I wanted to do this project because is a good starting point for home automation.
My idea is to use the nice ESP8266 and do everything in python (micropython).
I bought a Nodemcu ESP8266 a while ago and I wasn't using it, so when I heard about the micropython project, I got interested. I flashed the ESP12 with the latest micropython for ESP8266 and starting to play.
I find MQTT as the perfect solution for a project involving IoT and Home Automation, so that's what I was planning to use. As far as I know, nobody has done exactly this thing using micropython (you can find similar things using LUA or C) and adding a OLED 128x64 screen seemed like the right thing to do in a thermostat.
I think a thermostat is one of the most complicated things in home automation out there, so once ready it can be easily scaled to other parts of the home like appliances, lights, shaders, etc. that will be far more easy to automate.
krich
Charles Yarnold
Xasin
I replaced the defective thermostat of my freezer with a Nano, a relay, an SSD1306 display and a one wire probe. I chosed to lock the temp at -18°C and to display current, lowest and highest temps. Fast and easy.
