, RB10 and RB11 (and there is a ground ring around them):
    Pads covered by scotch tape because we will measure capacitance of the "touch"...
View all 4 project logs
qquuiinn wrote 03/26/2017 at 04:52 point
Any ideas on how much it would cost in batch production? Can you do a PIC with USB eventually so the console could be programmed easily (with new games, or as a cheap console dev platform)? Great project!
SHAOS wrote 03/26/2017 at 06:30 point
For now I still think about PIC32 as a game cartridge itself to allow people to actually earn some money from selling preprogrammed chips (if they chose to go close-source way), but sure - I will eventually investigate applicability of USB PIC32 devices to Xorya...
SHAOS wrote 03/26/2017 at 04:01 point
Ok, project was repurposed as a candidate to 2017 Hackaday Prize with new name - Xorya Touch :)
Aleksandar Bradic wrote 02/28/2017 at 21:08 point
Project No. 20,000 ;) That must be worth something :P
SHAOS wrote 03/04/2017 at 01:09 point
Sorry, I tricked your system a little ;)
But I really wanted this number :)
Aleksandar Bradic wrote 03/04/2017 at 01:16 point
hahah I see what you did :)
SHAOS wrote 03/04/2017 at 01:39 point
I promise, it will never happen again :)
Yann Guidon / YGDES wrote 02/25/2017 at 21:13 point
knock knock :-)
SHAOS wrote 02/26/2017 at 00:40 point
who is there? ;)
Yann Guidon / YGDES wrote 02/26/2017 at 00:45 point
a guy who's curious about this mysterious empty placeholder ;-)
SHAOS wrote 02/26/2017 at 00:49 point
I'm still not exactly sure that I have time to do that :)
