close-circle
Open Source FFT Spectrum Analyzer
An FFT spectrum analyzer for machinery vibration analysis, using open source hardware and software
close
A computer running a program written in Python and using the libraries, Numpy, Scipy, Matplotlib, and Pyserial is the FFT spectrum analyzer. An Arduino Nano is used as the data acquisition system for reading acceleration form a ADXL335 accelerometer.
This combination makes an effective, simple and low cost FFT spectrum analyzer for machinery vibration analysis.
Overview
Machinery vibration is usually the best indicator of overall mechanical condition. It is used in preventive and corrective maintenance.
It can be measured using displacement and velocity transducers, and accelerometers. You can get an overall reading indicating the maximum value of vibration, but the most useful information is obtained with a FFT spectrum analysis of a time period reading.
Machinery vibration analyzers are usually expensive and complicated and many small and medium sized industries can't afford this instruments, particularly in my country (Bolivia).
Open source hardware and software tools are very accessible this days, and a simple, inexpensive and open source FFT spectrum analyzer can be easily built using some of this tools.
Description
For this project, an Arduino Nano is used as the data acquisition system, it contains an USB to serial converter and ADC channels. A common accelerometer, the ADXL335 is used as the transducer for vibration measurement, and a computer is the FFT analyzer, using Python and Numy, Scipy and Matplotlib libraries.
A system diagram is shown below.
The Arduino Nano listens for an incoming command from the computer, that tells it to start or stop sending ADC readings. The ADC reads the accelerometer vibration channels on a given sampling frequency (5000 Hz), controlled by one of the micro controller timers. This readings are sent on the serial port at a speed of 0.5 Mbps.
The Arduino Nano program (adxl335_01.c ) is compiled with Avr gcc, and programmed using Avrdude and the Arduino Bootloader installed in the atMega328 microcontroller. The Arduino libraries and IDE are not used.
The ADXL335 is a small, thin, low power, complete 3-axis accelerometer with signal conditioned voltage outputs. Maximum bandwidth is selected for the application, with a range of 1600 Hz for the X and Y axes. The Z axis maximum range is 550Hz, and is not used because the limited range, but it is wired to the micro controller in case it is used in the future.
A circuit diagram is shown next.
The computer controls the data acquisition sending commands to start or stop the transmission of samples. The program counts the amount of data received and the amount of data it needs (sample size). When the necessary amount of data has been taken, a command to stop is send to the microcontroller. Pyserial is the python library used to control the serial communication.
The serial communication is binary based and a mechanism to mark the end of packages is necessary. A PPP type byte stuffing algorithm is used for this. In PPP frame boundaries are marked with a reserved byte value 0x7E. This reserved value is not permitted to occur in any other place than frame boundary. In a case the reserved value should occur in data packet, an escape sequence is used to transfer 0x7E into byte sequence of 0x7D, 0x5E. The byte value 0x7D means that a possible escape follows and is called a Control Escape value. Also the Control Escape itself needs to be escaped and becomes to byte sequence of 0x7D, 0x5D.
This PPP framing algorithm is used in the Arduino Nano and on the python program for the computer.
There are two python programs, one for data acquisition from the serial port and saving that data, and the second for file opening, plotting of data and FFT spectrum calculation and plotting.
Program serial_avr_01.py sends commands to the Arduino and reads data from the serial port. Once the desired amount of data has been acquired, it is saved on a file, as text, separated by comas and delimited by tags.
Program acel_file_plot_02.py waits for a file name introduced on console, opens the file and plots the signal from the accelerometer. It is shown on the next picture.
Then, the FFT spectrum is calculated and plotted. It can be seen in the next picture.
This images correspond to a motor running at 1450 rpm (24.17 Hz). It can be seen that the peaks in the FFT spectrum are multiples of this frequency (24.17, 48.33, 72.5, 95.67, 120.83 and so on).
