close-circle
GoTo Telescope Control for rDUINOScope
Standalone Hardware Control Unit for use with "rDUINOScope" Firmware
close
Sorry for my bad english grammar...
This hardware project is "Open Source" and for all "Private-Uses"!
Comercial User (Companies) should ask me for the mass production rights!
1. Picture is the complete Telescope-Control-Unit, incuded the "Arduino DUE" Board.
2. Picture is the control unit with look at the bottom side, this can be odered by me.
3. Picture is the driver unit for the two stepper motors and joysick hand control unit.
4. Picture is the Schematics of the hardware, for user, who want to to bild it by self...
The last two pictures are the PCBs, top and bottom side.
The advantage of this hardware project is, it is not more expensive than the separately purchased components and you only need to connct it to "Arduino DUE" Board, load the "rDUINOScope" software and let it run & enjoy to look at the amazing sky...
It is not unknown that the RESET routine of the Arduino DUE does not work properly.
I have tested a circuit that fixes this problem. As seen in the photo, after switching on the operating voltage, it takes more than 150mS to reach the voltage of  fully 3.3V level.
In the CPU integrated RESET routine starts already after approx. 3mS!
This very short Master_RESET delay is the reason, why the Controller starting mostly with blank Screen!
The RESET Circuit I've created, works properly and in the next Version of the Controller it will be integrated.
It generates a delay for Master_RESET with about 150mS and the Controller running fine, after we switching the Power on...
In the future Controllers, I'II use the MAX803R Chip with the same delay time...
https://datasheets.maximintegrated.com/en/ds/MAX803-MAX810Z.pdf
It is a SOT-23 Chip with 3 Pins and can easy soldered on the older Controller Boards too!
For those who can solder such small parts, see the picture below:
The new enhanced Motor Driver is reloaded, up to 24V input Voltage for the stepper Motors...
The version from 3. Sept. has an input voltage capabilities from 15V up to 24V!
This driver Board is only compatible to the Main Unit V1.4c and later!
Here the Videoclip of the prior Version of the Driver Board:
rDUINOScope New Driver Board
_________________________________________________________________________
I've a suitable cable for the stepping motors manufactured.
It can be loaded with 1A / contact, which means 4A / motor!
The max. outer diameter is only ~ 12,5mm.
This Connectors are maded for Aviation and they are watheproof!
You need only to drill two holes with a diameter of 8mm in your case...
For disconnecting, you need only to pull back the outer Shell and pull the cable a way!
The finished version V1.4d is ready to use, you need only 2 NEMA17 mounted on your  Telescope and let it run!
It can be ordered as full assembled version included the programmed and tested Arduino DUE
+ Bottom holder aluminium plate with two cables (~ 50-60cm long) including a 5V Fan 25x25x7mm.
The price will be 325 CHF (Swiss Currency)  including PayPal fee and shipping costs.
This is the latest and finale Version of the series V1.4x!
The enhanced Version V1.4d is finished and can ordered after 20. Oct. 2017!
The enclosure is only a prototype and can ordered some weeks later...
The next Version V1.4.1 brings some more enhancements, like new Joystick with high accuracy digital intrface for a very precise manual aligning of your Telescope!
The whole height of the device will be only 28.3mm!
The bottom side of the housing is made of 1.5mm aluminum and is used as heatsink for the motor drivers!
It could be operated without a fan...
This Version is planed to finished and could be ordered, probably at the end of this year.
The price for the assembled and tested Controller, without enclosure cost $205 including the shipping costs.
For the Version wiht enclosure, the price is not fixed yet. Some Users could make it with 3D Printing.
It would be 3D printable and the STL-Data can be downloaded here.
This hardware design is for the open source project of "rDUINOScope", designed by
Dessislav Gouzgounov (Bulgaria) and with helping of community of over 250 members!
The whole Project Home is here: https://hackaday.io/project/21024-rduinoscope
The newest Controller V1.4c can be ordered here: http://rduinoscope.byethost24.com/kits.php
It is assembled and tested and will be shipped without Arduino DUE and without Motors.
The "rDUNINOScope Control V1.3 (or newer) Unit works only with Arduino DUE or compatible Boards and the "rDUINOScope" Software!
The Stepper Motor Driver section is designed for max 1A /...
This is also the last Version of V1.4x
JPEG Image - 458.72 kB - 09/05/2017 at 15:12
eye
Preview
download-circle
Download
This is probably the last Version of V1.4x
JPEG Image - 877.93 kB - 09/05/2017 at 15:11
eye
Preview
download-circle
Download
The Version V1.4a has some little changes, because of compatibility to the Firmware 2.3_Boiana_EQ and bellow. Some PCB Layout optimisations was maded to better soldering some parts.
JPEG Image - 1.04 MB - 06/20/2017 at 23:11
eye
Preview
download-circle
Download
It is the Version 1.4 of the Schematics with DRV8825 stepper Drivers. This Drivers, can drive, up to 2,2A with sufficient (heatsink) cooling...
