Trinket LED Thermometer
Espy room temps with a Trinket, a battery, a 1-wire sensor and an RGB LED
This is a simple remote thermometer that reads ambient temps with a Dallas-Maxim 1-wire temperature sensor (DS18B20 or DS1822) and displays the temperature on a single RGB LED tuned to a predetermined color scale (blue for cold, red for hot, green for "comfortable". These are small enough and cheap enough to place in multiple locations around a room to monitor for hot/cold spots. A large number of these spaced appropriately can be videoed and used to track heating/cooling trends over time.
  • Mapping Temperatures
    ethan.dicks12/30/2014 at 23:22 0 comments
    The simplest color map would be a table with one entry per temperature increment available from the sensor. Given a spread of room temps from -20°C to +40°C, that's a table of longwords well under 1K even at 0.5° intervals. There's no need for that much redundancy, and it might be advisable to keep the entire memory footprint down in case there's reason to scale back to, say, a Tiny 4313 where a 1K table has a noticeable impact on space left for code. Computers are good at math, so the usual trick is a small table of inflection points and a handful of statements to interpolate between them...
    // temp_to_color - convert temp x 10 to ready-to-use color value for RGB LED
    Adafruit_NeoPixel strip = Adafruit_NeoPixel(1, PIN, NEO_GRB + NEO_KHZ800);
    uint8_t cmap[] = {
      0xff, 0xff, 0xff, // -9C - white
      0x00, 0x00, 0xff, //  3C - blue
      0xff, 0x00, 0x00, // 15C - green
      0xc0, 0xff, 0x00, // 27C - orange
      0x00, 0xff, 0x00, // 39C - red
    uint32_t temp_to_color(int degree_tenths)
        uint32_t c;
        uint8_t i;
        int floor_t;
        float scale;
        // Grab extremes (colder than -9C and warmer than 39C) and return max colors
        if (degree_tenths <= -90)
            c = strip.Color(cmap[0], cmap[1], cmap[2]);
        else if (degree_tenths >= 390)
            c = strip.Color(cmap[12], cmap[13], cmap[14]);
        else {
            i = ((degree_tenths + 90) / 120) * 3; // set floor at -9C and scale range
            floor_t = (i * 40) - 90; // get the bottom temp of this range
            scale = (degree_tenths - floor_t)/ 120.0; // calc how far along this range
            // get colors by interpolating this range and adding it to the base color
            c = strip.Color(cmap[i] + (cmap[i+3]-cmap[i])*scale,
                            cmap[i+1] + (cmap[i+4]-cmap[i+1])*scale,
                            cmap[i+2] + (cmap[i+5]-cmap[i+2])*scale);
        return(c);
    This should take care of temps below and above what the table can handle, and gradiate the colors along the continuum. It has the additional advantage of being easier to tweak than editing a massive table.
  • Colors
    ethan.dicks12/23/2014 at 23:03 0 comments
    Thinking of the color-display aspects of the project, I think one or two selectable color ramps is enough to get started.
    Really Cold -> Cold -> Comfy -> Warm -> Hot
    White -> Blue -> Green -> Orange -> Red
    About 12°C ought to be a good initial separation...
    -9°C -> 3°C -> +15°C -> +27°C -> +39°C
  • The Libraries
    ethan.dicks12/16/2014 at 22:51 0 comments
    Even a simple Arduino project invokes libraries. Here's what I plan to use...
    With the heavy lifting done by the libraries, the core code just needs to call for a temp conversion, map temp to a color, set the color, then sleep for a time and repeat endlessly. Enhancements include adding a simple button interface to mark a set-point, and perhaps to discover additional DS182x/WS2811 pairs on extension wires.
  • DS1820 or DS18S20 or DS18B20 or DS1822...
    ethan.dicks12/09/2014 at 22:49 1 comment
    It's been a while since I've picked up a 1-Wire sensor, and I come to find that the venerable DS1820 has been retired. Looks like the current recommended parts are the DS1822 for 2°C accuracy and the DS18B20 for 0.5°C accuracy (the DS18S20 is a drop-in for the original DS1820).
    APPLICATION NOTE 4377 - Comparison of the DS18B20 and DS18S20 1-Wire® Digital Thermometers
    With all of that, I happen to have the original DS1820 and the newer DS1822 in my parts bin, so I plan to test them both.
  • Initial Design Notes
    ethan.dicks12/02/2014 at 21:19 0 comments
    The hardware design of the LED Thermometer is straightforward. The WS2811 LED consumes one pin, and the 18B20 consumes one pin for data. Given the nature of both the WS8211 and 18B20, it's easy to add multiple pairs of temperature sensors and display LEDs chained back to the first one, the only issue being matching up the sequence of LEDs with the random nature of 18B20 addresses on the bus, but requiring them to be added one at a time and saving the station addresses in EEPROM could simplify the expansion process.