This... Read more »
ino - 4.82 kB - 04/10/2017 at 12:44
download-circle
Download
plain - 192.06 kB - 12/20/2016 at 19:20
download-circle
Download
fft_spectrum_gui_3can_py3_01.py
FFT sperctrum analyzer for 3 accelerometer axis. Python 3.5
text/plain - 22.95 kB - 01/12/2017 at 20:18
download-circle
Download
fft_spectrum_gui_3can.py
FFT sperctrum analyzer for 3 accelerometer axis. Python 2.7
plain - 21.50 kB - 12/20/2016 at 19:08
download-circle
Download
adxl335_3can_01_en.c
AtMega328 program to send 3 accelerometer axis.
C Source File - 5.54 kB - 12/20/2016 at 19:08
download-circle
Download
View all 17 files
  • 1 × Arduino Nano Microcontroller atMega328 and USB to serial converter on a single and small board.
  • 1 × ADXL335 breakoutboard ADXL335 3-axis accelerometer and a breakout board to make signals accessible.
  • Correction in g calculation
    Ariel Quezada02/08/2018 at 14:41 0 comments
    An error regarding the g_scale for calculating g from accelerometer voltage was pointed and corrected by Steve Ferry (thank you Steve).
    adc_resolution = 3.3 / 1024 # Vref = 3.3V, 10 bit ADC.
    accelerometer_sensitivity = 1000/300 # 300 mv/g
    g_scale = adc_resolution * accelerometer_sensitivity = (3.3 / 1024) * (1000/300)
    The Python 3 program has been corrected with this new value.
    I think the mistake was to assume that +-3g would cover the whole ADC range, but it will cover only around 2 V, not all the 3.3 V (Vref) range.
    Looking through the ADXL335 datasheet, the output is ratiometric (proportional to supply voltage), and the 300 mV/g is the approximate value using a 3.0 V supply. This numbers can have around 10% variation between devices, so I think that an additional correction factor will have to be introduced and calculated (calibrated) for each different accelerometer used.
  • Third axis and Python 3.5
    Ariel Quezada12/20/2016 at 19:39 0 comments
    I have added a third axis to the spectrum analyzer. The atMega328 (Arduino Nano) program is adxl335_3can_01_en.c. The Python 2.7 program is fft_spectrum_gui_3can.py.
    I also made a version of the three axis analyzer that works with Python 3.5, fft_spectrum_gui_3can_py3_01.py.
    There is also a file with sampled data for testing purposes datos_3can_20-12-2016__11_39_50.txt. Works with both versions of the 3 axis FFT analyzer.
    Notice that the accelerometer Z axis is limited to 500 Hz.
    This files are also available on GitHub at https://github.com/ariquezada/FFT-spectrum-analyzer/tree/master/3_axis.
    The screen shot is shown below.
  • GUI program with window functions
    Ariel Quezada07/13/2016 at 21:40 0 comments
    I updated the GUI program, and now it includes the window functions (rectangular, Hann and Flattop). These functions can be selected using radio buttons.
    This is a screen shot of the new GUI. The radio buttons are at the end of the left panel.
    I also uploaded some text files with acceleration measurements. The file names start with “datos…” and a date and time. These files can be used for testing.
  • GUI program
    Ariel Quezada06/24/2016 at 19:39 0 comments
    A program with a GUI has been developed (fft_spectrum_gui.py). It uses the Tkinter library, basically because it is the one included with Python, and no additional programs are needed. Also, it integrates very well with matplotlib.
    The new program combines the programs acel_file_plot_03.py and serial_avr_01.py. This new interface lets you scan serial ports, select the serial port, save the sampled data to file, and open files with sampled data previously saved. It also has a scrolled textbox where messages are displayed (the ones printed on the previous programs).
    A screen shot is shown below.
  • Window functions
    Ariel Quezada06/09/2016 at 15:15 0 comments
    Window functions are used to avoid signal leakage, that can hide low amplitude level signals when their frequency is close to high amplitude level ones. To avoid this leakage, the input samples are multiplied to a mathematical function, so the samples at the center of the sampled time are favored while the values of the samples at the extremes, are lowered. Usually Hann and Flattop windows are applied. Using Python and Scipy, applying window functions is very simple.
    First, you have to import the signal module
    from scipy import signal
    Then create the window function coefficients. For the Hann window use
    w = signal.hann(N, sym=False)
    For the Flattop window use
    w = signal.flattop(N, sym=False)
    N is the length of the signal (number of samples).
