Hackaday.io Hackaday.io
Sign up Log in
Mitten Heater
A Trinket powered mitten insert that provides heat and uses a Neo-pixel for displaying info
jesse-millwoodJesse Millwood
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
23 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
427
0
23
2
Team (1)
  • jesse-millwoodJesse Millwood
Join this project's team
  • Mitten Heater
hardware
ongoing project
Neopixel TRINKET heater Mitten
This project is submitted for
  • The Trinket Everyday Carry Contest
This project was created on 12/17/2014 and last updated 11 years ago.
Description
I decided to look into this project because I seem to have bad circulation in my hands and walking to school (about 20 min walk) causes me to loose sensation in my fingers on cold days (around freezing and bellow). I live in Michigan and it gets cold here sometimes, so mittens in general don't totally prevent it. I had a spool of Nichrome wire laying around a decided to give this a try. The project is powered from a 3.7V 1000mAH Lipo battery. Status and info is displayed on a 16 LED Adafruit Neo-pixel ring. The user will be able to adjust the heat with two tactile buttons. The 3V3 ATmega328P version of the Adafruit Trinket will be used to control everything. The Nichrome wire will be controlled with a PWM from the Trinket. I am designing the circuit in KICAD, taking notes in emacs org-mode, and the project files are hosted on github.
Components
  • 1 × Trinket 3V3 ATmega328P
  • 1 × Nichrome Wire Heating element
  • 1 × NeoPixel Ring 16 addressable LEDs
  • 1 × Li-po Battery 3.7V 1000mAH
Project Logs
Collapse
  • Ordered Parts
    Jesse Millwood • 12/20/2014 at 23:16 • 0 comments
    I ordered my parts from Digikey
  • Ordered Board
    Jesse Millwood • 12/19/2014 at 14:52 • 0 comments
    I just placed an order for my board with Seeed Studio
  • Finished BOM
    Jesse Millwood • 12/19/2014 at 11:03 • 0 comments
    I finished the BOM up today with some functionality built into kicad. As I design a project I associate part numbers with the symbols in the the schematic so making a BOM is easier later. I also sent my gerbers to 4pcb.com so if that goes well this morning, I will hopefully order my parts and board.
  • PCB Layout Done
    Jesse Millwood • 12/19/2014 at 04:58 • 0 comments
    I finished a rough pcb layout. It could be a little more compact and organized better but I would really like to get this out to fab soon.
  • Schematic Done
    Jesse Millwood • 12/17/2014 at 14:40 • 0 comments
    Finished the schematic today
    Ordering the parts from Digi-key
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Wearable led ring watch with way too many functions
Project Owner Contributor
Design of a Watch
edscalatieedscalatie
Replacement boards for a cheap commercial cable tester
Attiny24 Network Cable Tester
jnp-3rJNP-3R
You can get 10 pcbs from most manufactures for cheap if they are under 100mm on each side. Let's make some shapes.
PCB Decahedron
ian-shannon-weberIan Shannon Weber
A Project page to host and blog about my various analog audio circuit experiments and designs.
Audio Blox: Experiments in Analog Audio Design
avrAVR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Mitten Heater", please tell us the reason.
Send message
Remove Member
