close-circle
Building the Thor+ robot arm
Building a 6-axis robot arm based on the AngelLM's Thor robot and the add-on's and improvements of dannyvandenheuvel.
close
This is the buildlog of the Thor+ robot I'm building right now.
The original author is AngelLM who created the Thor robot.
DannyvandenHeuvel created the Thor+ robot which is an improved version with many add-ons.
I was looking for a 6DOF robot arm to print.
The first project I found was the Mantis Robot Arm. This is a nice robot arm but the project seams to be abandoned.
Then somebody pointed me to the Thor OpenSource 3D printable Robotic Arm from Angel LM. I loved this design but I was missing the feedback sensors.
And then I found the 'Thor' robot with addons and GUI from Dannyvandenheuvel. This is the Thor robot arm with a lot of addons and improvements. Danny added the feedback sensors in V2.02.
In this project I will share my building of experience of Danny's version of the Thor robot.
Zip Archive - 2.33 MB - 09/17/2017 at 15:10
download-circle
Download
Art56SmallGear_For16x7PulleyShaft_01.stl
For more info look at the Day 15 log
Standard Tesselated Geometry - 1.22 MB - 09/10/2017 at 17:35
download-circle
Download
Art56MotorCoverRing_01.stl
Standard Tesselated Geometry - 1.24 MB - 09/10/2017 at 17:35
download-circle
Download
Art56SmallGear_For20x6PulleyShaft_01.stl
Standard Tesselated Geometry - 1.21 MB - 09/10/2017 at 17:35
download-circle
Download
Axle6Fixer.stl
Standard Tesselated Geometry - 246.96 kB - 09/10/2017 at 17:35
download-circle
Download
View all 8 files
  • Day 16: Redesign of Body 4, Covers 5 and some small changes to the gripper.
    Sepio09/17/2017 at 14:33 2 comments
    The last few days I changed some parts. I added some 40x40x11mm cooling fans to the ART4BottomBody . There isn't much room but it fits. I have test printed it and everything fits but i made some of the walls too thin (on the left and right side of the vent holes).
    I also tested if I could fit the GT2 208 mm belts but the motors can go high enough. So i ordered GT2 232 mm belts. If they are too long then I have to change the mounts between the upper and lower body. In the image below on the top the motor mount (and motor) are touching the mount with the screw hole.
    On the left of the left fan hole (and on the right of the right hole) the wall is too thin. The downloadable version (below) is 1mm thicker.
    Because of the fan holes the ART5 covers didn't fit anymore. So I recreated them. Below the Base part.
    And the upper part. I also made them in two parts. This way it is possible to use two colors and it can be printed with less print support.
    This is the way Danny designed it. (But his downloadable STL is different). I added the screw holes for the covers.
    I changed the gripper mounting plate to a trapezium so both parts will stay together and the existing screw holes will keep them together. The GripServoMount has some extra room for the servo (on the bottom). The GripMountB is a little bit thicker. I also added the GripGear.stl (which was missing in Danny's version). The ART56 interface place also contains a hole for future usage.
    Below the gripper. On the right side of the servo there is some extra room.
    To mount the gripper from right to left:
    - GripServoMount
    - Washer
    - Plastic ring with bearing
    - Large gripper with bearing
    - Washer
    - Small gripper with bearing
    - Washer
    - GripMountB
    I might redesign Axle 6 again. Olaf made a comment on how to wire the gripper. I would like to do that by making this Axle hollow and use large bearings on the outside of the shaft.
    So I already added a hole to the Art56Interface (on the right side).
    Danny asked about my printer. Below my print setup. I have a Ultimaker 2 Extended + with top cover and door. I use some Alkotip wipes to clean the glass plate before printing. After cleaning I use a (very) little bit of 3DLAC.
    The Art4UpperBody is currently printing. The Art5Top Covers are almost finished.
    Below the changed parts:
    - Day 16.zip The Body4 and Cover5 parts are untested. Next week I can tell if everything fits.