JPEG Image - 1.08 MB - 06/11/2017 at 21:03
eye
Preview
download-circle
Download
rDUINOScope-Control-V1.3-540p.mp4
This is a 3D Videoclip of the control Unit.
MPEG-4 Video - 49.94 MB - 05/06/2017 at 21:18
download-circle
Download
View all 8 files
  • 1 × Adruino DUE Board (not Included)
  • 1 × Bluetooth Modul HC-06
  • 1 × Humidity Sensor DHT22-G
  • 2 × Stepper Motor Driver DRV8825
  • 1 × U-Box GPS Modul NEO-6M
View all 14 components
View all 7 project logs
  • 1
    Step 1
    For assembling of this harware we need a good knowledge
    in soldering of very small SMT components.
    Some SMT Pads, has a gap of only 0.2mm, see the picture bellow!
    The assembled unit must be tested with rDUNOScope Firmware
    and if it works, is fine...
    My experiences had showing, that the China parts like TFT Display,
    does not always work!
    It can lie on the defective Display or we have a soldering fault...
    In this case we need to figure out where is our problem
    and we need an oscilloscope!
    For soldering of Stepper Driver Chip DRV8846 or DRV8825,
    we need a special soldering oven, because this Chips has a Exposed Pad
    for dissipation of heat! We can not solder this with solder pen,
    because the Pad is on the bottom side of the Chip!
    I think, the better way to sell this unit as tested and working assembly.
    If someone wants to bild it himself,
    no problem but on own responsibility!
View all instructions
Daniel Zhou wrote 09/20/2017 at 14:58 point
Ii is an amazing project and found on google, because I tried to find a related GOTO project, I am very luck to find this. So I bought Arduino DUE, GPS module, BT module, and very hard to find the HX8352A TFT LCD, I have to build my own shiled for the TFT PCBA..I wonder if the 1.4D ver PCB is open source or not? IF yes, I am going to order a formal PCB in China. If it is not open source, i have to use my homemade PCB with much wires.
Thanks a lot.
Daniel Zhou wrote 09/23/2017 at 15:52 point
Hello Otto, could you please send the GERBER file to : FSCLUB@YEAH.NET , Thank you so much!
Otto Winter wrote 09/30/2017 at 01:03 point
Hi, fsclub, have you a really name?
My project is fully open source for any private use!
All who should plan a mass production have to make an agreement with me!
All who will produce the PCB's and solder all the parts itself, I find very brave...
It is not so easy to build up this system, without any truble!
The Parts are very small and if you do not have the experience to solder such small parts, then it usually goes wrong and it was only a wasting time for nothing!
My interests are not profit-oriented, I only want one, when somebody wants to buy or build this system, he should be able to work with it, without problems.
It must be clear to everyone that this is a complicated electronic system and not a cheap kit for some LEDs to flash ...
Sorry, I am an engineer with nearly 40 years of experience in the microelectronics world and I know what I'm talking about...
Only the gerber files alone, will not help you. You need all the data of the components and the assembly information!
I have already made in China, circuit boards, they had to throw away because of bad quality,!
I'II send you the Gerberfiles + Schematics and wish you much success...
If you get it running, give me a little feedback!
Best Regards
Otto
Daniel Zhou wrote 10/12/2017 at 03:10 point
Hello Otto,
My name is Daniel Zhou, from China.
Many thanks for your reply.
 I exactly know what you said about the difficulty to finish these kind project, not just flash a led. I have this hobby about making electronics by my self more than 20 years, and there is no problem for me on this project to solder and test, and repair. 0603 SMD components are good for me, even 0402 is also ok for me to manually soldering. TSSOP, TQFP is ok for me.
I have got the PDF SCH file and printed on my desk. I even planed to covert the PCB picture to *.pcb file if there is no other choice. This is really good news for me that you can provide related raw design files that I can save many hours to do this action. You PCB design is really perfect.
There is a little problem is my TFT pin map may be a little different than yours, that need a further check, so I may have to modify a little or make another shield to fit your PCB design. I will check this carefully.
Of course I will sign what you mentioned the non-commercial statements or related files, I just do it for my own use purpose.
I will send you the pictures after accomplishments.
Thank you again.
My email is FSCLUB@YEAH.NET.
Best regards.
Daniel ZHOU
Wellingtonsmoura wrote 07/19/2017 at 20:05 point
I am interested in buying, very interesting your project. Let me know how we can handle a possible purchase.
Otto Winter wrote 07/20/2017 at 19:05 point
Thank You for Your interesting to bay this Hardware! :-)
Actually I don't have any assembled Conroller, because of redesigning & many improvements.
The next working controllers (V1.4b) could be finished in 3-4 Weeks.
Sorry for the long delaying, but I've to order new PCBs next week!
Otto Winter wrote 07/21/2017 at 18:26 point
You can bay the assembled and tested controller for $205.
This price including the PayPal & shipping costs.
Otto Winter wrote 07/19/2017 at 01:29 point
Yes, You can run both from a 12V 2A+ but for two motors, better 4A+!
