Microchip PIC Arduino based programmer
I love to program programmers. Yo dawg...
This is more software than hardware project running on vanilla Arduino, but for sake of completeness I'm going to build simple dedicated hardware instead.
More to come.
For #Micro progmeter project I want to deliver full set of open-source materials, but it would be shame if folks trying to replicate the project would have to buy another programmer to flash the PIC MCU, so I decided to do a little bit of brain stretching and implement PIC16F1xxx programmer with... Arduino, just because it is low cost and available platform.
Together with SDCC compiler this serves as completely open-source basis for PIC16F1xxx and similar projects.
The current project status: Programmer working, sources need cleanup.
SUPPORTED DEVICE LIST - see readme at github
  • 1 × ATmega328P Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Crystal 16MHz
  • 1 × FT232RL Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 2 × LED 0805
  • 6 × 470Ohm resistor
View all 9 components
  • version 0.96
    jaromir.sukuba13 hours ago 0 comments
    After nearly two years, I refreshed this project again.
    Apparently, Microchip introduced new programming specification for newer PIC devices, like PIC16F1xxxx and PIC18FxxK20 and PIC18FxxK22. The old format was LSB first, either with mix of 8/14 bit long words (for PIC16Fxxx) or 8-bit long words, but a lot of direct instructions entering (PIC18). This seems to be unified now (see the famous XKCD comics) with MSB-first and 8-bits only words. Nice initiative, only if there were already a few different formats among PIC devices.
    Honestly, I was too lazy to implement it, but there is already quite a few "new format" devices in the wild, so I finally got myself to add it to pp3 programmer, so here you go. Only PIC16F188xx are added, but more will follow.
  • pics of PICs, version 0.95
    jaromir.sukuba09/16/2016 at 11:15 1 comment
    Today I made some more progress. I added support for more PIC18FxxKxx devices, so the total supported devices count is 305. There will not be much more of them.
    I tested a few new ones, including PICs in TQFP package. Unlike for DIP packages, breadboard and wires are not enough, so I had to use TQFP adapter I made few years ago for PIC24 and PIC32 series, but with single cut trace it works for PIC18 too.
    There is nothing more than micro and decoupling caps. By the way - JS09 really means year 2009. The time flies.
    For this adapter I made simple testbench of perforated PCB.
    With this one I tested PIC18F66J15, 67K22 and 67J50, each on its own breakout.
    And this is gallery of all PIC devcies I programmed with this Arduino programmer. Every single MCU here has blink a LED program flashed. Much blinking power, very wow.
  • version 0.94 - PIC18FxxKxx CAN devices added
    jaromir.sukuba09/14/2016 at 16:42 0 comments
    In version 0.94 I added support for CAN devices like PIC18F25K80, 12 new in total. New firmware is released too.
    Everything is on github.
  • version 0.93
    jaromir.sukuba09/12/2016 at 09:28 0 comments
    I hunted a bug with programming PIC18F24J10, but finally I got it working - so version 0.93 is out.
    I ordered some more PIC18FxxJxx devices to test the programming protocol implementation. After tested, I'm going to do the final sources cleanup and release version 1.00.
    Files are on github, as usual.
  • Version 0.92 - major rework
    jaromir.sukuba09/09/2016 at 11:14 0 comments
    I reworked the MCU selection code. The if-then structure was OK for dozen of devices, but with more than 200 supported MCUs, it became messy. So I rewrote it into simple plain text file database with entries like
    # PP3 device database for version 0.92
    # name   flash page  ID  mask family_type
    # flash size and page size in bytes 1 WORD = 2 BYTES
    # PIC16 family
    16f1503   4096   32 2CE0 FFE0 CF_P16F_A
    16lf1503  4096   32 2DA0 FFE0 CF_P16F_A
    16f1507   4096   32 2D00 FFE0 CF_P16F_A
    16f1508   8192   32 2D20 FFE0 CF_P16F_A
    16f1509   16384  32 2D40 FFE0 CF_P16F_A
    16lf1507  4096   32 2DC0 FFE0 CF_P16F_A
    16lf1508  8192   32 2DE0 FFE0 CF_P16F_A
    16lf1509  16384  32 2E00 FFE0 CF_P16F_A
    16f1454   16384  64 3020 FFFF CF_P16F_A
    16f1455   16384  64 3021 FFFF CF_P16F_A
    so it is easy to edit (add new PIC devices or fix mistakes in existing) by hand without recompiling the code. The pp3 takes all the information about device to be programmed from here. The original source shrunk from 2700 to 900 lines of code.
