As a proper hacker space i thought we also need a proper prototyping platform and i also wanted to try out dirtypcb
Features
22pin IC header with all pins connected to the vias next to them
2x strain relief for power cords (the larger hole vias)
lots of connector points
c-base silkscreen
Finally i have them in my Hands. The new revision of the protothing. As the last revision also ordered at DirtyPCB's the 50x50mm PCB Protopack - got 11 of the +/-10 boards they say. I really love the fact that i do not need to pay extra for the black soldermask that is maybe not always the best choice but for a c-base board needed. The print is on the top is a tiny bit off but nothing bad. Will order again.
The first thing i try is to create a small Arduino clone with regulated 5 V just to see how good the idea with the power section at the bottom works.
And as the last batch, i will also spread them to c-base members to see what they will come up with. Maybe if all the other that will get a board say this is good i will order a bigger batch.
Sieht super aus, Grüße aus der Warpzone.
