SquishBox
A Raspberry Pi stompbox sound module running Fluidsynth
Public Chat
Starting from
$150.00
albedozero has 169 orders / 1reviews
Ships from United States of America
The SquishBox is a synthesizer in a stompbox powered by a Raspberry Pi. It uses Fluidsynth to produce sound, which means you can add or create whatever soundfonts you want. Plug a MIDI controller or four into the USB ports, connect the 1/4″ stereo outputs to an amp, mixer, or headphones, and you’re ready to rock. This project has gone through several iterations and upgrades, and is now available as a kit or fully assembled unit with a custom-printed PCB using the link to my Tindie store above. This Hackaday project documents the development process, and describes the best method I've found for building the SquishBox from off-the-shelf components.
As a keyboardist, I wanted to be able to use software instruments without having to manage a laptop/tablet, audio interface, etc. Basically, I needed a compact, simple sound module that I could customize and use with my favorite MIDI controller - specifically an Alesis Vortex keytar. The Raspberry Pi 3B+ was easily the winning choice for a platform since it has the 4 USB ports, low price tag, and fits snugly in a standard Hammond 1590BB-style enclosure.
code: https://github.com/albedozero/fluidpatcher/
PCB design files: https://github.com/GeekFunkLabs/squishbox/tree/main/schematics
3D printed case: https://www.thingiverse.com/thing:6188155
I wanted the SquishBox to use easy-to-find and inexpensive components. I chose a standard HD44780 16x2 character LCD for the display. For sound output, I chose a PCM5102-based DAC sold as a GYPCM5102 - a compact, cheap board built around the same chip as mainstream but pricier and bulkier add-on DACs like the HifiBerry. It seems to be pretty widely available from different online electronics distributors, and the PCM5102 is pretty much an audio standard, so it seems reasonable that it should remain in production for a good while. The DAC provides an improvement in quality over the Pi's onboard sound, but more importantly a drastic decrease in audio latency.
I chose FluidSynth as the sound engine because it's free and versatile - soundfonts are arguably the prototype virtual instruments, and you can modify them without having to code and/or recompile. There already existed a Python library - pyfluidsynth - that uses ctypes to wrap Python functions around FluidSynth's C callables, and I used this to design my own Python-based FluidSynth wrapper based on patches - groups of instrument, effect, and MIDI settings stored in YAML text files. The code is written so that different implementations can be created that use the same bank files, and includes a desktop editor/player and a version that runs on a bare Raspberry Pi (i.e no screen or buttons). In future I hope to create DAW plugins and perhaps an Android build. The series of video lessons below explain how to create bank files, in addition to the wiki at the source code link above.
  • 1 × Raspberry Pi computer 3B+ recommended
  • 1 × microSD card (at least 8GB) for RPi firmware+software
  • 1 × HD44780 16x2 character LCD
  • 1 × 1k resistor
  • 1 × 10k trim potentiometer for setting LCD contrast
View all 15 components
  • DIY SquishBox
    Bill Peterson02/05/2021 at 18:55 0 comments
    Now that I've got kits for the SquishBox up on the Tindie store and build instructions for that hosted on Geek Funk Labs, I've posted complete DIY instructions here on Hackaday for anyone who wants to build their own SquishBox from scratch. Good luck and contact me if you need guidance!
  • Tindie Store Now Open!
    Bill Peterson01/16/2019 at 07:10 2 comments
    I've opened a Tindie store for selling a completed version of this project, which I call the SquishBox. Updated code and info can be found at the GitHub repository. Yay!
  • Pi 3 Upgrade
    Bill Peterson05/06/2016 at 21:42 0 comments
    I bought a Raspberry Pi 3 for the speed/memory upgrade. Since the GPIO header is the same as the Pi 2 I was able to just swap it out with the Pi 3. With the faster processor I was able to tweak fluidsynth's settings (audio.period-size: 64, audio.periods: 3) to get even less latency. I didn't really notice a delay before, but playing through the jamPi definitely "feels" more responsive now.
