Hackaday.io Hackaday.io
Sign up Log in
Micro Word Clock
Displaying the time on 8x8 pixels.
danielDaniel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
10k views
19 comments
670 followers
  • Description
  • Details
  • Files 0
  • Components 9
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 19
View Gallery
10k
19
670
124
Team (1)
  • danielDaniel
Join this project's team
  • Youtube
  • Github
  • OSH Park (PCB)
hardware
completed project
clock LED MATRIX RTC The Square Inch Project
Related lists
Square Inch Project Entrants
Projects that fit in a square inch
Atmel® AVR® Projects
Atmel® AVR® 8- and 32-bit MCUs deliver a unique combination of performance, power efficiency and design flexibility.
Projects using OSHpark boards
projects using the purple PCBs
LED Matrix Projects
so much LEDs
Clocks
clock projects
Browse related lists
This project was created on 10/06/2015 and last updated a year ago.
Description
A tiny replica of the famous Word Clock, using only an ATmega microcontroller, a DS1307 Real Time Clock and a few passive components to display the time on an 8x8 LED matrix. The letters have been printed onto a transparent sheet and glued over the LEDs to produce a readable time. The LED matrix used is 20x20mm, and so is the PCB behind it! :-) 20 mm = 0.79 in 400 mm² = 0.62 in²
Details
Components
  • 1 × ATmega328P-AU Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × DS1307Z+ Clock and Timer ICs / Real-Time Clocks
  • 1 × 220nF ceramic capacitor 0805
  • 1 × 2.2uF tantalum capacitor B-size
  • 1 × 32.768kHz crystal 3216 metric size, 1206 imperial size
View all 9 components
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Manuel Domke wrote 03/20/2017 at 16:29 • point
It is so great.
I *just* made a solar powered pocket word clock based on the PCB.
Together with a ME4056 lipo charger, coin cell, 30mA solar panel, 2 buttons (on/set) in a 51x35x15mm plastic case. Maybe I can send you pictures to publish here?
Thanks for sharing this!
EngineerAllen wrote 01/31/2017 at 19:04 • point
can you make it brighter?
chmod775 wrote 01/29/2017 at 20:37 • point
Cute and very well designed! Great work man.
lalalandrus wrote 09/03/2016 at 10:19 • point
Your project inspired me to make this.
https://hackaday.io/project/13431-iot-led-matrix-projector-clock
Daniel wrote 09/03/2016 at 19:19 • point
That is awesome! I like it :) I should try a projector build someday...
Pabluski wrote 12/12/2015 at 23:47 • point
I made a similar version, based on Daniel's, that can switch among English, Spanish, Dutch, and French.  http://pablo-sanchez.com/8x8-word-clock-with-rtc/
I can share the language layout if you are interested.
Andrew Albosta wrote 12/12/2015 at 02:03 • point
I built my own last year after I saw HaD post about it and decided to give SMD soldering a shot. My blog post about the process: http://www.andbosta.com/building-the-micro-word-clock/
Daniel wrote 12/12/2015 at 08:15 • point
Wow, fantastic writeup!
PinheadBE wrote 12/12/2015 at 01:08 • point
Fine project.  Would "skull" if a French version would be available on 8*8 dot.  Super mega bonus for a bi-langual version (I know: this is a cruel challenge, almost unreachable)
Daniel wrote 12/12/2015 at 08:07 • point
Hi,
thanks for the comment! :-)
You are free to try your hands at the French version. So far, people have contributed Dutch, Hungarian and Spanish versions! (See GitHub)
PinheadBE wrote 12/12/2015 at 11:40 • point
I made one, but on a 14x9 matrix. It wasn't a watch, and I didn't have your space constraints.  On the other hand, I didn't want to have the words cut.
I will try to make a 8x8 french one.  It must be possible...
I'll keep you posted
alpha_ninja wrote 12/07/2015 at 00:28 • point
Double-checked your design: you're missing gerber files.
Daniel wrote 12/07/2015 at 17:58 • point
Thanks! They've been added to GitHub! :-) Hope a .zip is fine
alpha_ninja wrote 12/07/2015 at 19:58 • point
Absolutely :)
alpha_ninja wrote 12/02/2015 at 00:47 • point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
Arduino Enigma wrote 11/27/2015 at 05:15 • point
Cool project. Anything worth doing is worth miniaturizing.
zakqwy wrote 11/09/2015 at 15:29 • point
Think you could add a battery and a few PCB-mounted wrist strap attachment points? This would make an awesome watch!
danjovic wrote 10/06/2015 at 13:09 • point
Amazing idea, design and build! Congrats, pal!
Daniel wrote 10/06/2015 at 14:02 • point
Thanks! :-)
This LED matrix clock displays the current time using signals received from the GNSS satellites orbiting the earth!
Project Owner Contributor
Digital Satellite Clock
cpknightcpknight
A 14-segment LED display that shows the time in both numbers and words.
Word Clock
david-plassDavid Plass
Clock made of 512 Led's
Clock 512
saarbastlersaarbastler
A programmable, pixelated WiFi analog+digital clock the size of a credit card
Foxie CardClock
will-fox-foxie-productsWill Fox (Foxie Products)
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Micro Word Clock", please tell us the reason.
Send message
Remove Member
