The necessary schematic, board files, and test code can be found below. The entire design has been validated, and is set up for production using OSHPark's PCB service, with parts all available from Digikey.
The board was made using entirely 0805 passives to make hand-soldering possible. The connector can be attaching using the "flood-and-wick" technique ( use plenty of flux! ).
jareklupinski
Corey Benn
PK
Valentin
I pulled this out of my project box (I had it working before, but didn't have a good application that I wanted to use it for.... now I do).. I loaded up the recent Teensy Duino, downloaded the llibraries, re-compiled the EpaperQuoteDisplay (since I wasn't sure in what state I left it) and the only output I see is : Beginning SPIResetting screenwaiting for busy signal
I got all the latest libraries. I've verified that I have the Teensy Epaper Adapter properly aligned (at least w.r.t the 3.3V and GND listed on the Teensy LC). Has something broken while I had this in my box? (could I have possibly had the adapter on wrong once? ) Have I killed it? :-(