    - Step file of version 3.05
  • Day 15: Redesign of Art56MotorCoverRing
    Sepio09/10/2017 at 10:54 11 comments
    I didn't like the way the ART56 gears are mounted. So I decided to redesign it. Below the renderings of this new design
    Below on the bottom the old version. There is just a few mm to mount the screw which forms Axle 6. In the new version a real axle is used and it is guided by two bearings. There is also room for one or 2 rotation sensors on Axle 6.
    Also the bearings of Axle 5 are removed. I splitted this axle into 2 parts. The axles can be "screwed" into placed by placing them into a electrical screwdriver. They are fixed inside the new part so the rotation sensor will work.
    First put a bearing on the top side. (You can reuse the old bearings).
    Then put the other bearing on the bottom side.
    Use a flat tool to push the bearing in it's hole.
    The axle will be mounted like this. From right to left.
    - The big gear
    - 2 M5 spacers
    - A bearing on the top side
    - A bearing on the bottom side
    - Another M5 spacer.
    - The Axle6Fixer that prevents the axle from moving up or down.
    - (If there is room another 5MM spacer. I didn't use one)
    - One or two rotation sensors.
    The makerblock rotation sensor doesn't support a full 360 degrees rotation. If you mount 2 of them on the same Axle then it will be possible to measure all directions.
    Use a electrical screw driver to screw the Art56GearPlateAxleHolder_01 on the axle. It will be a tight fit.
    The axle with the holder can now be fitted into the big gear.
    My version was 15mm and the hole is 16mm so I used some tape to make the axle a little bit wider. The downloadable version is 15.5 mm. (it has to be removable)
    To make the rotation sensor work the Axle has to be fixed inside the gear. This way it is still removable and by using the 3 screws for the Art56Interface it is possible to keep everything in the right place.
    Add 2 M5 spacers.
    And mount everything together.
    Make sure the gears align perfectly. It is possible to remove or add a M5 spacers (two steps up) to change the gap between the gears.
    This is how it will look with the gripper mounted.
    There is enough room for the belts. I will have to find a way to wire the rotation sensors.
    I might drill a hole on the bottom of the ring for the wires. This way the electrical wire will stay out of the belts way.
    I am going to change the small gears also. There is about 29 mm room on both sides of the axle. 2 bearings and the pulley are 27mm.
    The hole inside the gear is too big. I am going to make the hole smaller for the pulley. And on the other side I will add some plastic to add a bearing. (The gear has to be able to rotate freely on it's axle.
    On the axle it will be mounted like this:
    - 1 or 2 M5 spacers
    - The pulley
    - The small gear
    - Bearing
    - A few M5 spacers
    Update:
    Below the new gears. This is the first version and there are two small problems. The bearing can't go deep enough and the screw hole to fix the pulley and the gear is 0.5mm off. The second version is printing right now. The second version can be downloaded below.
    I added a bearing. The axle hole in the plastic gear is a little bit bigger. And I made 2 version. One for a 20x6mm pulley shaft and another for a 16x7mm pulley shaft.
    One M5 spacer is needed.
    The final result.
    Below the rendering of the new structure.
    The changed and new parts can be downloaded here:
    Art56GearPlateAxleHolder_01.stl
    Axle6Fixer.stl
    - Art56SmallGear_For16x7PulleyShaft_01.stl
    - Art56SmallGear_For20x6PulleyShaft_01.stl
  • Day 14: Art 5 and 6 test fit.
    Sepio09/03/2017 at 10:44 1 comment
    Below a few photo's of the construction of Art 5 and 6. There is one big axle. The small orange gears and Pulleys are (going to be) connected with a screw. They will freely rotate on the Axle and are driven by two motors.
    The middle part with the ring contains a nut on which the Art 6 Axle with the big orange gear is mounted.
    If both the left and right small orange gear are rotating in the same direction then Art 6 is going up or down. If  the small gear are rotating in the opposite direction then Art 6 is rotating.
    But I don't really understand how it has to be mounted. The hole in small orange gear is much bigger then the GT2 pulley. There is also to much room on the Axle. The small gears are supposed to rotate freely on the axle but the aren't any spacers to prevent them to go up or down the axle.
    There is a nut in de orange part with the axle. A screw is used to hold the big gear of Axle 6 on top of the small gears. But there are no bearings inside Axis6. And if it rotates the screw becomes looser.
