Introduction
OpenCube is a 3D-printable filter cube implemented using OpenSCAD. OpenCube can house round filters and rectangular mirrors of any size. It can also be connected to any lens tube by insertion of a retaining ring into a filterFace. OpenCube overall size, as well as sizes of all housings can be easily adjusted by editing parameters in a setup file.
OpenSCAD files available on GitHub.
Components
OpenCube consist of a frame, which provides a structural support, a set of faces that allow to customise the functionality of a cube, and a mirror holder that positions a mirror in the middle of the cube. An overview of all OpenCube components is given below.
Square components
Triangular Components
Hi!
I love your project!
You've probably seen this other project, but just in case you haven't: http://publiclab.org/wiki/spectrometer . Maybe you can get an idea from it or something. :D
Good luck with the open cube! Looks nice so far.
Cheers