    Finally apply the FFT to the signal weighted with the window function.
    yf = fftpack.fft(y*w)
    Program acel_file_plot_win_01.py plots the FFT spectrum using the window functions.
    After applying the window functions, no much change is visible in the signal frequency separation and only the amplitude is reduced. Apparently, signal leakage is low for the sampled data used, and further testing would be required to validate this functions.
  • Some testing
    Ariel Quezada06/08/2016 at 18:06 0 comments
    Three measurements on the same rotating machine were taken for testing the instrument response. The first measurement was taken without modifying the machine.
    The second test was taken adding weight to a certain place on the machine, for creating an imbalance. It can be clearly seen an increase in the magnitude of the acceleration, both in time domain and frequency domain.
    Finally, more weight was added to increase the imbalance and a third measurement was made. Again, an increase in the acceleration amplitude is observed.
    From the test results, it can be seen that the instrument can detect the imbalance variations, and seems to be working properly.
  • Software scaling correction
    Ariel Quezada06/07/2016 at 19:31 0 comments
    The original program was not properly scaled. The signals were plotted using the ADC values and the number of samples obtained.
    The signal size has been scaled to g. The ADXL335 has an output from -3g to +3g, for a voltage range from 0 to 3.3 V, that is converted by the ADC to values from 0 to 1023. The original signal is multiplied by 3.0/512, and then the DC offset is determined, taking the average of all the readings. This approach assumes that the average value of the vibration signal is 0.
    A correction to the time scale has also been done, considering the sampling rate and the number of samples taken. Frequency range has been limited to 1500 Hz, the maximum frequency that the ADXL335 con provide on the X and Y axes.
    The corrected program is acel_file_plot_03.py, and the resulting plots are now properly scaled.
  • Accelerometer probe construction
    Ariel Quezada06/07/2016 at 14:03 0 comments
    The accelerometer and the Arduino Nano fit together inside a plastic probe (camera film canister). A strong magnet is also included inside, so the probe can be attached very firmly to different parts of a rotating machine and measure its vibration.
    The accelerometer breakout board is soldered to a perforated board and three capacitors are connected and soldered, one to every analog output form the ADXL335. Header pins are placed at the sides of the board and arranged so this pins fit inside single line sockets soldered on the Arduino Nano, instead of the regular connector headers.
View all 8 project logs
svarun52 wrote 01/26/2018 at 16:19 point
Hi ,this is very amazing project ,i'm trying this project but i am getting some warnings in    python 35 like this
Warning (from warnings module):
  File "C:\Users\csc\Desktop\VARUN\CreaTech\FFT-spectrum-analyzer-master\3_axis\Python_35\fft_spectrum_gui_3can_py3_01.py", line 199
    ax_11.hold(False)
MatplotlibDeprecationWarning: axes.hold is deprecated.
    See the API Changes document (http://matplotlib.org/api/api_changes.html)
    for more details.
  File "C:\Users\csc\Desktop\VARUN\CreaTech\FFT-spectrum-analyzer-master\3_axis\Python_35\fft_spectrum_gui_3can_py3_01.py", line 205
    ax_12.hold(False)
    for more details.
  File "C:\Users\csc\Desktop\VARUN\CreaTech\FFT-spectrum-analyzer-master\3_axis\Python_35\fft_spectrum_gui_3can_py3_01.py", line 212
    ax_12.hold(False)
    for more details.
  File "C:\Users\csc\Desktop\VARUN\CreaTech\FFT-spectrum-analyzer-master\3_axis\Python_35\fft_spectrum_gui_3can_py3_01.py", line 223
    ax_21.hold(False)
    for more details.
  File "C:\Users\csc\Desktop\VARUN\CreaTech\FFT-spectrum-analyzer-master\3_axis\Python_35\fft_spectrum_gui_3can_py3_01.py", line 230
    ax_22.hold(False)
    for more details.
  File "C:\Users\csc\Desktop\VARUN\CreaTech\FFT-spectrum-analyzer-master\3_axis\Python_35\fft_spectrum_gui_3can_py3_01.py", line 238
    ax_23.hold(False)
    for more details.
can u plz help me in solving this problem
steve wrote 01/30/2018 at 14:42 point
Hi Svarun52, Im no Python expert myself - only started using it 3 weeks ago. As I had those same warnings, I simply commented out the offending lines because they dont do anything as the command is deprecated and that stopped the warnings.