    A couple other minor points of progress:
    • Updated pyfluidsynth with bindings to fluid_midi_router.c - router rules can be set up in config_jampi.yaml
    • Expanded structure of config_jampi.yaml and how it is interpreted by jampi.py:
      • settings:soundfont: global soundfont to use in patches if per-channel soundfont isn't specified
      • settings:fluidsettings: passes options to fluidsynth
      • router rules can be specified globally (in settings) on a per-patch, or per-channel basis
    • I read the soundfont 2.1 spec a bit more carefully and realized that modulators can be used to allow CC messages to control things like filter cutoff, resonance, etc. Fluidsynth already understands modulators, so I can use the built-in synth capability of soundfonts without rewriting fluidsynth. To test this, I used Polyphone to make a soundfont with one saw wave preset and modulators tying the filter resonance and cutoff to CC 71 and 74, and it works! Boss.
  • Ready for Jams
    Bill Peterson04/02/2016 at 18:14 0 comments
    Time since the last update has been spent coding a smooth interface for the jamPi, coming up with a logical format to store patches, debugging to make sure there aren't too many crashes when I'm playing live, making sure there is always a way to get an ssh so I can make changes/debug if things go bad without taking the thing apart, and painting the box. I'm fairly confident this is at a state that people can actually use and make their own modifications from, so I'm posting the code in its current working form and will add some actual instructions soon. I have more mods planned to maximize this thing's potential (and fun), but they will all be software updates that can be pushed in via ssh.
    Painting stompboxes in a way that is durable and pretty is apparently an arcane artform that I may never have the patience for - if you don't believe me check out the forums on diystompboxes.com (which were incredibly heplful despite my failures). I failed with my initial paint job - the clear-coat ate my cheap cranberry 2x spraypaint and crinkled it up like a wadded paper towel - so I had to sand the whole thing and try again. Second try I used some automotive primer and a hammered-finish spray. That might have been enough, but I sprayed some clear lacquer over the top for some additional protection. Not sure if it helped or hurt - you can see some dents in the finish already from where it rode in my gig bag and some squishing where I tightened down the stompswitches because I'm impatient - there's no way I'm going to wait three months for the paint to cure or bake this thing in a toaster oven as some suggest. I decided to go with the punk cred and lettered on it with a white correction pen why not.
    The interface takes about 15 seconds to come up. I had it coming up in about 4 seconds by having systemd run it as a service, but fluidsynth wasn't able to start the audio driver. Hopefully I can figure this out later - in the meantime I may have a small script turn on the LCD at boot. The patches consist of global chorus/reverb settings and soundfont/bank/preset settings for any of the 16 MIDI channels. I plan to add a feature for reading midi routing rules out of the config_jampi.yaml file, but I'll have to add those bindings to pyfluidsynth first. A menu can be reached by holding either stomp switch for ~2 seconds - this allows you to update the patch (if you've changed a program or chorus settings, for example), save a copy of the current patch as a new one, reconnect a midi controller if you want to swap or didn't have one connected at boot, and control the wifi adapter. Holding down a stompswitch for ~5 seconds gets you a shutdown prompt. Stomping for 2 seconds confirms. I've yanked the plug on my Pi's many times without ever corrupting an SD card, but better safe than sorry.
    The wifi control is a bit unreliable. I have the Pi always boot up and connect to my home network for now so I don't get locked out - if I couldn't get a wifi signal I'd have to open the box, disconnect the Pi and plug in a keyboard/monitor or console cable to fix things. I installed hostapd and dnsmasq so I can connect to the Pi as an access point if I'm out somewhere with it, and this seems to start fine, but I can't dynamically switch between using hostapd and connecting to my home network like I want. I think I need to turn off network autoconfig (ifplugd something something) and learn more about manually configuring wlan0, but that's for another day. There is also a 'wifi off' option - sometimes the adapter makes some minor noise that gets into the audio signal.
    I want to add a midi learn feature, but that requires modifying fluidsynth itself to echo received midi messages, and adding bindings to pyfluidsynth. There already is a debug function in fluidsynth for this that goes in the right direction, but I also don't want to slow my script down by making it listen for midi messages all the time, so that will take some cleverness. There is also the project goal of being...
  • In the Box
    Bill Peterson02/26/2016 at 07:13 0 comments
    Punchline first - got everything to fit inside the box, and it appears to be working (mostly) as intended. Video evidence:
    I realized I'd have to do some reconfiguring to get everything to fit inside the stompbox. I made a couple USB extender cables out of some ribbon cable to connect from the Pi's USB ports to the MIDI in port on the hat and to the little USB sound card.
