NEW DIGIBOARD , DSP XMOS STM32H7 , USBC, GB ETHERNET, TWIN SD CARDS, TC IO, TXCO RTC
NEW DIGIBOARD
8 channels AES3
AVB gigabit ethernet audio
AES3 IO
USB C PC/MAC DAW connectivity
TXCO RTC for accurate time of day ( Timecode )
Individual Timecode IO , JamSync
Dual RF modules for digital audio link to camera ( or possible timecode to sync boxes )
NEW ANALOGUE BOARD
isolated digi opto power switching for the preamps ( power saving )
8 balanced 10 - 65db preamp cards on 1.27mm headers ( phantom power and 0db line level )
4 balanced line drivers cards
2 x very high quality headphone cards.
preamp front end limiters
Voltage monitoring
started printing 3d cases to try and get a design worth making out of aluminium or carbon fibre.
experimenting with changeable connector plates.
It's Alive !!! here's the 1st test recording for historic reasons :)
https://soundcloud.com/benbiles/bbbox-proto1-recording-48khz16bitwav
here's an old real-time audio meter input demo. was another mile stone!
The Bluetooth App does a lot more now also ! FX compressors LP HP filters etc.
_______________________________________________________________
The beginning , learning how to use SPI and I2C. I believe this ever worked :)
ben biles
Matt
Davide Ercolano
Stephen G
lion mclionhead
Hello, did you manage to get communcation setup for gain control etc. with the PGA2500? Really interested in using this preamp on my own project but the software side control is unclear to me as of now.
