Zamek: The Offline Pocket Password Manager
Creating and retrieving passwords for all your accounts has never been this easy and convenient!
Zamek is your personal, portable password manager.
I'm working on putting together a group-buy campaign for a batch of these with attractive cases! Sign up at https://www.crowdsupply.com/soniktech/zamek to find out when you can get your own!
See a video review of the beta unit at https://www.youtube.com/watch?v=gLEXId6XHqc !
Many people use the same password for different online accounts. Even if the password is very strong, hackers don't need to break into your very secure financial and other important accounts directly. They can attack a weaker website, such as a web forum or subscription service, and use the password they stole from that website's database to steal your identity and log into any of your online accounts.
Both physical and electronic security are difficult skills to master, but most would agree that it's a bad idea to use a single key for every real-world lock you own. So why would you use the same digital key for all of your electronic locks? Many people complain that it is difficult to remember multiple passwords; in the real-world, you don't need to remember how every key on your keychain looks like. So I thought: what if you could have a keychain that keeps your digital keys for you? Zamek is the answer.
I turned to the physical keychain for inspiration, as a physical keychain is already very easy to use. When you need to unlock something, you choose the right key, insert it into the lock, and turn.
Zamek was designed to open your electronic locks as easily as a regular key opens physical locks, with an additional layer of security in case someone other than yourself picks up your digital keychain. The process can be described as:
1. Unlock your Zamek using a security PIN you choose
2. Use Zamek's joystick to change the account displayed on its screen to the one you wish to unlock
3. Insert the Zamek into your computer's USB port
4. Press the joystick to enter the password for the account
Zamek will type in the currently selected password into any field on your screen you select. If there is no USB port available, you can read the password for the account on Zamek's highly visible OLED screen and type it in manually.
Entering your account information into Zamek is intuitive and simple. After you enter your information once, it is stored permanently on Zamek's built-in memory. Your information is encrypted with an industry-recognized AES cipher, which means that if your Zamek is ever stolen, criminals will not be able to extract your information.
Zamek was designed to be your electronic key to the digital world. Smaller than a car remote, it easily clips to your keychain and can be carried everywhere. It features a highly visible screen and a long battery life, which is topped up every time you plug Zamek into your USB port. The joystick is comfortable to use, and the interface is intuitive enough to not require an instruction manual after the first set-up. Additional features currently in consideration are secure formatting and backup/restore options.
All the code and schematics for Zamek will be published under an Open Source license. This mean that anyone can read, validate, and critique the design of any part of the Zamek openly. My desire is that the Open Source process will lead to a device which is ultimately more secure, completely trusted, and reproducible in case I am not able to produce these in the future.
Lastly, Zamek is completely yours to own and use. It protects your data in a personal, respectful, and dignified manner: Zamek does not "phone home" to any remote servers, and it does not store any information anywhere other than its secure memory. Your information will never be anywhere but in your pocket.
  • 1 × ATMega32u4 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × OLED screen
  • 1 × Custom designed circuit board
  • 1 × Lithium battery
  • 1 × Custom designed enclosure
  • Short Progress Update!
    jarek31901/27/2018 at 03:33 5 comments
    After a ton of excellent feedback regarding IP68 protection, I have decided to use buttons instead of a trackball for the initial version of the Zamek. I will keep the code for the trackball in comments and possibly revisit it for version 2, but right now my priority is to get this out the door soon!
    I'll finish testing when my battery comes in, then start looking at simple watertight enclosures. I'm thinking clear silicone?
  • ( Hopefully ) Final Zamek Design
    jarek31905/12/2017 at 23:26 1 comment
    Sorry about the lack of screen! I couldn't wait until the screen came to start fitting it together :)
    I'll take more pictures after the screen comes in. In the mean time I'll explore whether this case design is viable for production, or try to come up with a more manufacturable solution.
  • Video Review
    jarek31904/18/2017 at 18:11 0 comments
    I sent a spare Zamek beta unit to a Youtube Electronics Channel; check out their take on it here!
  • Back On Track!
    jarek31904/18/2017 at 18:06 0 comments
    Exciting news! After much waiting, I've finally found an easily source-able battery to use for the Zamek, meaning I can finally fit together an attractive case :) The first draft of the case has been sent to Ponoko; stay tuned!
    Some background: Zamek has been on hold for a while as I searched for ways to easily create a case that fit around the strange shape consisting of the Screen/Battery/PCB sandwich with the trackball right next to it. Every solution that was attempted was either ugly or impractical to produce.