Ariel Quezada wrote 02/09/2018 at 12:27 point
Matplot lib
deprecated the ax.hold() function. Commenting or deleting the lines containing this function will have no effect on the program and the Python interpreter will not issue those warnings.
The Python 3 program has been modified accordingly.
Ariel Quezada wrote 01/17/2018 at 12:08 point
Hi Steve, thank you for the suggestions. I plan to add the velocity component, but I was thinking about integrating the acceleration signal. I think I will test both forms. I will also check the Hilbert transform and the imperial units.
About the STM32F103, I thought about using it (I have a few around), but it did not fit in the film canister I am using. I plan to fabricate a container using a 3D printer, so the STM32F103 would be a good option.
Another option I was thinking of was the ESP32, that has Bluetooth and WiFi included.
There are many things to implement this year.
Thanks, and your help is welcome.
steve wrote 01/16/2018 at 23:16 point
hi, I’ve been running my own vibration analysis company for over 25 years and an very interested in this project. I’d like to make some suggestions. In order to fully assess machine condition, it would be useful if you had another two tabs with different plots. Firstly, convert the acceleration to velocity where velocity at each peak can be determined by (acceleration X 9806.65) divided by ( 2 X pi X frequency)  the gravity constant converts g’s to mm/sec/ sec. velocity is in mm/sec. There could also be an option to show in Ipswich for those who prefer imperial measurements. Secondly, apply a Hilbert Transform to the timewaveform prior to fft to give an envelope or demodulated spectra. This shows any bearing fault frequencies hidden within the twf and is the best tool in the box as far as I’m concerned.
I’d also like to suggest using an STM32F103 ‘blue pill’ which can be programmed using the Arduino IDE, has a processor speed of 72mhz and 12 bit adc’s For a very reasonable price on aliexpress. Plus, how about Bluetooth rather than usb wired connection? I’d very much like to help with this project. Steve.
Pavel Bára wrote 12/01/2017 at 04:09 point
Conversion to velocity
I try to add to your code calculation of actual and effective velocity in mm/s.
I use this simple code.
Velocity_Last = 0
Velocity_Suma = 0
for indice in X:
Velocity_Suma += np.power(Velocity_Last + (9.8 * canal_1[indice] * 0.2), 2)
        Velocity_Last += 9.8 * canal_1[indice] * 0.2
Velocity_Effective = np.sqrt(Velocity_Suma / datos_a_leer)
print (Velocity_Effective)
message_string = "Velocity X: {0:2.3f}\n".format(Velocity_Effective)
self.show_message(self.text_message, message_string)
Do you think it will work?
I will make some comparative measurement in two weeks.
I have one more question.
Acceleration is possible to integrate to velocity.
Suitable method for this is Omega Arithmetic method.
http://blog.prosig.com/2010/12/16/methods-of-conversion-between-acceleration-velocity-and-displacement/
I find implemetation of this method in matlab.
https://www.mathworks.com/matlabcentral/answers/264594-conversion-of-acceleration-to-velocity-and-displacement
But I am not able to conver this to python.
Can you help me with this?
Thank you
Best regards
Ariel Quezada wrote 01/19/2018 at 12:50 point
Hi Pavel, I have just started thinking about obtaining velocity and displacement from
acceleration, and I can not help you with this right now.
Thank you for the links you provided, they are very interesting and useful. I had not
heard about the Omega Arithmetic before, but it seems very promising, and I will try to implement it.
Best regards.
Pavel Bára wrote 02/09/2018 at 05:35 point
Hi Ariel, Omega arithmetic is the same what describe Steve above "divided by ( 2 X pi X frequency)". There is a problem on low frequency (big fault). I try to implement "Omega arithmetic" to your code. It is works. I can send my code to you, if you are interested.
Best regards
Pavel
Ariel Quezada wrote 02/09/2018 at 12:34 point
Hi Pavel, I am interested in your code, and would like you to send it to me.
