Ridiculously advanced air quality monitoring station, enclosed in a compact aluminium body for rugged design, it has sensors for Gamma radiation, formaldehyde, CO2, tVOC Air quality +temperature, barometric pressure, air humidity, and a laser scattering sensor for PM2.5 particulate matter. The A3 also comes in 4 variants, with the same sensors but offering different connectivity options: Ethernet, Wifi, GSM (with a data sim card) and LoraWAN.
Detection interval
– background Gamma Radiation: 0 .. 9999μSv/h
– PM1.0/2.5/10.0 particulate matter: 0 .. 1000μg/m³
– formaldehyde: 0..5ppm
– CO2 400..5000ppm
– air temperature: -40 .. +85C
– air humidity: 0 .. 100% RH
– air quality / VOC: 0..100mg/m³ reducing gases and 0..10mg/m³ oxidising gases
– barometric pressure: 300 .. 1100hPa
– HW105+ only: noise pollution: 30dBA .. 130dBA
May 2017 - HW105
Finally, both attempts that failed in HW104 were brought to a solution. A sound amplifier circuit based on MAX4466 allowed good dBA noise calculations, while a new VOC sensor was tested, with excellent results. Finally, the uRADMonitor A3 has noise pollution detection capabilities:
Picture shows elevated readings due to auto traffic during day, with data from two nearby units functioning concomitantly.
February 2017 - HW104
I wanted to add a sound sensor, and find an alternative to the VOC detection currently implemented with the BME680 from Bosch. I tried an electret microphone amplifier circuit and the GM502B sensor, but wasn't happy with the results. Design dropped.
September 2016 - HW103
This variant was a success. 4 PCB versions to hold the same sensors but offer 4 different connectivity options: Ethernet (via enc28j60), Wifi (via ESP8266-ESP04), GSM (via SIM800) and LoraWAN (via RN2483 / RN2903).
The enclosure was reworked as well, to use a new profile that comes with wall mounting brackets. The one that came closer to my size requirements had a smaller width and this impacted the new PCBs. I also made two types of enclosures, one with a rectangular opening for the Ethernet cable connector, and one with a round hole to fit the SMA antenna connector, serving all 3 radio variants.
The sensors in these units stayed the same. Bosch BME680 for temperature, pressure, humidity and VOC, the laser light scattering sensor for PM2.5, the NDIR CO2 sensor and the electrochemical formaldehyde sensor. The SI29BG Geiger tube remained responsible for the radiation readings. This tiny unit of about 11cm long, was therefore capable to measuring 8 air parameters, sending the data over 4 distinct channels: Ethernet, Wifi, GSM or LORAWAN.
The system drew the attention of Orange, and I started a partnership with them to install several such units in a few cities. One such example was the city of Alba Iulia, the first Romanian smart city, where 15 A3 units were installed in public transportation. The data is available online, here.
This became an excellent way to use my toys in the real life environment, but also to learn to raise up to the challenge of making everything work as expected. Some time after, the system is still functioning unattended, providing precious readings on the air quality. For a few months I was busy building by hand a few tens of these devices, running tests and making sure everything is perfect. But it was worth it, and I'm proud of the accomplishment.
And talking about the data, here are some of the tests, showing the output from several devices running in parallel. These are PM2.5 measurements, counting particles as small as 2.5 microns in diameter, and you can see the devices agree on the values:
Sweet!
July 2016 - HW101, 102
These versions had some issues. First I tried to use the previous HW100 design, and add extra connectivity options: instead of the Ethernet module for wired connectivity, I needed more options: Wifi, GSM and LoraWAN. Replacing the Ethernet module with modems for the radio variants was easy, but I placed the 8MHz crystal oscillator too close to the High voltage inverter...
Radu Motisan
The previous rounded aluminium boxes where neat, but installing those in buses was problematic. I had to opt for a different aluminium profile, and do the manufacturing all over again, including new holes and silkprint. With this variant I also needed different holes first for the Ethernet variant, and a new panel for the radio boards that replaced the cable for the SMA connector holding the antenna.
Samuel Wantman
Supplyframe DesignLab
Ryan Kinnett
Hi Radu,
I saw you moved to SMD components for your HV generation. Would you mind sharing which components you used?
Best regards
Tobias
