WiFi Webradio on ESP8266 or ESP32
KaRadio
A fully featured wifi web radio player with only low cost boards.
with or without a vs1053 board
Control with any browsers (ie edge, chrome mozilla etc...).
or with an external hardware panel or with the uart interface or with telnet.
Memory for 255 stations
OTA (On the Air) upgrade,
Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf
Read up to a 320 kb/s stream,
Encoder, IR, lcd ...
Embedded wifi configuration via the web or serial or telnet.
Metadata displayed (ie Title of the current song if given in the stream),
Permanent setting (sound setting, stations, wifi)
Server multi clients with automatic refresh (websocket),
The stations may be downloaded and uploaded within the web site,
Stations sort management by drag drop.
very quick responsive web by caching local information in the browser and websocket.
additional hardware: a led indicates the state of the equipment
Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
KaRadio32 Release 2.3
Release 2.3 Rev 0 - Built on 2022/02/23
New:
  • 2.3 R0:
    • RAM optimization
    • Audio buffer size incremented.
    • Bugs correction: HTML chunks processing and Meta computing
    • Stack crash on http instant command removed
    • AAC Decoding improved
  • 2.2 R1:
    • Introducing WIFI QoS Ip precedence AC_VI
    • SPDIF output improved
    • DAC bugs removed.
    • AAC Decoding improved (but not perfect)
    • New patch for the vs1053. Play OGG too.
  • 2.2 R0:
    • Many internal optimizations
    • ascii unicode #&xxxx; decoded
    • aac decoder improved.
    • Added html commands volume+ and volume-
    KaRadio: Release 2.1
    Release 2.1 R0 - Built on 2021/02/15
    • 2.1 R0:
      • Security: the ssid passwords are no longer sent on each "Setting" display, but only when changed.
      • Bug fixed: in parse playlist. Possible memory leak. Thanks to HmarikBel
      • Bug fixed: Special char in station name was incorrectly sent.
      • Some minors improvements.
    • 2.0 R0:
      • Better handling of the large "header moved"
      • Better monitoring
      • timezone suggestion on the setting page
    History:
    history
    For ESP32 see the github page KaRadio32.
    ESP8266 Simplest prototype:
    - Optional external ram (23LCV1024) support (1:CS/=GPIO16 2:MISO=GPIO12 3:NC 4:GND 5:MOSI=GPIO13 6:SCK=GPIO14 7:GND 8:3.3v)
    Attention:
    The optional led is now on GPIO2. The blue led on the ESP8266 is blinking at the same rate.
    GPIO16 is now the Chip select for the external ram if any.
    The external ram is detected at boot time if present.
    To upgrade to this release, please flash user1.4096.new.4.bin at 0x1000 ,
    user2.4096.new.4.bin at 0X81000 and blank.bin at 0x7e000 & 0x3fe000
    After that, all next updates are done with the On The Air (OTA) feature.
    New binaries are hosted at http://karadio.karawin.fr .
    Loading the esp8266
    First use
    • If the access point of your router is not known, the webradio initializes itself as an AP. Connect your wifi to the ssid "WifiWebRadio",
    • Browse to 192.164.4.1 to display the page, got to "setting" "Wifi" and configure your ssid ap, the password if any, the wanted IP or use dhcp if you know how to retrieve the dhcp given ip (terminal or scan of the network).
    • In the gateway field, enter the ip address of your router.
    • Validate. The equipment restart to the new configuration. Connect your wifi to your AP and browse to the ip given in configuration.
    • Congratulation, you can edit your own station list. Don't forget to save your stations list in case of problem or for new equipments.
    • if the AP is already know by the esp8266, the default ip at the first start is 192.168.1.254
    • a sample of stations list is on https://github.com/karawin/Ka-Radio/blob/master/ESP8266-Firmware/WebStations.txt . Can be uploaded via the web page.
    Feedback
    Please tell me if you succeeded or something more can be done, thanks.
    The second step will add some hardware buttons (vol + -, station + -, play ...)
    Wiring:
    From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
    REST
    ADC
    CH_PD to 3.3v
    GPIO16 (a 1Hz output)
    D5:GPIO14 to VS1053 SCK
    D6:GPIO12 to VS1053 MISO
    D7:GPIO13 to VS1053 MOSI
    TXD to CH340G UART rx
    RXD from CH340G UART tx
    D1:GPIO05 to VS1053 XDCS
    D2:GPIO04 to VS1053 DREQ
    D3:GPIO00 to VS1053...
KaRadio32.bin
KaRadio32 2.3R0
application/octet-stream - 1.49 MB - 01/01/2021 at 21:11
Download
KaRadio 2.1 R1 Partition 1
application/octet-stream - 424.75 kB - 01/11/2020 at 18:13
Download
KaRadio 2.1 R1 Partition 2
Download
boot_v1.7.bin
octet-stream - 3.98 kB - 09/17/2017 at 10:26
Download
blank.bin
octet-stream - 4.00 kB - 07/21/2016 at 15:19
Download
View all 6 files
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    D3:GPIO00 to VS1053 XRST
    GPIO02
    D8:GPIO15 to VS1053 XCS
View all instructions
Aleksey-748 wrote 04/04/2021 at 20:37 point
Взаимодействие с другими людьми
Tipitapi wrote 03/06/2021 at 16:45 point
It works very well! The next update could be MQTT.