Best regards,
Ariel
Pavel Bára wrote 02/09/2018 at 12:38 point
Can you write me your e-mail here?
I would like to send to you me code.
RENEE wrote 10/26/2017 at 14:24 point
Hi Ariel, I am trying to reproduce something very similar to your project.I would like to use your arduino code (.ino) but I've found some issues. Is it possible to start the data aquisition from accelerometer sending a character in serial monitor in the Arduino IDE? I tried to send "INI" but it isn't worked. How can I start the accelerometer throu serial monitor in the arduino IDE?
Thank you!
Best regards!
olem_de wrote 04/19/2017 at 12:02 point
Hi Ariel. a last question: I want to use your script also on other PC but not every has a python installed. so i tried to create  EXE file but struggled. I have tried py2exe successless. Do you have experience with this tool ?
regards Ole
olem_de wrote 04/09/2017 at 18:01 point
Hello
sorry i tried to compile your arduino code but i failed. Is there a way to use the Arduino IDE to compile? I am not familiar with that avr-gcc stuff and the IDE failed with a lot of error messages
regards Ole :-)
Ariel Quezada wrote 04/10/2017 at 12:43 point
Hi Ole, It is possible to compile using the Arduino IDE, but you have to use its structure (setup and loop). If you use the IDE, you can use the Serial class to manage the serial port. I wrote the program for Arduino IDE and it´s included with the project files. To configure the timer and ADC it writes directly in the configuration registers. Regards, Ariel.
olem_de wrote 04/10/2017 at 20:40 point
Hi Ariel.thx so much. compiling and downloading works, but the read out values are just 0-values. Now i am not quite sure if my breakout is working or not (although it is a new one). Are the external capacitors (3x3.3nF) necessary?
Ariel Quezada wrote 04/10/2017 at 21:27 point
Ole, did you connect the 3.3V to the Aref input in the Arduino? The capacitors (2X 3.3nF, 1X10nF) are used to limit the signal bandwidth, and avoid aliasing problems due to sampling. Probably you can skip them because the bandwidth is limited in the adxl335, but I prefer to be sure.
olem_de wrote 04/10/2017 at 21:32 point
Yes you are right i found out in the same minute as you answered my post - i have forgot to connect aref to 3.3v.
thx again :-))
Ariel Quezada wrote 04/19/2017 at 21:17 point
Hi Ole. Sorry, I have no experience with py2exe. I think that the problem could be with the numerical libraries, Numpy and Scipy, that use compiled code for optimization. I would rather work with the Python interpreter and install the required modules.
Regards Ariel
karimabdular.1605 wrote 03/10/2017 at 06:27 point
Hello Ariel, I heve project about vibration Analyzer and I want to try make same this one.
I have Question for you. Can you explain to me how to  upload your arduino program to the arduino boart. thanks
Ariel Quezada wrote 04/10/2017 at 12:51 point
Hi, I am sorry I didn´t see your message before. I did not use the Arduino IDE for previous versions, but I rewrote the program to work with the Arduino IDE (setup, loop and serial). The program is adxl335_3chan_01.ino and it is inculded with the project files. If you use the previous version (.c file) you have to compile it using GGG end download it using AVRDUDE.
Regards,
Ariel
karimabdular.1605 wrote 04/11/2017 at 06:04 point
Yes Ariel. thanks so much for your respon. Now i have a finish running your python program and uploading adxl335_3chan_01.ino to my Arduino nano. Your project is very cool. I have tested your vibration analyzer on drilling machine and I got the result is very well. But i heve Question about this project, I see the data graphic will update if I click button read serial data and is not real time update on the graphic.
I need your help, can you explain to me how to make the graphic is realtime update the data. Thanks
Ariel Quezada wrote 04/11/2017 at 16:37 point
Hi, I don't think the system can run fast enough to be real time. Maybe it can run in continuous mode, starting a new reading immediately after the previous reading finishes, not waiting for a button press. You nedd a certain amout of data to run the FFT.
karimabdular.1605 wrote 04/11/2017 at 17:29 point
Yes Ariel, I understand, but just now I have to finish make the program run in continuous mode. in this case modified this line
while (estado_serial == True):
            global g_canal_1, g_canal_2, g_canal_3, datos_a_leer
            canal_1 = []
            canal_2 = []
            canal_3 = []
            buffer = ''
            paquete = ''
            valores = []
            serial_avr.flushInput()
            serial_avr.flushOutput()
            valores_decod = []
            conta_datos_rx = 0;         #Received samples counter.
            print("Sending INI")
            message_string = "Sending INI \n"
I add while loop to the program.