Lee Maisel wrote 07/19/2017 at 01:23 point
SHOULD I supply power separately to the motor driver circuit? OR can I run both from the same 12v 2A+ supply??
Thanks!
Otto Winter wrote 07/21/2017 at 18:22 point
You can connect it together, because it is better to separate it, if it is possibile...
The Stepper Motors generate much of "EMC interference" that could influense the Arduino Board Functions!
Otto Winter wrote 07/21/2017 at 18:23 point
The EDA (CAD) files are not published and because it was designed with Altium!
The most people working with Eagle...
I will publish the GERBER Files for User, they want to produce the PCBs it self.
Lee Maisel wrote 07/18/2017 at 18:13 point
I have received my rDuinoScope 1.4 unit from Otto, and it is a MASTERPIECE!!!  Beautiful construction!!   THANK YOU!!!
Otto Winter wrote 07/21/2017 at 18:16 point
Thank You and enjoy it and good luck for all experiences!
Otto Winter wrote 07/04/2017 at 19:46 point
Yes, the Version 1.4x is Open Source HW and for the later Versions 1.5x-1.9x probably to.
From the Version 2.0 we will sell it only as assembled and tested Hardware, because of high complexity and it is a Standalone Version, without Arduino or any external Modules.
One PCB in a case without any cable! It will controll the Motors over Wireless!
With one Lithium Cell, (3700 mAh) it would work over 9-10 hours.
For The Motors we need an extra Power Stage with 15-20 Ah for the same Time.
madhu nuggehalli wrote 07/05/2017 at 14:30 point
Thanks for this info! where can I find the CAD files? I would like to make a PCB and check it out.
madhu nuggehalli wrote 07/04/2017 at 16:21 point
Hi Otto,
Will this project be OSHW at all?
Thanks,!
Lee Maisel wrote 06/26/2017 at 23:01 point
How can I purchase the PCB's please?  Thank You  WONDERFUL Project!!
Otto Winter wrote 06/27/2017 at 11:24 point
Hello Lee, Thanks for your interesting!
For now I sell only assembled and tested units, because it is to complicated
to be assembly yourself.
Lee Maisel wrote 06/27/2017 at 17:09 point
I'm ready to buy,  How do I proceed?  Thanks!
Lee Maisel wrote 06/26/2017 at 22:36 point
Also, are the custom boards OR completed units for sale?
Otto Winter wrote 06/27/2017 at 11:27 point
The assembled & tested Board cost 150 € or 170 USD + shipping costs.
Without stepper motors and without Arduino DUE Board!
Lee Maisel wrote 06/27/2017 at 20:15 point
Thanks!  Let me know where to order. :)
Otto Winter wrote 06/27/2017 at 11:21 point
Hello Lee, thank you for your interest of my harware.
I'm using a single TFT and not an assebly like in the Link you posted.
Please read all my Project informations and you will see, that this hardware
project not to be compared with modular assemblys...
Diego Dabrio-Polo wrote 06/19/2017 at 09:16 point
Hello,
• Probably this is not the right place to post this comment, and maybe I should write a Private Message. I do not know to whom I should write of how to do it.
I do not know the etiquette rules of this site yet, and I prefer to be extra-cautious.
I have just joined Hackaday because of this stunning rDUINOscope Control project.
I am an amateur telescpe maker and I need a control unit, that can work either standalone or connected to a PC or android device (with Stellarium)
I also need to be able to use my own stepper motors with their specific step count.
Therefore, this project suits me perfectly.
I have been looking for something like this for ages!
• I want to make a rDUINOscope Controller, and I want to make one and test it as soon as possible.
I am ready to buy all the pieces from eBay or Aliexpress, but I need the PCBs. I imagine you can provide them. I would like to buy a bundle (a kit with all the items) from you, if possible.
• I would like to join your project and get involved in it, but I do not know if you need me, because my programming skills are very basic.
I can solder pretty well, and I could test the controller of contribute in other forms.
• I would like also benefit from the V 1.5 version of the project, but if you have old V 1.3 or V 1.4 PCBs that you want to get rid of, I can buy them and make an older version.
In fact I do not know if different versions of the rDUINOscope Control share PCBs
I also do not know when V 1.5 will be ready. I can wait, but I am so eager...
Thank you,
Best regards
Diego
Otto Winter wrote 06/19/2017 at 21:21 point
Thank you for the message, it is arrived on the right place...
I'm  working on the V1.5 but the changes are much more as planed.
The V1.4a is the latest working version and it  is 100% compatible to rDUINOScope code from Dessislav.
New PCBs V1.4.a would be available in about 2-3 weeks.
The V1.5 Version takes probably more then 4-5 weeks, sorry...
Gianluca wrote 04/28/2017 at 18:21 point
Sent a Private Message
Otto Winter wrote 04/27/2017 at 11:06 point
For all Users, Likers, Followers, tahank you for your interest on this usefull project!
I'm shure, that this hardware unit, could help, for many telescope owners, who do'nt have any positioning control unit, because they are too expensive.
This hardware is build up modular and can easy customized for different requirements...
Any suggestions or constructive criticism, are welcome!