    If all parts can rotate and stay into the right place then it will work. So I might redesign this.
    Below a few photo's of the idea I have. I have added a piece of black tape on the Axle 6. I want to cut it on the left side of the tape. Then I have 2 parts. One part with the big gear and one part with the shaft.
    This way I can redesign the "big ring" part and add two bearings (the bearings shown are to big). The shaft is thick enough to use 3 3mm screws to fix both parts together. This way it can still be mounted together and the shaft is fixed between two bearings. (I might even be able to keep the shaft hollow to guide some wires)
    I am also going to redesign the two small gears so the pulley will fit tightly. Small ball bearings will be added to the small gears.
  • Day 13: Building Art 3
    Sepio09/03/2017 at 10:18 1 comment
    Last week I printed al the Art3 Parts.
    First I had to cut the GT2 belt to length. I used the Art2 body parts as a mounting template.
    After a few tries the pulley was having the right length.
    Now it was time to mount it al together. There is just enough slack to mount the belt. The cover contains the bearing and this will tighten the belt.
    Below the inside of the lower part of Art 3. I already mounted the motor. A potentiometer or optical rotation sensor will be added later.
    This is the top part of Art 3. It contains a custom bearing.
    Below all the parts for this custom bearing. The green ball are 6mm airsoft balls. The small black part is the plug.
    Just hold the inside and the outside of the bearing in place and fill the hole with balls.
    By rotating the inner part the balls are traveling to the bottom and the hole is free to insert the next ball.
    I used some tape to hold the plug in place. The plug will fit in the hole of the outer part on the left side.
    There is a small gap between the orange Art4 part and the Black Art 3 part.
    Below the Art 3 upper and lower part are mounted together.
    In the future I might change the custom ball bearing because it has to much slack. I want 2 bearings to keep this axis as steady as possible. I already ordered a few different sized 6xxx series ball bearings.
  • Day 12: Axle Holder
    Sepio09/03/2017 at 09:46 0 comments
    In my previous blog I told about the weak construction of the Axle between Art1body and Art2BodyB. I also had to find a way to fix the Axle in Art1 because of the rotation sensors in Art2BodyB.
    So I decided to design a custom part. The green AxleHolder part in the photo below is the solution for both problems. It replaces the bearing and the bearing ring holder. The same Axle holder can be used for the axle on the right side. (Note: There isn't room for the Art23OptoDisk anymore. Danny's design doesn't need one).
    The new parts and the place it will fit on.
    The hole for the Axle is very tight. I did put the Axle in a electrical screwdriver and used it to "screw" it into it's place. Because of the friction the plastic melts a little bit and that keeps the Axle in it's place.
    The other side.
    Both axle holders are mounted. You need 20mm screws.
    After putting everything back together it feels much sturdier. No wobbling axis anymore.
    The AxleHolder part is available for download: AxleHolder.stl
  • Day 11: Mounting Art 2.
    Sepio08/27/2017 at 16:08 1 comment
    Below all the parts of art 2.
    First I had to create the belt tensioner wheel mount. At first I had no clue how to fit those wheels. There is no room for a nut. So I decided to use m3 threaded inserts. I made the hole a little bit bigger. I fitted the insert on a long screw so I could heat up the insert. Then I inserted it into the hole. The plastic melted a little bit and after aligning everything I used some cold water to cool the plastic down.
    The mounts with the threaded inserts.
    Now it was time to add the belt tension wheels. I also used two halfs of a compression spring (from a pen) to push both belt tensioners to the inside.
    Now it was time to fit all the parts together. I don't like the orange parts for the sensors which have  to be glued on the axles. I am going to make the axle a little bit longer and use that for turning the potentiometers.
    The inside.
    Now it was time to create the axles. I made one side of the 5mm axle a little bit smaller. Just put the axle in a electric screw driver. Use the dremel (or file) to grind the axle to 4mm. Then I used the dremel to flatten one side.
    I fitted the orange parts on art 1 and inserted the axle. The side with the flat area is on the inside.
    I used some tape on the Axle to mark the length.
    Then I cut the Axle with the Dremel. Use the screwdriver to turn the Axle and keep the running Dremel steady.