After I run the program. I got the reading is update continuesly but if I try to save file the and press button save file, the python GUI is not responding.
Ariel Quezada wrote 04/12/2017 at 12:10 point
You created an infinite loop that continuously will read the serial port, but I never ends. You have to make a call to read_serial(), the function called when you press the button to read data. This function should be called after it finishes reading data. Use a flag (boolean) to control start and stop reading. You can use a button to start/stop the readings also.
jslee777 wrote 01/09/2017 at 11:47 point
I need your help.
I think there are some problems in these parts
----------------------------------------------------------------serial_avr_01.py
while x < len(valores):
if valores[x] == 0x7D:
valores_decod.append(valores[x+1] ^ 0x20)
----------------------------------------------------------------- error
Traceback (most recent call last):
  File "/home/pi/FFT-spectrum-analyzer/serial_avr_01.py", line 92, in
    canal2 = (valores_decod[2] * 256) + valores_decod[3]
IndexError: list index out of range
I have been tried to use try - exception error. it works, but some data are missing
Please let me know how to solve this problem
Ariel Quezada wrote 01/09/2017 at 12:57 point
Hi, I think the problem is in the incoming data (communication channel or microcontroller). The list 'valores' is formed when you receive a 0x7E byte, that marks the end of a data block, so when you analyze a block of data, you should alwas have either a 0x5D or 0x5E after a 0x7D byte. If not, there is an error in the data block received. Which OS are you working with? Which UART to USB chip are you using? I had problems with data loss when using a CH340 and Debian Linux. Regards.
jslee777 wrote 01/11/2017 at 12:48 point
Thank you for your quick response. As you said, there are some data missing problems with CH340 and Debian Linux. After  I changed CH340 to FTDI, it works very well.
I have one more question about fft_spectrum-gui.py
I am not sure. but, I think there is a infinite loop in this part (it while conta_datos_rx < datos_a_leer:). Do you have any idea?
Ariel Quezada wrote 01/11/2017 at 21:59 point
You are right, the "while conta_datos_rx < datos_a_leer:" will create an infinite loop if the total amount of data expected is not received or if it is not foratted correctly (not enought 0x7E markers). I think that a timeout should be added to this loop. This is one thing that has to be added to the program. Thank you for noticing it.
Ariel Quezada wrote 01/12/2017 at 21:37 point
Hi, I added a timeout to the loop "while (conta_datos_rx < datos_a_leer)". I am checking the elapsed time since the loop started, and if it is longer than 8 seconds (defined in t_timeout), the loop will terminate.
The while loop part is now:
    global t_timeout
     timeout_state = False
     t0 = time.time()       #Start loop time stamp.
     while ((conta_datos_rx < datos_a_leer) and (timeout_state == False)):
        #Check if t_timeout seconds have elapsed since time stamp t0
        if ((time.time() - t0) > t_timeout):
             timeout_state = True
I updated the program fft_spectrum_gui_3can_py3_01.py with this changes.
Jaime Chaparro wrote 11/09/2016 at 15:18 point
Hi, this is a very useful industrial application, I'm very interested in replicate it by myself! But, is any practical improvement (sensibility, range, etc.) in changing the adxl335 for the "new" adxl345 or even for a piezoelectric vibration sensor? thanks!
Ariel Quezada wrote 01/09/2017 at 12:42 point
Hi, I don't know why I missed your message, very sorry. I think the adxl345 is a good replacement, and you can select between many sensitivities. 2g to 16g. Interfacing shoud also be easier, no badwith limiting capacitors nor sampling needed. Also the lowest resolution seems to be 10 bits, that is the same in the atMega328 ADC. A piezo sensor should work fine, but maybe you would need some extra signal conditioning.
edward wrote 08/18/2016 at 16:31 point
con la señal FFT que conclusión llegó?  pudo determinar algún tipo de falla, quizás pudo concluir errores en el motor por fallas de desbalanceo, desalineamiento, rodamientos,etc. Con este acelerómetro y en esa posición que tipo de fallas se pueden detectar.