    I also pried the case off the sound card so it would take up less space. Wrapped some pretty orange duct tape around a couple things to prevent things from shorting to the case, and crammed everything in the box. It's a pretty tight fit:
    But it works! I've got jampi.py set up as a service so it starts up quick when the box is plugged in. There's something goofy in the code where the buttons register an event on both press and release, and I have many more plans for the interface code (and for modding fluidsynth itself), but progress is being made!
  • It's Alive
    Bill Peterson01/15/2016 at 07:23 0 comments
    Soldered the rest of the components onto the proto hat over the weekend. Used a short length of USB cable from the jack on the hat to the one on the Pi - had to really fuss with the length, and ended up making it almost too short, but it works. The jacks, wires, and components sit kind of high on top of the hat, but I think it will all fit inside the box once I cut the holes.
    Changed some of the pin numbers in the code to match where I connected the necessary LCD pins and buttons, and added some code to use the Pi's built-in pull-down resistors. Turned it on and ... it's alive! I plugged in some headphones and the MPKMini2, and I got piano!
    Next steps: cut holes in the box (+sweet paint job), make some tweaks to fluidsynth, and write really nice interface code for my python stompbox.
  • Dummy Tax
    Bill Peterson01/09/2016 at 09:06 0 comments
    That was a big waste of time. The USB cable I was testing with must have a short or a bad connection in it somewhere. I got frustrated and cut up a new one, and the Pi powers just fine off of 5V into the expansion header. Tried a few different power supplies just to be sure. This is good, though - fewer cables in the box and more space for buttons/jacks. Blerg at least I can sleep now.
  • Soldering Fun/Power Issues
    Bill Peterson01/09/2016 at 02:49 0 comments
    I soldered the USB jacks for power and MIDI controller onto my perma-proto hat. I shelled out $6 for one of these because it's got pads on both sides - needed so I can solder the jacks on top where they'll fit - and it's sturdy and has mounting holes to hold everything together. First thing I did, of course, was break it. I drilled holes for the little anchor tabs on the USB jacks, and the first hole in the ground rail next to the 3.3V rail is where the trace from the header is connected. No biggie, since there's another ground rail by the 5.5V rail.
    Fitting things into this box is going to be tricky. I'd hoped to chop the end off a micro-USB cable and wire it to the B-jack to get power to the Pi, but it's a tight fit even with some of the plug sliced away (the laptop PSU is just photobombing - not part of the project).
    I'd like to be able to wire the USB-B jack to the 5V and ground pins on the Pi's expansion header (even though many say this is not a good idea) - if you can power the Pi with a console or FTDI cable, this should work, right? The fact that it's a USB jack should make it clear you're not supposed to plug your 12V PSU in there. Unfortunately, no dice. When I connect a standard 5V 1A charger to the pins the Pi does not power up. The red PWR LED stays dark, and the green LED gives me 2 blinks, pauses, and repeats.
    I put the voltmeter on the pins and saw that the voltage was fluctuating rapidly between a few tenths of a volt and maybe 4.5 volts. I imagine what's happening is that the Pi is beginning its boot sequence, and the switching voltage regulator in the 5V adapter is not keeping up with the current demands. The Pi decides something is wrong and shuts down. Then, current from the adapter ramps up and process repeats. The electronics in a console cable must be better able to handle this.
    I took a look at the schematic for an FTDI cable and saw all those filtering capacitors sitting on the 5V line - maybe they filter out those rapid changes in current demand. I tried to copy it on proto (I know a coil of wire does not a ferrite bead make, but EMI shouldn't be a huge problem here).
    Same problem. Why won't this work? Guess I'm just a dumb physicist that doesn't get electronics. One thing that did work (no pictures though) was connecting a 9V battery up through a standard LM7805 5V regulator. The Pi powers up fine with that (although it wouldn't run very long). The LM7805 should provide a pretty constant voltage, so maybe the problem is just that a cheapo 5V phone charger can't hack it.
    I was able to pop the casing off the microUSB cable plug, so I should be able to go that route after covering it with some shrink tubing. Probably the safer option, but I would like to know what makes my FTDI cable so special.
