Mini-PCIe - PIC18LF2550 - DevBoard
Use your PIC-Projects on Mini-PCIe (USB/SMBus)
DEVBoard for Mini-PCIe and PIC18LF2550.
Control over USB and SMBus(i²C), Flash over USB
Build your own Hardware for your PC
Features:
  • Flash the PIC18LF2550 over USB
  • Transfer Data over USB and SMBUS(i²C / Slave)
  • Controll the Status LEDs from Host (WPAN/WLAN/WWAN-LED)
  • Proto-Area on the Top Side
  • All Free GPIOs on the Top Side (3 x I/O, 9 x Analog or I/O, 1 x SMBUS(I²C), 1 x UART or 2 x I/O)
18f2550_g.lkr
New Linker script for gputils. - Programm space after 0x000800 - High Interupt Vector on 0x000808 - Low Interupt Vector on 0x000818 - Protected Areas
lkr - 1.74 kB - 12/01/2016 at 18:02
Download
bootloader.hex
Bootloder V5 from Sprut.de whit EEPROM FIX
x-hex - 88.83 kB - 12/01/2016 at 09:48
Download
PCIe-PIC-BOARD.brd
Eagle Board V1.3
- 98.40 kB - 12/01/2016 at 23:27
Download
PCIe-PIC-BOARD.sch
Eagle Schematic V1.3
- 362.49 kB - 12/01/2016 at 23:27
Download
fsusb-PCIe-ID-ff0b.tar.gz
Fsusb with the changes for the bootloader USB ID: 04d8: ff0b
gzip - 30.70 kB - 11/22/2016 at 09:36
Download
View all 5 files
  • 1 × PIC18LF2550 - SOIC Microcontroller
  • 1 × 8Mhz Resistor
  • 4 × 10k - 0603 Resistance
  • 1 × 220p - 0603 Capacitor
  • 1 × 100n - 0603 Capacitor
  • 1 × 100mA - 1808 Fuse
  • New PCBs
    Knudt01/12/2017 at 10:14 1 comment
    After the last error I now have the new boards these are the final version.
    I can now start testing all the functions.
  • LED Blink Test
    Knudt12/23/2016 at 13:43 0 comments
    A little Blink WWAN LED - Test on the V1.1 Board (Comments will be translated later), Write the Little Code with mpasm.
    main.asm
    	;list p=18f2550
    	include "p18f2550.inc"
    	org	0x000800		; Starte Programm
    	goto	init
    	org     0x000808		; Interuptvector High
    	; call or goto blablub
    	org	0x000818		; Interuptvector Low
    	org	0x000828		; Erste Rotine auf Adr. 0x820
    	cblock	0x00			; Variabeln ab 0x00
    	t1				; Delay
    	t2				; Delay
    	t3				; Delay
    	endc
    	#define WPAN	PORTC,0		; WPAN LED
    	#define WLAN	PORTC,1		; WLAN LED
    	#define WWAN	PORTC,2		; WWAN LED
    	include	"portreg.inc"		; Ports einstellen (portreg)
    	include "delay.inc"		; Software Delays (delay)
    	;include	"i2c.inc"		; I2C Routinen
    init
    	call	portreg			; Ports einstellen
    main    				; Mainschleife
    	bsf	WWAN
    	call	delay_1s
    	bcf	WWAN
    	call	delay_1s
    	goto	main
    	end
    delay.inc
    delay_1s
    	movlw 0x6d
    	movwf t1
    	movlw 0x5e
    	movwf t2
    	movlw 0x1a
    	movwf t3
    loop_1s
    	decfsz	t1, 1
    	goto	loop_1s
    	decfsz	t2, 1
    	goto	loop_1s
    	decfsz	t3, 1
    	goto	loop_1s
    	return
    portreg.inc
    portreg	; PORTA
    	movlw	B'00000000'		; PortA I/O setzen (1=In, 0=Out) (Reinfolge RB7,RB6...)
    	movwf	TRISA			; PortA I/O setzen
    	clrf	PORTA
    	; PORTB
    	clrf	PORTB			; PortB auf 0 setzen
    	clrf    LATB			; Data Latch löschen
    	movlw	B'00000011'		; PortB I/O setzen (1=In, 0=Out) (Reinfolge RB7,RB6...) (I2C Slave RB7/RB6 = input)
    	movwf	TRISB			; PortB I/O setzen
    	movlw   B'00001111'		; Alle I/0 Digital
    	movwf	ADCON1
    	; PORTC
    	movlw	B'00000000'		; PortC I/O setzen (1=In, 0=Out) (Reinfolge RC7,RC6...)
    	movwf	TRISC			; PortC I/O setzen
    	clrf	PORTC			; PortC auf 0 setzen
    	return
  • Find the Fail;-(
    Knudt12/21/2016 at 11:40 7 comments
    Wait long Time for the new PCB, Error from me and OSHPark, OSHPark forgets the VIAs and I order in the wrong thickness, i Order new and wait for the New One.