Ariel Quezada wrote 08/18/2016 at 19:27 point
En el LOG número 3 (Some Testing), se muestra el resultado de hacer un desbalanceo en un equipo de prueba. Se muestra el espectro sin el desbalance, y luego dos espectros, con distinto desbalance. Se observa claramente que el pico en la frecuencia de operación del equipo (24.17 Hz o 1450 rpm) se incrementa con el desbalanceo. Los otros picos en múltiplos de 24.17 Hz muestran que el equipo está desalineado. Los archivos datos_08-06-2016__13_34_50.txt, datos_08-06-2016__13_37_26.txt y datos_08-06-2016__13_45_09.txt corresponden a estas mediciones.
edward wrote 08/11/2016 at 03:01 point
Hola
buen tutorial "An FFT spectrum analyzer for machinery vibration
analysis, using open source hardware and software", quisiera saber como hizo para colocar el
acelerómetro al  cable(donde lo puedo conseguir?¿Qué tipo de
cable es?) , ¿Tiene algún tutorial de la construcción del
empotrado del acelerómetro al cable?,ese pequeño circuito de condensadores me imagino
que es son filtros, es correcto?, de que valores son los condensadores, tiene
un diagrama?,¿Cómo lo puedo comprarlo o hacerlo?. Gracias.
Ariel Quezada wrote 08/11/2016 at 12:23 point
Hola edward, en la página del proyecto hay una galería de imágenes, y ahí puedes encontrar el diagrama esquemático de la conexión entre el Arduino y el acelerómetro. Todo el sistema entra en un antiguo envase de rollo de película fotográfica, y el cable es solamente un cable USB mini para conectar al puerto USB del Arduino Nano.
Los capacitores se utilizan como filtros paso bajo, para limitar el ancho de banda de la señal antes de digitalizarla. Los valores están en el equemático y corresponden a una frecuencia de 1500 Hz para los canales X e Y.
El acelerómetro está en una placa 'break out', y se consigue en ebay (http://www.ebay.com/itm/ADXL335-3-axis-Analog-Output-Accelerometer-Module-angular-transducer-for-Arduino-/400985206886?hash=item5d5c94b066:g:ZokAAOSwq5lTmAS9) o en Adafruit (https://www.adafruit.com/product/163).
Los capacitores van en una placa inermedia, que sirve de enlace entre el módulo del acelerómetro y el Arduino.
Saludos.
edward wrote 08/10/2016 at 17:37 point
for this type of non-stationary signals, it is not better to use an ARM or FPGA or DSP?
Why you prefer to use Arduino?
Ariel Quezada wrote 08/10/2016 at 21:19 point
The microcontroller is used only for data acquisition. The signal processing (FFT and windows) is done by the PC program. I chose the Arduino Nano because of its avalilability and its size.
edward wrote 08/11/2016 at 02:16 point
El adc de arduino es limitado(número de bits ) para la adquisición de datos. Usando un adc paralelo de 10 bit(ad9215) te ayudaría a mejorar la calidad de data almacenada.
Ariel Quezada wrote 08/11/2016 at 12:28 point
Una de mis opciones es usar una placa con STM32F103C8T6 (http://www.ebay.com/itm/1pcs-STM32F103C8T6-ARM-STM32-Minimum-System-Development-Board-Module-Arduino-/201414966215?hash=item2ee5447bc7:g:X-oAAOSw6BtVVACk), que además de un procesador  ARM tiene un puerto USB y dos canales paralelos de 12 bits, y es muy económico, pero es un poco más grande que el Arduino Nano, y no cabe en el envase que tengo disponible. Sin tomar en cuenta el tema del envase, este micro es una mejor opción.
Bob Hannent wrote 07/08/2016 at 07:47 point
I really like this, I've often wondered if such an analysis would be beneficial in domestic cars. Given the low cost of the components it must be getting closer to a time when such analysis is practical for every day mechanics, the issue then becomes the interpretation rather than the tools.