Home Assistant Integration? Thanks.
josefburgersanktmartin wrote 01/26/2021 at 18:46 point
The O-led with arduino mini  addon work now , but the  date display  only  "01-01-2000' and the clock work like a function time counter , it count the time from powering on  .What can i do to fix this ?  Thank you !
Jean-Pierre Cocatrix wrote 01/30/2021 at 21:42 point
This is because the request time from the mini is not received by the esp. Check the mini tx ---- rx esp wire
josefburgersanktmartin wrote 01/31/2021 at 08:43 point
in my schematic the wire mini tx ---- rx esp not exist ,   only tx from ESP 8266 to rx mini , i have only 3 wires from radio to mini , 3,3V GND and  tx esp to rx mini
Jean-Pierre Cocatrix wrote 01/31/2021 at 08:50 point
Yes a mistake.
but in u8glibConf.h you can read:
The tx of the pro mini must be connected to the rx of the esp12 but
Warning; the esp rx pin is not 5V tolerant, so if your pro mini is a 5v version we nned to adapt the level.
See
http://www.instructables.com/id/Pi-Cubed-How-to-connect-a-33V-Raspberry-Pi-to-a-5V/
The value of the resistors is not critical. Only th ration 1/3 2/3 must be respected 1k and 2k for example)
zhenya4444 wrote 07/20/2022 at 18:08 point
Hello. I have a few questions for you. I can't write to you on this site. Give your mail.
hehaipeng wrote 12/14/2020 at 05:15 point
hank you! Production completed. It's just that China's radio streaming media does not support the display of radio program information, and the display screen looks ugly and harmonious. I want to adjust the screen display layout and enlarge the font, but I'm not very familiar with programming, and I'm only good at hardware. Hope under the guidance, thank you!
podhradp wrote 11/28/2020 at 21:41 point
Hello, i have Ai-Thinker ESP32-A1S-audio board. But sound not work. It have AC101 hal audio.
https://github.com/pilnikov/adf/tree/master/esp-adf/components/audio_hal/driver/ac101
Any idea how solve this?
Vanya Venikov wrote 09/23/2020 at 11:31 point
Hello, there is a bug in KaRadio32_19R7.bin - ogg vorbis streams does not work. Using KaRadio32_19R6.bin works correctly. Could you fix the bug in future release?
Jean-Pierre Cocatrix wrote 02/02/2021 at 14:56 point
fixed
Marco wrote 05/19/2020 at 14:28 point
Hello,
I would like to add a I2C display to my Karadio. Do I need an Arduino micro or can I connect it directly to the ESP32?
Thanks!
josefburgersanktmartin wrote 04/19/2020 at 17:42 point
Hello,
I want to add to my KaRadio with ESP8266 and VS 1053 an 16x2 (or 20x4 )  liquid crystal display  with Arduino uno (or Nano )supplied with 5V . Can i connect RX-TX from Arduino and ESP8266 direct or I need a level adaptor ?Can you help with schematic ?
Jimsonweed wrote 02/14/2020 at 15:44 point
Hello, is it possible of implementing flac stream for karadio32 with vs1053 decoder? And wma parcing with "mms:" stream, since vs1053 is support all of it.
Jean-Pierre Cocatrix wrote 04/20/2020 at 07:42 point
I don't think that the esp wifi will support the stream speed for a flac.
Never tried.
Martin Fasani wrote 01/15/2020 at 15:20 point
Added to my curated list Espressif
https://hackaday.io/list/162467-espressif
ifcristian wrote 12/09/2019 at 19:38 point
Hi! Nice job! Nice job!
I need help with one idea... i want to implement auto start chanel from day and hour. One day at 10 listen x chanel other day y chanel from y hour. You can help me? Regards !
simon wrote 08/27/2019 at 15:07 point
Hello,
I have installed your Software on two ESP32 systems and booth working very well, i have only two suggestions.
1. sometimes after power the radio, the ESP32 don´t connect to the wifi and start instead the AP, the router is not far from the ESP... and next time the ESP connect to the WIFI, maybe it is possible to programm a routine, when AP is active, check every 5 minutes to stored WIFI networks.
2. somitimes when i switch a light in the near of the Radio, i hear a knock at the speaker and the radio is loudless, after a restart the radio is working well. Ithink the problem is the VS1053, maybe it is possible to check if the VS1053 is working, if not, give him a reset.