    I recently got my hands on some ultra-thin batteries, only 1.5mm thick! These guys don't hold a lot of juice ( 30mAh ), but my calculations estimate that that's enough to check your password about 700 times before you need to top up ( 15 seconds of on-time at 10mA avg draw ). I'm working with the battery manufacturer to see if we can push the charging rate of the battery up to 2 or even 4C, so the battery could be charged in a matter of minutes. Case parts should be in early next week, next update then!
  • Final Hardware Revision
    jarek31909/09/2016 at 02:35 8 comments
    After some back and forths with designing the case, I realized that it would be much easier to produce the device if I re-engineered some of the sticking points around the previous design. So I cleaned up the entire back of the circuit board so that it can sit flush up against the housing. I also added a trackball for faster and more accurate navigation.
  • PCB and Assembly by MacroFab, Launching on CrowdSupply!
    jarek31905/10/2016 at 03:17 0 comments
    Latest PCB Revision, fabbed and assembled by the fine crew at www.macrofab.com !
    I'm working on putting together a group-buy campaign for a batch of these with attractive cases! Sign up at https://www.crowdsupply.com/soniktech/zamek to find out when you can sign up for your own!
    This project will release its source files, containing board layout, source code, and enclosure designs, on the day the campaign launches, all published here on https://hackaday.io/project/3555-zamek-the-offline-pocket-password-manager !
    See all the details: https://hackaday.io/project/3555-zamek-the-offline-pocket-password-manager
    Here is a video showing the screen layout and data entry using the joystick: https://hackaday.io/project/3555-zamek-the-offline-pocket-password-manager/log/33748-drum-roll-please
    There is also a PC app planned which will provide backup and restore to hard disk functionality, as well as make inputting credentials to your Zamek easier: https://hackaday.io/project/3555/log/36334-pc-app-is-functionally-finished
  • Short delay as I'm waiting for displays to arrive
    jarek31904/27/2016 at 13:57 0 comments
    The next PCB revision is in, but my display vendor has delayed shipment of my order. Expect pics of the new revision some time next week!
  • Adding Storage and Increasing Security
    jarek31904/21/2016 at 00:20 0 comments
    A bare ATMega32u4 has 1KB of EEPROM. This means that by itself, it can store 20 typical account entries (consisting of a 16 character site name, a 16 character user name, and a 16 character password). In order to expand this repository, I have added on a footprint for common EEPROM chips. This will allow up to 100 accounts to be stored!
    I'm also starting to think of ways to implement an additional layer of security to secure the EEPROM payload against brute-forcing attacks. This usually means taking the route of longer keys and/or longer computation time. I thought about all the literature I've read on the subject and parsed through chat logs with the excellent folks on the Hacker Channel chat, and am thinking about writing a method to encrypt the EEPROM with a very long key that would be stored in the microcontroller's RAM. This key would itself be encrypted with the relatively shorter PIN. This means that if an attacker simply tries to dump the EEPROM, they would be met with a very resistant payload. If the attacker were to try to dump the RAM, they would likely erase the contents of the RAM in the process (I'll give the chip a warm jacket in case security researchers try to freeze the chip ;) ).
  • PC App is Functionally Finished!
    jarek31904/20/2016 at 05:09 0 comments
    All the features are finished and tested: reading and editing individual accounts, and full encrypted EEPROM dumps and restores. Now to give it a good helping of UI design :)
  • PC-based Credential Entry
    jarek31904/15/2016 at 20:55 0 comments
    One of the biggest 'asks' has been "can I use my PC to enter the credentials more quickly?"
    Now you can. Still a WIP, need to clean up the UI and figure out how to do terminators, but it definitely works!
View all 16 project logs
PointyOintment wrote 12/05/2014 at 09:37 point
I disagree with your tagline:
66
99
I use LastPass, which can automatically fill in my username and password and click the "log in" button as soon as I load the site. I don't see how this can be more convenient than that.
[deleted]
PointyOintment wrote 12/06/2014 at 02:04 point
Ah, good points. Will this emulate a keyboard, then? And how will you find entries on it (i.e. input a website name to get a password)?
I do like the idea of generating passwords dynamically by selecting from a large random table according to a PIN. I'm not sure about the security implications of that, though.
jarek319 wrote 12/07/2014 at 23:25 point
Navigation is the secret sauce to this project :) Stay tuned!
Keyboard emulation will be one of the first things I will add after making sure the security of the generated passwords is acceptable for tech folks like us. It is a Trinket Pro after all, so it should be an easy addition.
