New TFT colour screen
10/14/2026 at 00:29 • 0 commentsA lot of updates !!!!
FS switching 48khz 96khz 192khz from app
4 colour TFT on SPI bus with Realtime metering.
AVB working and FS switching from the APP on the way.
LTC timecode fully working with LTC input output on the mini jacks on the front.
Jam Sync is functional but basic.. plug in LTC to input and it autoJams with side by side on display.
New proper Android App written in Kotlin ( App inventor no longer needed )
New digi-board has FPGA for 8 x AES3 input with SRC and 4 x AES3 output
Dual card recording fully working with auto file recovery on power interruption !
I am thinking of moving headphone connectors to front panel to make room for larger ADC DAC card ( upgrading to CS4308P which is current so need OPAMP I/C conversion on the ADC DAC card , so need more room there ! )
back to 3d print case and screen on the side
12/12/2025 at 02:13 • 0 commentsmoved the screen to the side of the case.
made the case with corner parts that I can get professionally 3d printed in metal.
The panels I can then get laser cut when I have finalised the design layout.
The little green light at the back of the picture is the new clock controller which is used for AVB.
see my new AVB USB interface project.
clock timing of the whole device can be controlled by AVB to keep the field recorder in sync to other AVB devices / whichever device is clock master.
there's still work to be done with changing MCLK from 48khz to 44.1lkhz clock types. MCLK can be changed via I2C from XMOS , the XMOS also has an I2C slave port defined and connected to the STM32H7 so it can control the MCLK settings.
As soon as I have finished coding AVB auto stream connect for PTP mode to the USB AVB interface board ( no AVB switch required then ) I will be moving onto a new digi board 6 layer layout.
The fuzz on the screen is an old issue I had for not including OLED screen reset so sometimes when you switch on the device the timing is off and OLED does not initialise properly.
Another small issue to fix in the 6 layer design.
New motherboard
02/13/2025 at 05:19 • 0 commentsI started work on the new motherboard that integrates the power cards , power monitoring as well as all the signal cards.
The main change is that aes3 card will no longer have the connectors on it. It has an fcp header brake our on the motherboard that goes to the main IO connector card. This gives me a bit more flexibility with the case design .
The legacy 2.54 headers for line driver cards and HP driver cards are still here! I need to change those for 1.27 headers and add more ground connections and bring in DAC Vcom through the header and loose the JST socket. Doing this means remaking 4 balanced line driver cards and 2 HP driver cards !! This is the down side to a modular card design !
The next revision of the motherboard will get that change I think. At least the new aes3 driver card is 1.27 header.
I'm keeping the old motherboard for testing. Running the current digi Baird that will updated next.
time to make a metal case !
12/03/2024 at 06:05 • 0 comments![]()
The corners allow the panels to be removed so I can 1st 3d print the panels with the connector holes in place to make sure the boards and connectors etc all fit.
after that I will use the plastic panels as templates and copy it to aluminium , drill cut etc.
I will get the corner parts 3d printed in metal or CNC'd
The plastic bolt heads are only there for fast access while its still being programmed.
There is some flex in the 2 long side panels so I will need some more support there.
The 2 main digi and analogues pcbs sandwiched together fit exactly and they will have some kind of plastic mounting in between them both with bolts securing them in place through the long side panels. that maybe be enough rigidity to stop any flexing.
I also need to mount the OLED screen in the side panel near the power supply. its going to be tight !
BBBOX gets used in the home studio as an 8 channel usb DAW interface
09/29/2024 at 13:08 • 0 commentsThe best way to find problems with a device is to use it !!!!
This is where you find essential things like having the device start in the last used state is really important.
At the moment the settings are all sent from the APP when the APP starts. It can be really annoying using this device
as a USB interface and have to start an app to get to the default gain or routing settings etc
I think I need to think about having the user settings stored in the Micro flash memory so It can just start in the *last used state* without
even needing to start the app.
Also , maybe some control should work over USB midi. not really sure about that though.
I am working on a flexible monitor routing matrix which is nearly done. this allows any of the USB output 8 audio channels from the DAW to be routed to any outputs of BBBOX audio drivers ( headphones balanced line outputs etc eas3 etc )
The SD card media cannot be mounted from the MAC / PC , seams unlikely it will ever happen since the SD card is controlled by the M7 cortex and not the XMOS. not necessarily impossible but sounds difficult. It would probably be easier to just add another USB socket from the micro for this purpose. or just take the card out and put it in a card reader!!!
sometimes I think this project would have been better just running with a proper OS like raspberry PI linux etc but that would require quite a lot more power and this is meant to be a low power device.
weird DAC output fixed
11/30/2023 at 10:00 • 0 commentsI must have blown the DAC by inserting a car incorrectly at some point.
changed the DAC IC and its sounding GREAT!!