    Lock very nice its better as the First Version and not usable.
    Can you see whats is not ok ?
  • Order Version 1.3 / Bootloaderfix
    Knudt12/01/2016 at 10:05 2 comments
    - New version V1.3 ordered at OSHPark, some minor improvements, Quartz changed.
    - Fix for the Bootloader, the EEPROM is now nullified by default, otherwise the first Programm will not start.
  • Wiring diagram
    Knudt11/24/2016 at 22:05 0 comments
  • Work on the next Version
    Knudt11/24/2016 at 11:10 0 comments
    Work on the next version, the first version is usable but not good enough for me.
    Changes:
    - Other Crystal
    - Fix placement pressure
    - Fix overlaps on the connector
    - Remove Bootloder Jumper (JP1)
    - Other Protopads
    - Fix minor things in the libs
    - More Bling Bling;)
  • Bootloader Works
    Knudt11/22/2016 at 00:58 0 comments
    I use the Bootloader V5 from
    Http://www.sprut.de/electronic/soft/usboot/usboot.htm (German Page)
    Https://goo.gl/Z53QYX (Translated Page)
    This starts after the reset when RE3 is at GND, or when the EEPROM cell with the address 0xFE has the value 0xFF.
    Drivers / Tools for Windows are included in the USBoot package (Not Tested),
    For Linux I use a customized version of fsUSB (http://www.internetking.org/fsusb/), or Piklab.
    The device has its own USB ID:
    Bus 004 Device 002: ID 04d8: ff0b Microchip Technology, Inc.
  • PCBs V1.1
    Knudt11/21/2016 at 18:24 0 comments
    PCBs from OSH Park with some layout errors.
    - Quartz footprint with too much soldering resist
    - Smaller errors in the placement pressure
    For initial tests the PCB is usable.
  • Test Tool
    Knudt11/19/2016 at 12:52 0 comments
    Order a Test Tool for USB, to Test Power consumption, the connection and other things.
    https://aliexpress.com/item/Mini-PCI-Express-pcie-pci-express-PCI-E-Wireless-WWAN-to-USB-Adapter-Card-with-SIM/32657444139.html
  • PCB-Order PCB V1.0
    Knudt10/27/2016 at 16:17 0 comments
    Long time ago ;(
    Order a Proof of Concept PCB, wait for it, ETA ~3-4 Weeks ordert by OSH-Park
View all 11 project logs
profecie wrote 03/30/2017 at 17:15 point
Very useful project
Thank you
Is it possible to have reference for quartz/resonator on mouser or farnell ? I didn't find quartz with right footprint?
Knudt wrote 03/31/2017 at 21:33 point
I've found at no with 8MHz but one of the fit.
Http://en.farnell.com/ael-crystals/c16m000000s004/resonator-sm-16mhz-cv/dp/1448145
The footprint is a little different because it is otherwise difficult to solder the parts.
bobricius wrote 03/11/2017 at 23:52 point
Great project, I am very inspired and I creating Samd21 variant ;-)
Knudt wrote 03/12/2017 at 09:56 point
I think it is very good that my small circuit board, as a template for other projects serves, am already excited.
bobricius wrote 4 days ago point
Boards assembled and I thik all working :) Thanks for inspiration ... https://hackaday.io/project/20295-mini-pcie-micropython-arduino-zero-sam-d21
davedarko wrote 11/22/2016 at 19:23 point
much gold. such wow.
danjovic wrote 10/28/2016 at 17:25 point
Amazing project. Didn't knew it was possible to connect a microcontroller directly to a mini-PCI slot!
Knudt wrote 10/29/2016 at 07:57 point
Mini PCIe has USB and SMBUS (i²C) on the connector, i use the Status LEDs from Host, Planing for the Future use the SIM-Card Socket from my Nettbook it´s can Controlled over the PCie Bus.