Martin Fasani wrote 01/15/2020 at 15:23 point
I have a suggestion about that: Instead of using WiFi manager, let WiFi configuration come from Bluetooth serial or BLE (Serial is a smaller lib)
Here there is an example: https://github.com/martinberlin/Remora
There is an Android app called "ESP32 WiFi setup over BLE or Bluetooth Serial" and then you can easily setup the Radio via Bluetooth
Georde wrote 07/29/2019 at 22:29 point
Hello. I have a problem: I cannot access the web page (192.168.4.1). Connection to AP is correct. wifi "WifiWebRadio".  My browser, it says "This site can't be reached."
What am I not doing well, what am I supposed to do?
Thank you
Curt Parrish wrote 07/25/2019 at 15:35 point
Hi,
I like this project but haven't had much success. I'm using a nodemcu v.3 with an ESP8266 and a VS1053. After flashing the nodemcu, I can see a response from it in a terminal program. Following the directions in the response, I can connect to WifiKaRadio successfully, but when I enter 192.168.4.1 in my browser, it says "This site can't be reached." There is also no result pinging that IP address, but 192.168.4.2 does respond to the ping. I can't get any farther than this.
Can anyone help?
Sera26 wrote 05/13/2019 at 18:52 point
Hello,
Playing of radio stations are lagging strongly with KaRadio, the streams are unpalatable.
I have already removed control buttons (ADC and GND bridged) and STM32+LCD but radio can't play stations continuously.
What can be the problem?
Jean-Pierre Cocatrix wrote 05/14/2019 at 08:37 point
What is the log?
Sera26 wrote 05/14/2019 at 09:10 point
Sorry, for ignorance but how can I get log file?
Jean-Pierre Cocatrix wrote 05/31/2019 at 15:47 point
resolved, thanks.
jumpjack wrote 05/13/2019 at 10:35 point
Could this tiny little thing be used as MP3 player module for the ESP8266 version?
<img src="http://www.mauroalfieri.it/wp-content/uploads/2017/12/DFPlayer-mini-mp3.jpg">
DFPlayer mini mp3 module.
Jean-Pierre Cocatrix wrote 05/13/2019 at 11:07 point
No. no sd card allowed.
jumpjack wrote 05/16/2019 at 07:17 point
no, I meant if an MP3 stream could be sent to the module over serial.
Jean-Pierre Cocatrix wrote 05/16/2019 at 08:12 point
no, sorry
jumpjack wrote 05/13/2019 at 10:34 point
Can the project work as-is if I do not connect any display or key, or does it require some tuning?
Is any Arduino-IDE version available?
Jean-Pierre Cocatrix wrote 05/13/2019 at 11:06 point
Yes. no tuning but better with a little effort. (no lcd (sys.lcd("255"))
No, it is an esp_idf project only.
Roman Kot wrote 04/30/2019 at 09:54 point
Is this possible to integrate IR receiver in order to use any remote control. So you can learn commands from your Rc then map it at CSV
Jean-Pierre Cocatrix wrote 05/13/2019 at 11:08 point
You can learn codes with the log at sys.logd level then map them in the csv.
Sera26 wrote 04/14/2019 at 10:10 point
Hello,
I would like to use control buttons of KaRadio to Karadio32 instead of encoder.
Is this possible?
Thank you for help in advance.
Sera26 wrote 04/14/2019 at 17:42 point
Dear JPC! Many thanks for your support.
silvercarph wrote 03/11/2019 at 21:35 point
Hi, I appreciate your effort to create KaRadio. My setup works somehow but I need some help with two issues: poor sound quality and noise.
1. Poor sound quality: I receive only a low quality mono-like sound (with some echo) with no bass unless a GND point (power extension safety GND point) is connected to the V1053 GND. With the external GND connected the sound is excellent but I would prefer to avoid another wire connected so close to 220V.
2. Low freqency noise -
When powered from a 5V power bank, there is no noise (still needs GND to mains GND to have good quality sound) and works perfectly.
When powered from a 5V phone charger and there is no external GND connection there is a loud low freqency noise. With the external GND connected all noise disappears and works perfectly.
Analog GND is connected to digital GND? Noise from the charger? Any ways to eliminate the noise?
My setup:
- MB102 power supply - powered from 5V power bank or phone charger through USB
- NodeMCU ESP8266 ESP-12E V1.0 - (Ka-Radio-master1.9.zip flashed with flash_download_tools_v3.6.5.exe), powered from MB102 5V, common GND
- VS1053 (red, chip ver. 1815) MP3 with SD Card Slot  - 5V from NodeMCU, GND from NodeMCU, jack connected to HiFi amplifier (which is also connected to UPC TV box)
- STM32F103C8T6 Blue Pill (karadio-addons-master\karadioUCSTM32 ver.07.02.2019 (flashed with HW-597 (CH340)) powered from MB102 5V, common GND
- 1.8" TFT ST7735B - powered from MB102 5V and 3.3V(for LCD), common GND
- KY-040 Rotary Encoder - powered from MB102 3.3V, common GND
So now I got stuck with an operational radio but the external GND line does not look safe. Any suggestions to improve?