View all 5 project logs
  • 1
    Step 1
    Any digital I/O pins can be used for the WS2812 LED or the DS1822 OneWire temperature sensor. For easy placement, the code expects to see the LED on D6 and the sensor on D8. If you decide to move them, just change the constants in the code.
    Besides running +5V and GND to both the LED and the sensor, you'll need a 4.7K pullup on the DS1822 data line per the OneWire spec.
    That's it! Three components.
  • 2
    Step 2
    Here's a functional program to initialize the hardware, read temps, and display temps as colors. Enhancements such as multiple sensors/LEDs per Trinket are possible but left as an exercise for the reader.
      trinket_thermo
     Trinket-based therometer with color output
     When         Who  What
     30-Dec-2014  erd  Incorporate basic color conversion process
      2-Jan-2015  erd  Update color conversion process
      2-Jan-2015  erd  Final changes for production hardware
    #include <Adafruit_NeoPixel.h>
    #include <OneWire.h>
    #define LEDNUM 1
    #define LEDPIN 6
    #define TEMPPIN 8
    Adafruit_NeoPixel strip = Adafruit_NeoPixel(LEDNUM, LEDPIN, NEO_RGB + NEO_KHZ800);
    OneWire ds(TEMPPIN);
    // function prototypes
    uint32_t temp_to_color(int);
    // set up hardware
    void setup() {
      uint32_t i;
      // init LED
      strip.setPixelColor(0, 0); // one LED for now
      strip.begin();
      strip.show(); // Initialize color to 'off'
    // collect temp, display temp, repeat forever
    void loop() {
      uint8_t i;
      uint32_t color;
      // OneWire storage
      byte present = 0;
      byte type_s;
      byte data[12];
      byte addr[8];
      float celsius, fahrenheit;
      // scan OneWire bus
      if ( !ds.search(addr)) {
        ds.reset_search();
        delay(250);
        return; // holdover from vendor example
      // the first ROM byte indicates which chip
      switch (addr[0]) {
        case 0x10:
          //Serial.println("  Chip = DS18S20");  // or old DS1820
          type_s = 1;
          break;
        case 0x28:
          //Serial.println("  Chip = DS18B20");
          type_s = 0;
          break;
        case 0x22:
          //Serial.println("  Chip = DS1822");
          type_s = 0;
          break;
        default:
          while(1)  // loop forever if no DS182x found
      // reset OneWire and tell DS182x to acquire temperature
      ds.reset();
      ds.select(addr);
      ds.write(0x44,1);  // start conversion, with parasite power on at the end
      delay(1000);     // maybe 750ms is enough, maybe not
      // we might do a ds.depower() here, but the reset will take care of it.
      present = ds.reset();
      ds.select(addr);
      ds.write(0xBE);         // Read Scratchpad
      // read data from OneWire bus
      for ( i = 0; i < 9; i++)           // we need 9 bytes
        data[i] = ds.read();
      // convert the data to actual temperature
      unsigned int raw = (data[1] << 8) | data[0];
      if (type_s) {
        raw = raw << 3; // 9 bit resolution default
        if (data[7] == 0x10) {
          // count remain gives full 12 bit resolution
          raw = (raw & 0xFFF0) + 12 - data[6];
      } else {
        byte cfg = (data[4] & 0x60);
        if (cfg == 0x00) raw = raw << 3;  // 9 bit resolution, 93.75 ms
        else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
        else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
        // default is 12 bit resolution, 750 ms conversion time
      celsius = (float)raw / 16.0;
      // set pixel color
      color = temp_to_color(int(celsius*10));  // color routine takes int of 10X temp
      strip.setPixelColor(0,color);
      strip.show();
    // Ranges of colors in RGB order
    uint8_t cmap[] = {
      0x00, 0xff, 0x00, // 15C - green
      0x80, 0x66, 0x00, // 27C - orange
      0xff, 0x00, 0x00, // 39C - red
      uint32_t c;
      uint8_t i;
      int floor_t;
      float scale;
      else {
      return(c);
  • 3
    Step 3
    Download the OneWire library and the NeoPixel library then install them for your platform. Compile and upload the sketch to your Trinket.
View all 4 instructions
Adam Fabio wrote 12/02/2014 at 07:02 point
Hey Ethan! Welcome to the Trinket Everyday Carry Contest! Don't forget to add an image and a project log so we can include you in the first giveaway drawing. It's happening at 9pm EST tomorrow, January 2, 2014