    Now insert the Axle the correct way.
    The potentiometer of the sensor fits.
    All three Axles finished. I think I will created an extra plastic part with an extra bearing to mount between art 1 and art 2. This axis uses two small axles because the motors are inside the art 1 housing. On the gear side it is very sturdy. But on the other side it is hanging trough. If I mount a new plastic ring with another bearing to the black or orange part then it will become more firm. But before I will design this I want to be sure that I'am not missing any parts. Without the extra part I'am sure the potentiometer sensor will break.
  • Day 10: Wiring the base and art 1
    Sepio08/27/2017 at 15:41 3 comments
    Last week many parts arrived from China. One of them was the slip ring. Also Danny added the base with the fan holes for a 40x40X10 mm fan.
    After printing the new base I tried to add the fan. But it didn't fit. All the 40x40x10 mm fans are 10.8 mm high. Why don't they call it a 40x40x11 mm fan.
    The base only accepts 9,8 mm fans.
    So I had to use some pliers to break some plastic away. I used hot glue to mount the fan.
    Now it was time to mount the slip ring. The slip ring has 24 wires. I created 5 groups of 4 wires (green, blue, orange, red and white for the stepper motors and a group of 2 wires for the power lines (black) and a group of 2 for the serial communication (orange). I wanted this wires to be shielded. The shield on the foto below is long enough to fit over the remaining wire. I used some copper tape to keep the shielding in place.
    A piece of shrink wrap is used to fix the sleeves.
    On the other end I used also some sleeving. The orange serial cable is longer because I want to be able to put the Nextion display on the table with all the wires attached.
    I used the old base (without the fan holes) so I could do the sleeving of the upper part. Also the bottom wires are fitted with connectors.
    The top ones are fitted with connectors. I created a new PCB. All the stepper motor wires are on the left side. So there is room for step down convertor on the right side. I am going to use 24V power wires trough the slip ring. So I need a step down convertor above the slip ring to change it to 5V. This way I'am not restricted by the 2A max slip ring wires (24V x 2A = 48W, 5V * 2A = 10W). I think I need more then 10W for the arduino, sensors, led ring and servo.
    Now it was time to mount the art 2 part with al its wires on the base. The pink wire is used for the sensors. I made a small PCB (bottom left). (Green = 24V, Black = 0V, Red = 5V). This board is also used to power the Nextion and the 24V line though the slip ring.
    The wires of the stepper motors are also sleeved and fitted with connectors. The connectors are arranged in such a way that the will fit in the gap.
    Everything fits.
    I still had to connect the Nextion. I added some alu tape on the inside of the Nextion display cover as a shield. (Don't know if it will help).
    I created a small PCB (just above the Nextion display) with a power level convertor. The Ultratronics uses 3.3V and the Nextion and Arduino inside the arm are using 5V. The Nextion display is powered with the 5V from the power supply. The 24 line is used to power the top part of the arm. I want to add a Emergency button on the powersupply case which will cut the 24V line. This way the Nextion display can stay on.
    Yes! It is still working :-)
  • Day 9: Mounting the Nextion display
    Sepio08/27/2017 at 15:03 10 comments
    Today it was time to mount the Nextion Display in its frame. With a file I created a hole in the orange part so there is room to remove/insert Micro SD cart. I used a piece of all tape to smoothen the surface. This way it was easier to remove the cart.
    I didn't like an unprotected bottom. Its to fragile. I created a bottom cover for the Nextion Display. It has an air intake on the bottom left side. An hole for the SD cart on the bottom side. And on the right side there is room for the warm air to escape. There is also a cable guide.
    Below the bottom part mounted. (The wires will be replace by shielded ones).
    The air intake and the hole for the SD cart.
    The covers can be downloaded here. I used Fusion 360. I included all possible export formats.
    I Also created a top cover to protect the screen during the build. (But I'am going to reprint it because I left the black part in the sun and now it is curling up.
  • Question: Powering the parts inside the arm.‚Äč
    Sepio08/19/2017 at 15:55 0 comments
    Amperage
    I have to wait for some parts (among which the slip ring) before I can wire the PCB inside the arm. So I was thinking about the maximum amperage I need for all the parts inside the arm:
    - 2x 5V fans  (2x 0.14A = 0.28A)
    - Arduino Uno (0.1A)
    - 6 Rotation sensors (0.1A)
    - Servo (0.5 to 1 amp?)