I have the balanced outputs going into a Tascam LA40 mk2 so I can listen to the outputs on monitors and I'm using an old Behringer 4 channel Ultra Pro DI rack for testing mixing lots of channels at the same time.
The idea is I actually use this box for PC TV Alexa and whatever rubbish I use at home to test long term stability. does it crash , over heat and all that ! so far so good.
I've set the main faders to mix from -inf dB to +16dB and the main output faders from -inf dB to +18dB
Line Driver buffer clipping
11/27/2023 at 00:27 • 0 commentsI have only just found time to check the differential line drivers cards. They are way off !!
I have clipping on one side.
I have measured after the DC blocking caps between the biased buffer op amp and the line driver IC ( That 1606 )
I think I need to check what's happening before the blocking caps now and try and figure out why the output of the buffer opamp is 1.25V peek on one rail and clipping at 1V on the other !
8 pre amp cards loaded !
03/19/2023 at 18:18 • 0 commentsHere's a pic of all 8 preamp cards with 4 balanced line driver card loaded.
The headphone card gets warm , so I'm only running 1.
The protection diodes on the rear of the preamp cards are in the way of the SMD electrolytic caps ( they moving over about 10mm )
They were added to protect the PG2500's against voltage rail error !
The next job is to code the +-5v rail monitoring on the MC and have all the channels immediately shut down if there is a
voltage rail deviation > 0.1V
The would have preferred there protection diodes to be on there too ! next revision I'll move them over 10mn so they are well
clear.
This is all part of learning how to build multi board designs !
The gap between the balanced line drivers and preamps is tight but ok.
you can see the analogue IO panel FPC connector just fits.
I'm thinking of stripping a lot of the 3d printed box away so it's just a frame and then
using aluminium panels to make up the sides and connector panels of the box.
my 1st manufactured PCB cards !
01/08/2023 at 15:54 • 0 commentsExciting times :) !! I have ordered my 1st run of cards at PCBway pick and place !
Here are my 1st ever professionally manufactured boards :)
There are only 10 cards , but the parts are not cheap !
https://www.pcbway.com/assembly-process.html did an amazing job here guiding me through the world of having a correct BOM ( bill of materials ) and checking everything from part orientation to proper part / footprint matching !
They part sponsored the project by reducing the pick n place / manufacture cost by 50% which was really helpful. This is not why I am writing a positive review about them though. I am free to write what I want here !
They really did have a ton of patience with me and my stupid mistakes on this. I can't recommend you use this service enough if you have never had a board professionally manufactured. You can send your own parts or have them source the parts locally. some parts I had to send them as they are difficult to source in China due to the current situation. but its easy to send parts directly to them.
On this version of the preamp I have VCOM from ADC coming in through the connectors.
I also reduced the size of the phantom blocking caps as it was taking to long to drain them and causing problems with the PGA2500. The lower value 22uF blocking caps should slightly increase bass filtering slightly but so far I can't tell the difference from using these or the 47uF blocking caps. apart from the faster drain time when phantom power is switched off. When phantom power is switched off or on the DSP mutes the inputs for 1 second in case of large banging noise etc. this time was reduced using the smaller blocking caps.
I need to glue the caps onto the PCB myself but I opted to do this myself to save time.
As you can see the solder reflow is really nice !!! especially on the PGA2500 and OPA1637
diode protection on rear for power protection and phantom power short protection
One thing I can say , using KiCad you often just choose a generic symbol / footprint for resistor or capacitor etc and have in the back of your mind what actual part you will use. this is really bad practice since when you output your BOM there are to many empty holes as far as manufacturing are concerned. it might be just a 10k 0603 resistor to you , but they need to know exactly what part to order for you !!!!! its so easy to overlook when outputting a BOM ! worse still a really bad habit of mine is to just use say a resistor footprint for say a capacitor or ferrite bead !! don't do it !! you will forget and the factory could easily choose the wrong component.
Anyway , thanks to PCBway they fixed my stupid mistakes and got me some really nice working preamps for the BBBOX mixer recorder.
here's a few pics of a card inserted !
note , FPC cables to ADC/DAC card and ext connectors to :)
switching battery / ACDC adapter testing
12/01/2022 at 10:40 • 0 commentsSEE PREVIOUS LOG FOR DESIGN NOTES
Its working but next revision I think I will change the priority to the mains ACDC power input if both battery and wall adapter are plugged in! basically swap the 2 power input wires around :)
ben biles
