WiFi Webradio on ESP8266 or ESP32
KaRadio A fully featured wifi web radio player with only low cost boards. with or without a vs1053 board
Control with any browsers (ie edge, chrome mozilla etc...). or with an external hardware panel or with the uart interface or with telnet. Memory for 255 stations OTA (On the Air) upgrade, Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf Read up to a 320 kb/s stream, Encoder, IR, lcd ... Embedded wifi configuration via the web or serial or telnet. Metadata displayed (ie Title of the current song if given in the stream), Permanent setting (sound setting, stations, wifi) Server multi clients with automatic refresh (websocket), The stations may be downloaded and uploaded within the web site, Stations sort management by drag drop. very quick responsive web by caching local information in the browser and websocket. additional hardware: a led indicates the state of the equipment Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
Release 2.4 Rev 1 -
 Built on 2026/03/08
  • 2.3 Rev 0 - Built on 2022/02/23
  • Real time optimizations
  • 2.3 R0:
    • RAM optimization
    • Audio buffer size incremented.
    • Bugs correction: HTML chunks processing and Meta computing
    • Stack crash on http instant command removed
    • AAC Decoding improved
  • 2.2 R1:
    • Introducing WIFI QoS Ip precedence AC_VI
    • SPDIF output improved
    • DAC bugs removed.
    • AAC Decoding improved (but not perfect)
    • New patch for the vs1053. Play OGG too.
  • 2.2 R0:
    • Many internal optimizations
    • ascii unicode #&xxxx; decoded
    • aac decoder improved.
    • Added html commands volume+ and volume-
    KaRadio: Release 2.1
    Release 2.1 R0 - Built on 2021/02/15
    • 2.1 R0:
      • Security: the ssid passwords are no longer sent on each "Setting" display, but only when changed.
      • Bug fixed: in parse playlist. Possible memory leak. Thanks to HmarikBel
      • Bug fixed: Special char in station name was incorrectly sent.
      • Some minors improvements.
    • 2.0 R0:
      • Better handling of the large "header moved"
      • Better monitoring
      • timezone suggestion on the setting page
    History:
    history
    For ESP32 see the github page KaRadio32.
    ESP8266 Simplest prototype:
    - Optional external ram (23LCV1024) support (1:CS/=GPIO16 2:MISO=GPIO12 3:NC 4:GND 5:MOSI=GPIO13 6:SCK=GPIO14 7:GND 8:3.3v)
    Attention:
    The optional led is now on GPIO2. The blue led on the ESP8266 is blinking at the same rate.
    GPIO16 is now the Chip select for the external ram if any.
    The external ram is detected at boot time if present.
    To upgrade to this release, please flash user1.4096.new.4.bin at 0x1000 ,
    user2.4096.new.4.bin at 0X81000 and blank.bin at 0x7e000 & 0x3fe000
    After that, all next updates are done with the On The Air (OTA) feature.
    New binaries are hosted at http://karadio.karawin.fr .
    Loading the esp8266
    First use
    • If the access point of your router is not known, the webradio initializes itself as an AP. Connect your wifi to the ssid "WifiWebRadio",
    • Browse to 192.164.4.1 to display the page, got to "setting" "Wifi" and configure your ssid ap, the password if any, the wanted IP or use dhcp if you know how to retrieve the dhcp given ip (terminal or scan of the network).
    • In the gateway field, enter the ip address of your router.
    • Validate. The equipment restart to the new configuration. Connect your wifi to your AP and browse to the ip given in configuration.
    • Congratulation, you can edit your own station list. Don't forget to save your stations list in case of problem or for new equipments.
    • if the AP is already know by the esp8266, the default ip at the first start is 192.168.1.254
    • a sample of stations list is on https://github.com/karawin/Ka-Radio/blob/master/ESP8266-Firmware/WebStations.txt . Can be uploaded via the web page.