    - Ledring (24 NeoPixels at full brightness × 0.06A  = 1.4 Amps)
    I would also like to add a few MPU9250 9-AXIS Gyro Accelarator Magnometer Sensors in the future.
    5V through slip ring.
    The slip ring wires can handle 2A max. Danny uses one of the wires for 5V. This way it can handle 2A x 5V = 10W. I don' think this is enough.
    24V through slip ring and 5V step down convertor on PCB
    Wouldn't it be better to use 24V for this wire. This way it can handle 2A x 24V = 48W. I could convert it back to 5V on the PCB above the slip ring. This way I have 48W / 5V = 9.6A.
    The top of the PCB is cooled by the fan. So cooling isn't a problem. If I mount the PCB a little bit lower there is more than enough room for the step-down convertor.
    This also means that if I hit the emergency switch in the power unit I only need to cut the 24V line. The 5V line can be left intact to power the Nextion display.
    Question:
    What do you think about this? Are there any disadvantages I didn't think about?
  • Day 8: Finishing Axis 1
    Sepio08/19/2017 at 14:38 0 comments
    After printing all the parts for AXIS 1 it was time to put it all together.
    First I had to glue some parts together. I used the screws to align the parts.
    I added a hole in the orange ring. I used the bearing cover ring for positioning the hole.
    All the parts that will be mounted together. I added a few drops of glue between the black and orange bearing ring. This way the ring can't the screws holes are aligned and it will be easier to mount AXIS1 to the base. I also added some ball bearing.
    Axis 1 from the top side. (I changed the screw and nuts to mount the PCB to PCB standoff pillars).
    And from the bottom side. De inner black tube is used to mount the slip ring.
    An example of the slip ring (this one doesn't have enough wires).
    If the slip ring is inserted it will look like this. The part with the wires can rotate. The little gap on the top right side of the gear is used for the optical gate sensor.
    The same slip ring from the top.
    After mounting the PCB it was time to put AXIS 1 on the base. The little hole in the top ring can now be used to insert and fasten the screws.
    Just rotate the top ring 120 degrees and insert the next screw.
    I didn't add the 10 turn potentiometer in the base yet. Because I still have to create the correct firmware It can now rotate continuously.If I add the potentiometer it is limited to one rotation. One rotation of AXIS 1 is about 8 turns of the potentiometer. Without support for this in the firmware it could (and would) break something.
    Now it was time to turn the power on and it worked perfectly.
View all 17 project logs
donskit30 wrote 09/18/2017 at 04:29 point
Were  there any exceptions to the 3D material use for your print on certain parts. AngeL said he used PLA for all parts?
dannyvandenheuvel wrote 09/03/2017 at 13:25 point
Your doing fantastic work! It's a pleasure to watch your progress, I even want to change my weak parts by your ideas. thanks!
dannyvandenheuvel wrote 08/15/2017 at 16:47 point
Shielding cables:
Generally shielded wires are only grounded on one end. Splicing shouldn't be a problem.That depends. General rule is:If you want to keep EMI inside the cable, ground both ends. If you want to keep the EMI outside the cable, ground one end.So if a signal is small in magnitude (think audio signal like microphone circuit) ground one end to keep interference from outside corrupting the signal inside the cable (including interference created by a ground loop if you were to ground both ends).If you are connecting something like a strobe signal (large AC signal) go ahead a ground both ends as goal is to make sure what is inside doesn't radiate to the outside (groundloop induced corruption of the large strobe signal is a non-issue).In the case of an RS-232 signal you have a fairly large signal [5V or more Peak to peak) running at almost 10KHZ baseband frequency (or more)]. Radiated harmonics could cause all sort of issues. Hence, ground both ends.
I grounded one side on the ultra board. No problems detected after it.
Olaf Baeyens wrote 08/15/2017 at 19:58 point
I learned something new!
Olaf Baeyens wrote 08/14/2017 at 11:44 point
Nice work!