  • Work Thus Far
    Bill Peterson01/07/2016 at 08:10 0 comments
    I initially spent some time playing with sound cards and with Fluidsynth to see if it could be used reasonably in live performance. The Pi's built-in sound jack is right out - my web research tells me the Broadcom chip downsamples audio to 11kHz, which sounds unacceptably crummy on many patches. I thought it might have lower latency, but this is not the case. With the right buffer/period settings (will provide later) on Fluidsynth the latency is not noticeable and the sound through my little USB sound card is actually pretty decent. The one horrible thing that does happen is that if you mash a lot of notes at once (10-12), Fluidsynth gets overloaded somewhere, and rather than simply dropping notes it produces horrific digitized car crash sounds until you stop pressing keys for a few seconds. Maybe some kind of memory overload? I couldn't find any help on this issue (please advise if you know what's going on) and haven't had any luck fixing it myself, but after a while I decided maybe I just don't need to hit 10 notes at once.
    I did some prototyping to make sure I knew how to wire buttons and a character LCD, and that my python script didn't interfere with Fluidsynth. I had to add some bindings to pyfluidsynth to start up the MIDI driver and router - apparently it was just designed for people who want to play MIDI files. I did some jamming with my proto board synth, and everything felt and sounded good, so I proceeded to work on putting things into the stompbox.
    There isn't a lot of extra space in the box with the Pi, proto hat, LCD, stompswitches, and various connectors in there. The USB-B power jack and USB-A jack for midi controller will be soldered onto the proto hat for stability. I plan to anchor the proto hat to the box with standoffs, then the Pi will be held in place with its GPIO connector and additional standoffs. I need to get USB from the Pi's ports to the sound card, and to the USB-A jack on the hat, and there's barely any space in the box over there, so I will fashion my own short right-angle USB cables by cutting down a couple USB plugs as small as possible, soldering on wires, and shrink-wrapping.
View all 9 project logs
  • 1
    Overview
    The image and (very crude) schematic below show the overall construction of the electronics for the SquishBox. The components are all attached to a rectangular piece of perfboard that plugs directly onto the Pi's GPIO header. Since we're using cheap one-sided perfboard, all the components are soldered to the same side, so the resistor, DAC, and trimpot will fit between the Pi and perfboard, and there will be room inside the enclosure for the LCD on top. The 2x20 header creates a bit of a barrier to the layout, but rather than wrapping wires around the sides of it and making a complicated mess, you can strategically remove a few unneeded pins, strip some extra insulation off your wire, then thread it through and over the back of the header as shown in the image below. The X's in the schematic show where pins should be removed from the header (you can pull them out with needle-nose pliers). The enclosure-mounted components - audio/DC jacks, buttons, and LCD - are connected to the perfboard with strips of ribbon cable, which I like because it keeps thing tidy and the color-coding is helpful for making the right connections.
  • 2
    Connecting LCD
    Two strips of ribbon cable are used to connect the LCD pins to the perfboard - this is necessary since we can only solder on the top side of the board, so the wires have to be inserted from the bottom, and also allows for the LCD to be mounted in the enclosure body. Hot glue should be used for strain relief at both ends of the ribbon cable, or the wires will definitely tear out while you're assembling the components.
  • 3
    Perfboard Components
    Solder the 2x20 female header into the perfboard, followed by the resistor and trimpot. Mount the trimpot at a point where it will be accessible by a thin screwdriver inserted between the USB ports. The trimpot shown in the inset images is a better choice than the one in the larger image, as a cross-head screwdriver will seat more easily. Bend the pins to one side as shown so you can mount it at a right angle to the board edge. Test fit the location of the DAC in the board and solder in the jumper wires for its connections, but don't solder it in place yet.
View all 7 instructions
tonystarc992 wrote 01/21/2024 at 09:35 point
The NJ ticket payment portal has been a lifesaver for me. It's so user-friendly and efficient. I recently got a traffic ticket, and being able to settle it online without the hassle of going to a physical location made the process much smoother. Kudos to New Jersey for embracing technology for the convenience of its residents!
https://disqus.com/by/njmcdirectcom/about/
https://www.blogger.com/profile/11003571691742501273
HayMiltone wrote 05/02/2022 at 11:06 point
SquishBox is a new startup with an innovative model for higher education that does just that. The company has created a system for splitting the costs and time commitment of college between students and their parents. First, high school students are recommended to get  best writing services online and learn all the material necessary for entry-level positions in their chosen career field at home online through SquishBox's proprietary program.
Craig Hissett wrote 07/04/2016 at 00:00 point
This is bloody marvellous!
A Pi based stompbox is a very versatile build.
I'd love to explore using one for recording, or even just effects!