    I also added 67 more PIC18FxxJxx devices and one PIC16F, so it supports 273 devices in total. At last, I tested support for another 7 devices, all of them working on a first try. I feel like time for 1.0 release is near.
    Everything is on github, as usual.
  • After 0.9 comes 0.91, obviously
    jaromir.sukuba09/06/2016 at 12:16 5 comments
    I decided to release version 0.91 - the previous should be 0.90, then.
    No matter what, I added some more devices - 205 devices supported in total.
    I also changed somehow serial port handling, resulting in higher programming speed, especially under windows. PIC16 programming algorithm got a bit more intelligence, resulting in faster programming.
    Before 1.00 release I'd like to rework the MCU type selection into table driven function instead of huge if-then-else behemoth and set support for all LVP ICSP-able 8-bit PIC devices.
    Everything is at github, as usual https://github.com/jaromir-sukuba/a-p-prog
  • Version 0.9 - 175 devices supported
    jaromir.sukuba09/05/2016 at 20:55 0 comments
    Oh here we go, version 0.9 - this means first "normal" release 1.0 is close.
    I added a lot of new devices, some new are tested. I fixed some bugs around serial port and hex file handling. The PIC name is now case non-sensitive. 175 devices is in support list in total.
  • New devices support
    jaromir.sukuba08/16/2016 at 06:42 0 comments
    Amount of supported devices increased from 68 to 131. Some new PIC16F1xxx were added (16F151x, 16F178x, 16F19xx) and completely new PIC18 family was added - PIC18FxxJxx (like 18F26J50); which also required updated programmer firmware. Not all members of this family are here yet, that is subject of next release.
    Everything is on github and updated support table is at the project details section too.
  • New devices support update
    jaromir.sukuba08/05/2016 at 06:00 0 comments
    I increased number of supported devices from 48 to 68 (PIC16F1619 family and PIC16F1579 family added) and tested a few new ones.
    Sources at github, as usual.
  • PIC16F USB devices added
    jaromir.sukuba07/30/2016 at 20:34 0 comments
    I added support for PIC16F1454, 1455, 1459 and LF variants. I had PIC16F1455 at hand, so I tried to upload some small program and it worked as expected.
    Some minor mistakes fixed for PIC12F18xx.
    PIC12F1840, PIC16F1503, PIC16F1509 tested and working too.
    PIC programmer sketch verified to run on 2USD chinese arduino nano clone with CH340 USB-serial converter.
View all 21 project logs
KSUdoubleE wrote 08/18/2017 at 17:09 point
Successfully programmed a PIC12LF1571 and PIC12LF1501, worked great.  Thanks!
jaromir.sukuba wrote 08/31/2016 at 13:27 point
@rmessino  The PIC type should be all lower case, like 16f1783, for current software version. Perhaps I should rewrite to accept both letter cases.
adilmalik_n wrote 12/26/2015 at 00:06 point
Can this work with higher end like the DSPIC33F's? ive got a diy dev board that im dying to program and have a PICKIT3 on order but its delayed due to Christmas (dont worry, its a clone).
jaromir.sukuba wrote 12/26/2015 at 14:18 point
Yes, dsPIC33F are technically possible.
Speaking from memory, all 16- and 32-bit MCUs from Microchip are using low voltage on MCLR and serial key on PGC/PGD pair to enter programming mode (as well as newer 8-bits, like PIC16F1xx, like PIC18F1829 and some PIC18, for example PIC18F46K22 and similar).
On the other hand, there are dsPIC33 with 512kB of FLASH. Programming such as amount of data with this simple and really slow programmer would be pain in the ass. Bottleneck of data throughput here is simple polled firmware architecture and slow serial transfer - acceptable only for few kB of data for 8-bitters.
But it is good to know there is demand for other than PIC16F1xxx devices. I'll start thinking about how to improve the programming speed and scan through programming specs of PIC devcies to determine what types are possible to implement.
Connor Neal wrote 12/10/2015 at 23:37 point
Nice work! Did you hand solder the components?
jaromir.sukuba wrote 12/11/2015 at 09:26 point
Thanks. Yes, I soldered the parts by hand with my DIY soldering iron, leaded solder and cheap chinese flux.
rmessino wrote 08/31/2016 at 03:28 point
Hi first at all, thanks for your work, is great that you are doing. In the ither hand I run pp3 program today I am working with a seeduino board(atm328p) and a pic16lf1783 , I get a error "Unsupported CPU type '16F1783' This application has requested the Runtime to terminate it in an unPlease contact the application's support team for more information." Do you have any idea about?
Blecky wrote 12/07/2015 at 02:40 point
[verified: no design files missing]
alpha_ninja wrote 12/02/2015 at 00:42 point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