    Feedback
    Please tell me if you succeeded or something more can be done, thanks.
    The second step will add some hardware buttons (vol + -, station + -, play ...)
    Wiring:
    From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
    REST
    ADC
    CH_PD to 3.3v
    GPIO16 (a 1Hz output)
    D5:GPIO14 to VS1053 SCK...
KaRadio32.bin
V2.4R1
octet-stream - 1.49 MB - 03/09/2026 at 19:21
Download
KaRadio 2.1 R1 Partition 1
application/octet-stream - 424.75 kB - 01/11/2020 at 18:13
Download
KaRadio 2.1 R1 Partition 2
Download
boot_v1.7.bin
octet-stream - 3.98 kB - 09/17/2017 at 10:26
Download
blank.bin
octet-stream - 4.00 kB - 07/21/2016 at 15:19
Download
View all 6 files
  • 1 × ESP8266 http://www.ebay.fr/itm/121775761053?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  • 1 × VS1053 http://www.ebay.fr/itm/401046111343?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  • 1 × USB to TTL http://fr.aliexpress.com/item/USB-to-TTL-converter-UART-module-CH340G-CH340-3-3V-5V-switch/32392228218.html?detailNewVersion=2
  • 1 × MB102 Power supply http://fr.aliexpress.com/item/MB102-Breadboard-Power-Supply-Module-3-3V-5V-For-Solderless-Breadboard/2027279953.html
  • 1 × or nodeMCU clone http://fr.aliexpress.com/item/NodeMcu-Lua-WIFI-development-board-based-on-the-ESP8266-Internet-of-things/32338129505.html
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    TXD to CH340G UART rx
    RXD from CH340G UART tx
    D1:GPIO05 to VS1053 XDCS
    D2:GPIO04 to VS1053 DREQ
    D3:GPIO00 to VS1053 XRST
    GPIO02
    D8:GPIO15 to VS1053 XCS
View all instructions
Nolan Yu wrote 01/30/2024 at 07:01 • point
This is a topic that needs more attention. Thanks for addressing it. https://wollongongfencingexperts.au/
Well written and thought-provoking. https://uprightfencing.au/
Nolan Yu wrote 01/30/2024 at 07:00 • point
Interesting read. I never thought about it that way. https://townsvillefencing.au/
Olivia Higgins wrote 01/30/2024 at 07:00 • point
I couldn't agree more with your perspective. https://torquayfencingsolutions.au/
Great insights! Thanks for sharing. https://sunnycoastfencing.au/
Mason Hart wrote 01/30/2024 at 06:59 • point
Go-to source! https://sheppfencing.au/
Encourages critical thinking. https://settfencing.au/
Aria McDonald wrote 01/30/2024 at 06:55 • point
Resonates with me. https://rockyfencing.au/
Breath of fresh air. https://rockinghamfencing.au/
Ethan Rowe wrote 01/30/2024 at 06:54 • point
Deserves attention. https://redcliffefencing.au/
Articulate and compelling. https://pmqfencing.au/
Lily Pierce wrote 01/30/2024 at 06:54 • point
Well said. https://perthfencingsolutions.au/
Lily Pierce wrote 01/30/2024 at 06:53 • point
Refreshing authenticity. https://penrithfencing.au/
Jordan Lawson wrote 01/30/2024 at 06:53 • point
Meaningful conversation. https://newcastlefencing.au/
Enjoyed the humor. https://morningtonpeninsulafencing.au/
Ava Fleming wrote 01/30/2024 at 06:51 • point
Looking forward to more. https://mildyfencing.au/
Insightful comments. https://mandurahroofrestoration.au/
Max Wagner wrote 01/30/2024 at 06:50 • point
Solid evidence. https://mandurahhandyman.au/
Learned something new. https://mandurahfence.au/
Isabella Beck wrote 01/30/2024 at 06:49 • point
Bookmarking this. https://maccasfencing.au/
